				Posts185
				Days Won1
Everything posted by Huck369
	Should have clarifed in the original post, the vehicle is a 99 Forester with the SOHC 2.5, and I have 3 EJ18's laying around... Numbchux I may try that, sounds pretty straight forward. Got one more thing to try to get the 2.5 usable, but if that fails, I'll probably be giving the EJ18 a shot.
	as the title says, it's an OBDI EJ18, I think a 95 model...would have to check about the EGR, but could live with the CEL if it'd get it back on the road.
	Like the title says, I was thinking about installing an OBDI EJ18 in place of a OBDII EJ25 any info on this? I'm doubting it will just "plug and play" but what will it take to get it done. ...and yeah, my internet time is limited, and there are tons of swap threads to sift thru when doing a search, so, if you don't want to answer something that has already been answered, please link me to a relevant thread, and I'd be very thankful.
	Can Any of you with some electronic knowledge tall me if I can "Fool" the TCU on my 95 Impreza 1.8 4-EAT coupe into thinking it's warmed up sooner so the torque converter will lock up sooner, as it won't lock up until I am almost to work, and would like to squeeze every MPG out of it that I can. I plan to eventually swap it to a 5-Speed, but until then, would like to make the 4EAT do a little better for my commute...
	  Motorcyles, what are you riding?Huck369 replied to Slacker's topic in Non Soob Cars and Bikes Discussion I ride a Suzuki V-Strom on the street, and a Honda CRF250X on the trails... Also have a Honda VTR250...
	OK, IT's now running..... I had the timing belt on and off about 8 times, trying both the"By the book" and with the Crank 180 out.... It would crank over fine, either way. What seemed to fix it was I pulled out the Crank Position Sensor.....cleaned it off, re-installed it, and then it fired right up....go figure....AS I hadn't even touched the CPS up till that point.... I'm just glad it's back up and running.....and it is timed "By the book"
	I have tried it "by the book" did that first....And yes, I had several things un-hooked (actually I tryed to start it the first time without the MAF hooked up (DOH!) but it still wouldn't stat after I hooked it up. I had the folloswing un-hooked: MAF Cam Pos. Sensor Plug Wires Radiator fans All of which are hooked back up. (except the fans, as I haven't put the radiator back in yet, want to hear it run first) I just Changed the water pump New OEM Thermostat Valve cover gaskets Spark Plugs Timing belt Timing belt pulleys Cleaned everything up before re-installing it....should have been done hours ago......grrr......this has killed my whole saturday......and it's Still not running....
	Thanks for the quick reply... The Crank does have th ekeyway in it, so there is no way to put it on wrong.... And the left cam gear has the tabs on the bak of it for the cam position sensor, so it won't run at all if they a=re on the wrong head (i just pulled them off to make sure they were on the correct side, and they are) And yes, with the crank 180 off, the keyway points straight up.... I took the crank sprocket off and painted the tab on the back that is 180 out from the correct mark, and put the belt on that way...still no start...I'm completely lost on this one.... I've never had this much trouble with an EJ t-Belt before....
	OK....here's the deal...I've done a ton of these....but this one has me confused... I was re-sealing the motor today, and replacing the timing belt water pump....well, I disassembled it and notice the Crank gear was 180 out when I lined up the cam marks (before I removed the old belt....didn't think too much about it) When I put it back on I installed it with all the marks in thier correct place, matched to the marks on the new belt (which ment I had to spin the CRANK 180 degrees to make it line up)...it won't start, but was running fine before I removed the old belt.... So after giving it some thought, there should be NO WAY the CRANK mark can be out 180, as it goes around twice for every rotation of th ecams, so the CAMS can be 180 out form the crank, but EVERY time the Cam marks are up, the Crank mark should be up too.....so how was this motor running with the CRANK mark 180 off....I'm really stumped on this one... (And yes, I know you use the mark on the pick-up tooth on the back of the crank sprocket ) I guess I'm going to have to try installing it with the Crank Sprocket 180 off, but there is no mart to line it up to that way, so it will be a "close Guess"....anyone got anything better....
	I have tried, pulling it out some, and different angles...when you stand there for 10 minutes filling it in below freezing weather, you tend to try anything to make it faster:grin: ...but thanks for the reply I'll check the charcoal canister....sucks that it's in the back instead of the engine compartment....but at least the hoses will be shorter... I'll reply with results when I get around to checking it (hopefully before I need gas again:eek:) Huck
	Howdy, I've got a problem with the 2000 OBS I picked up a few months ago, and after a search couldn't find anything on it.. The issue is it won't take fuel.....well, it will BARELY take fuel, it will kick off the auto-shut off on a gas nozzle, even on the lowest setting.... So I have to hold the trigger the whole time, at just a slight trickle...takes about 10 minutes to fill it up... So anybody ever have this issue, and if so, how did you remedy it? I've messed with a lot of Subarus, but never run into this before... Any help would be appreciated. Huck Creator of FrankenWedge
	Very cool.... I've been wanting to do this for years.... cudoo's to you:headbang:
	Yeah...I don't get over here too often...
	Thanks Guys, The valve covers are dry as a bone...but I have new ones, as I plan to adjust the valves too... It looks to be leaking a little around the oil pump area...could be the oil pan too though....and maybe the front seal... So I'll probably replace them all. Can you do the oil pan with the motor in the car?
	Looking at resealing my EA81 in my Brat.....it's my first EA81 motor, so I was looking for a list of the typical leaks in a EA81 Info 1984 Brat EA81 4-Speed D/R 99k on it. Thanks in advance. Huck
	You might want to replace the plugs as well, as the 3 on the pass side may be gas fouled from the time it was run when the timing was off...
