Everything posted by PAezb
stereo question - aux in
PAezb replied to J A Blazer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust assuming for example, you're in rush hour traffic, cars are fairly tight and moving along slowing, and someone next to you decides to "scan" their FM dial... Wasn't sure of this product's capability. There are the home products that let you send FM signals throughout the home - having transmitting ability of 30ft or so (Ithink). I was wonder if this was the same type of principle...but it looks like from the response this is not the case.
PAezb replied to J A Blazer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have not used one of these - is there the possibility that other drivers near you can pick up on the signal on their radios? (say if you're on a private cell phone call)
Camper/Trailer
PAezb replied to Subaru_Aloo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot sure if Impreza's would handle these well. The Tribeca, Outback and Legacys and Forester's should have no issues in non-mountainous areas: I tow a 13 ft Casita Deluxe with my OBW. I don't recommend anything larger than the 13ft models except for the new Tribeca which should be able to handle a 16 footer. http://www.casitatraveltrailers.com/13-layout.html http://www.scamptrailers.com/ http://www.fiberglassrv.com/ Check out all the Brand/Models - lots of options..... http://www.fiberglassrv.com/board/index.php?showforum=52
Front Axles, '99 Outback
PAezb replied to 94Loyale's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI haven't ordered yet for my 96 OBW, but will be doing so very soon. Seems to be a few thumbs up here on the board on these: http://www.ccrengines.com/mwe/index.html Previous threads on topic: http://www.ultimatesubaru.org/forum/showthread.php?t=86449&highlight=axle+replacement http://www.ultimatesubaru.org/forum/showthread.php?t=83907&page=2&highlight=axle+replacement http://www.ultimatesubaru.org/forum/showthread.php?t=80970&page=4&highlight=axle+replacement
Dealership Service Coolant/Tranny
Alright, here we go again. 05 OBW XT with 59K - was going to have the coolant and tranny fluids "flushed". Dealers here in the Twin Cities are offering on a drain and fill on both but not a flush - they say Subaru doesn't recommend a "flush" on either. I was told by one service dept that flushes are not recommended as they could break loose some sediment buildup that may cause problems (what? are they afraid some sediment around the HGs may be a good thing and cleaning it out may cause leaks? ) Anyway, the going price for the drain n' fill is around $99 (each), which for that price I may just as well do myself. One dealer would do a tranny flush but at $159. I was thinking that I'd have the dealer do these services inside the 60K warranty just in case if there were any issues down the road the service is documented. I've always been a proponent of flushing those systems out - I just like the idea of near complete fluid change. What say all you - should I just go the drain n' fill route? Update: I'm a little miffed on the tone and response of the dealers not wanting to do a flush on these systems since they were always happy to take my money in the past for those services on my 96 Outback. So, I just got off the phone with SOA, and the official response is they do not recommend flushes because they have not, and cannot test those flushing machines that the dealers (or independents) use, and cannot state whether the machine and or process may or may not cause damage I have to assume SOA may have had some warranty issues in the past on such services done and they have defined their service policy now to only drain and fills to protect themselves. :rolleyes:
Stuck caliper pin / slide
PAezb replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had the same problem with my 96 OBW when doing the brake job last summer. Ended up destroying the rubber boot getting the pin out - and having to buy a Subaru's caliper rebuilt kit (all new rubber boots, piston seals, clips, grease for $20 - covers both front calipers). Well worth it rather than trying to save the original boots from sticking slider pins.... .02
stereo upgrade - recommendations?
PAezb replied to J A Blazer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo recommendations, but your research should begin here: http://www.crutchfield.com/app/product/category.aspx?c=3&cc=01&cm_re=internal_nav*target1 http://www.avsforum.com/avs-vb/forumdisplay.php?f=160 http://www.caraudioreview.com/
2.5 Premium or regular gas
PAezb replied to FSRBIKER's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe 96 owners manual states 91 Octane is recommended, but 87 can be used. For the 12+ years I have owned my 96 OBW (237K). I normally put 87 in it, occassionally 89, and 91 when towing. I can't tell much if there is a increase in power at 91 but would probably say it seems to run best on 89. I wouldn't worry too much about it. Oh, and yes the 96 2.5 has hydraulic lifters....
Octane Boost Recommendations
PAezb replied to PAezb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have put 89 once in a great while, and its seems to run fine with that (I don't/won't spool the Turbo up though). I thought products like HEET were hard on the CATs and such. BTW I don't know if your last reply was because of my comment about the mule and your username - I just have to post... http://ww2.glenbow.org/search/archivesPhotosResults.aspx?AC=GET_RECORD&XC=/search/archivesPhotosResults.aspx&BU=&TN=IMAGEBAN&SN=AUTO3351&SE=835&RN=0&MR=10&TR=0&TX=1000&ES=0&CS=0&XP=&RF=WebResults&EF=&DF=WebResultsDetails&RL=0&EL=0&DL=0&NP=255&ID=&MF=WPEngMsg.ini&MQ=&TI=0&DT=&ST=0&IR=11420&NR=0&NB=0&SV=0&BG=&FG=&QS=&OEX=ISO-8859-1&OEH=ISO-8859-1 There are moose in northern Minnesota as you know - could be a alternative...
PAezb replied to PAezb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI agree totally with you're statements above - all considered when I purchased the Turbo, among many other factors. I'm just learning that the Octane boosters don't boost enough to even consider, let alone ramifications to the engine and fuel system. So.... Anyone know of a low mileage mule for sale...
Battery Suggestion - 2000 Forester
PAezb replied to howards11's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFrom: http://autos.msn.com/advice/CRArt.aspx?contentid=4023696 Quote "Most auto batteries are made by just three manufacturers, Delphi, Exide, and Johnson Controls Industries. Each makes batteries sold under several different brand names. Delphi makes ACDelco and some EverStart (Wal-Mart) models. Exide makes Champion, Exide, Napa, and some EverStart batteries. Johnson Controls makes Diehard (Sears), Duralast (AutoZone), Interstate, Kirkland (Costco), Motorcraft (Ford), and some EverStarts." end quote. I believe the original battery in my 96 Subaru was a manufactured by Johnson Controls (Had 8 years on it before exchange which it didn't need to - but I was doing batteries for a couple other vehicles at the time). An interesting article of what may be possible to replacing batteries in the future... http://www.technologyreview.com/read_article.aspx?ch=specialsections&sc=batteries&id=18086&a= Read comments following article...
Trailer wiring harness help desperately needed.
PAezb replied to chaos1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't think so - only Outbacks, maybe the Foresters of that vintage. But to be sure contact a local dealer or SOA and let them provide the answer.
Raybestos vs. Centric vs. Brembo vs OEM
PAezb replied to 2X2KOB's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXVery happy with the Raybestos rotors and pads I replaced at 211K on my 96 Outback (now 235K). $150 for complete rotors/pads GS Semi-metallic, except for the front - upgrade to the PG pads. I think there every bit as good as the OE - maybe better as I had warping problems with Subaru's rotors. At the price, given the age of the car, my driving habits, this was a no-brainer in choosing Raybestos or OE. Others here will disagree.
PAezb replied to howards11's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX2nd the recommendation for Interstate batteries - I've had good experiences with their product's performance and reasonable cost.
Ok, so I have a 05 OBW XT, which we all know requires premium fuel (Turbo = 91 Octane minimum). In the Twin Cities, 91/92 Octane typically runs around $0.15/0.20 more than 87 Octane - no biggie. However in my regular travels to northern MN I've frequently had to pay $0.40 to $0.50 per gallon more for 91, which 87 is already $.20 more than in the TC - biggie. So, I've begun my research into purchasing an Octane booster to add to 87 for cost savings when up north. I was in Wally World checking out the Octane booster products which typically run $2 to $5 per bottle to treat a tank of gas (15 gallons). But most of the products do not state how much their product will raise the octane level. Anyone with experience and product suggestions...?
PAezb replied to chaos1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAnd maybe call SOA and tell them what a PITA it is to find the connector... it shouldn't be that difficult.
PAezb replied to chaos1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe connector for my 05 OBW XT is on the driver side as well. I did find references on googling that appears that some MY 00 to 04 may be on the passenger side:rolleyes: You'd think Subaru would standardize something like this...
plague of the bouncy speedo HELP!!
PAezb replied to scrapdaddytatum's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre the other gauges functioning normally? Does your vehicle shift ok, no jolts or hesitation? Is the bounce of the needle consistant or varies wildly? Does the bounce occur if you manually put the transmission in 1st, 2nd, 3rd, Drive, Reverse? Does the CEL come on? Describe what happens when you take your foot off the pedal, does the needle fall back to zero? Possibilities: Intermittant break in the cable or connector to sensors or gauges An issue with the ECU/TCU with regards to the signal coming from the VSS sensors. Problem with the mechcanical "tab" drive mating the tranning to VSS-2 Long shot - try discconnect battery to reset ECU Other than that I don't know what to tell you to try. Anyone else....?
PAezb replied to chaos1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXetrailer.com - the picture on this webpage is for the Forester, but if you read on it states that connector for the Outback is located on the drivers side (Should be the same for all later 200x Outbacks). http://www.etrailer.com/pc-VWH~118370.htm?vehicleid=20032410
09 Forester thoughts???
PAezb replied to chef_tim's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI spoke to a local dealer about this new coolant, unfortunately I didn't ask exactly what the chemical makeup of it was - but I did learn than it can be used in older cars but that a complete flushing is recommended (no drain and fill - confirming that it should not be mixed with other coolants). Regular Subaru coolant is priced at around $18/gal, new stuff is $22/gal. The 10 year interval will be nice - going to have my 05 OBW XT done with it.
so my speedo is bouncy?????
PAezb replied to scrapdaddytatum's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo you replaced the unit on the transmission with a *new* part - right? Not a used one pulled from another vehicle in a junkyard or otherwise? It may be defective anyway. Might want to try another unit to see if the symptom changes. If you search the archives, I think I remember reading someone suggesting a way to test the signal voltage output of the device by mounting it in a varible speed drill and watching if the output signal changes linearly on volt/ohm meter with the speed of the drill. But I never tried this. To make sure we are all talking about the same sensor - here is simple description of the 2 VSS components: http://autorepair.about.com/library/faqs/bl833h.htm. There is also previous message threads with pictures if you do a search: http://www.ultimatesubaru.org/forum/showthread.php?t=65752&page=3&highlight=vehicle+speed+sensor There is actually a 3rd VSS component which is the VSS buffer circuit located in the head unit (or gauge cluster) which takes the signal given to it from the sensor on the transmission to the ECU. As the article decribes, problems with the speedometer are either with the VSS-2 sensor (most likely) or with the circuit in the guages (most unlikely).
PAezb replied to scrapdaddytatum's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes the needle bounce at the lower speeds and then act normally when cruising at 30mph or above? If so, more likely the problem is at the VSS on the transmission than the VSS circuit in the instrutmentaion cluster. Did you replace either one with new or used parts? The VSS electro/mechanical on the tranmission has a common failure rate of between 90K and 140K miles - usually surcombs to the heat from the tranny and first symtoms show bouncing of the needle when first starting out and at low speeds. Symtoms may vary from a cold to a warmed up transmission. On my 96 OBW, the originally started failing at around 96K, replaced new, and now again at 235K -planning to replace soon. Dealer techs I've spoken to confirm it's common component to fail. From what I know about the VSS circuit in the head unit (gauges) when it fails, it fails completely - no speedo needle movement at all. Hope that helps.
Light grinding noise at right rear wheel
PAezb replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTo all the above I might also suggest checking the parking brake - have you used it recently, and not normally use it? - sometimes when used infrequently rust/crud can cause the mechanism to become sticky. .02
PAezb replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTo all the above I might also suggest checking the parking brake - have you used it recently, and not normally use it - sometimes when used infrequently rust/crud can cause the mechanism to become sticky. .02
Subaru Newsletter - March 08
PAezb replied to PAezb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSubaru might have to revisit the past... http://www.subarudrive.com/Sum06_attic2.htm http://www.subarudrive.com/Sum06_attic3.htm I might add that if the US/World economy should tank, the older, less complicated technological designs will be more maintainable (assuming parts can still be found or built).
