437
Posts posted by GeneralDisorder
Always inspect/dress the input shaft and test fit the pilot to it prior to installing it in the flywheel. If you can get hold of an old input shaft from a 5 speed you can use it to make an alignment tool that's not a plastic POS.
Also - remove the dowel pins that get stuck in the engine and clean HALF of them. Put them back in the tranny with the clean side facing the engine. Also clean the dowel pin holes in the engine.
Last resort you can leave the pressure plate bolts loose and tighten them through the starter hole after it's mated. Not as easy on the EJ's as it is on the EA's but it is possible. If you know you are going to do this in advance you can add a half-round notch to the starter hole in the transmission bell-housing to leave room for your socket to engage the PP bolts easier.
I do SO many engine swaps that I have it down to a science. Three EJ25D to EJ22E swaps last month
GD
I disagree with all of this. A running, and not completely rusted-out AWD subaru starts at about $3k in this part of the world.
Key phase. Here they are worth virtually nothing. I have been GIVEN first gen Legacy's for free. No rust.
Also, I love the utility of a wagon, but a Legacy is much more heavy/bulky.Much more?!? A few hundered lbs maybe. The EA82 body is pretty heavy and bulky itself. And it's power to weight ratio is crap compared to an EJ platform. The additional weight of the Legacy, which is minor, is easily offset by the superior suspension, additional power without need for a costly engine swap, etc.
I think an EA82-body wagon, with a D/R PT4WD 5MT, a '96-'99 EJ22, and a decent trailer hitch is about the most versatile and reliable daily driver a person can have. I still regret selling mineTo each their own - but the value of an engine-swapped EA is not recoverable unless it's one of the three body styles I mentioned above. No one is going to pay what you have into the car if you EJ swap a Loyale body wagon. Just not going to happen.
Perhaps I'm unique or one of the few - but being that I am a mechanic - my goal as far as vehicles goes is to never have more into something than I could sell it for. So far I have NEVER lost money on a car - not on one single occasion. And that's including the ones I personally drive. They have all been fabulous deals I guess.... or I'm just lucky.... or perhaps my recipe is a good one
GD
If they cut the friction surface but not the PP mounting surface then it could have easily caused it to slip prematurely.
I use exclusively Exedy clutch kits - because they are OEM. I have an Exedy WRX kit in my '91 SS right now. Works great. I've got customers with near 100k on clutches I've replaced....
GD
Just go to the junk yard, grab a good plug, and solder it in - grab 3 or 4 inches of wire with the used plug and cut the old one off as close to the plug as possible. These don't often fail unless the plug has been damaged from someone tugging on it, etc.
I knew you would likely find a wiring fault in the engine bay. Just a matter of which sensor has the bad wiring...
GD
RTV is a gasket replacement technology. You don't often use both RTV and paper gasket.
Personally I dislike RTV. Anearobic flange sealanth (loctite 518) is my preferance for water pump and EA thermostat housings, etc. EJ oil pumps also. You don't need much - 1/16" bead.
GD
The distributor is hooked up wrong. The red sheathed wire goes to the + terminal of the coil. The yellow sheathed wire goes to the - terminal of the coil. Leave the wires that are coming from "cable Z" alone - those are correct. Disconnect everything else except those two wires from cable Z and the two from the distributor - after you correct their placement. Then it should run.
GD
Measure the flywheel step.
GD
Not worth replaceing the HG's on the 2.2. Most of them go their entire life (usually about ~350k to 500k) without blowing them.
In the Subaru world, Head bolts are never replaced..... NEVER.
Find a recycler and get a known good runner with compression numbers, etc for $400 to $600 and call it good.
What are you swapping the EJ into?
GD
Easily more than the cost of a first generation legacy that runs and looks nice.
Loyale.... not worth it. EJ swaps are best suited for purpose built race or off road vehicles, or people that have lots of time, extra money, and are just doing it for the hobby or for the novelty of it.
My opinion of course - but the only EA bodies worthy of an EJ swap are the EA81 hatch, the Brat, and the EA82 three door coupe/RX.
In the case of the EA81 hatch it is the lightest and shortest of the EA bodies and therefore makes the best platform for lifting and off-roading.
In the case of the Brat - it's a collectible and they are worth significantly more than any other EA body. Thus an EJ swap that's done right will make them more road-worthy for years to come and can be the answer for putting them back on the road as EA81's are becoming harder to come by.
The RX and the three-door-coupe body is an interesting and unique body style and has the potential to be an '80s collectible.
But if you just want a more powerful wagon.... forget it. Your just burning money. Buy a first gen Legacy, lift it, and be done.
GD
Yes the Aisin pumps are great. They are the OEM for Toyota and some other's - and they may be the OEM for Subaru on the newer stuff. NPW is my second choice - that's short for Nissan Pump Manufacturing. They are also Japanese pumps and of excellent quality.
GD
The fuel line is simply a hose over a barb fitting at the engine and at the engine bay mounted fuel filter. Take the lines loose from the fuel filter and put the gauge there - rent or borrow a gauge.
It's not a wonderful job to replace a fuel pump. Besides that - an excuse to buy or learn to use a new tool should always be priority.
Your problem isn't the pump and all you will get is frustrated by throwing parts at this problem.
GD
Had one of these fail at about 5k miles. Massive leakage from the weep hole. Customer paid no attention to the temp gauge and destroyed the motor - ran it without coolant down the freeway till it wouldn't run any more....
http://www.olympiaautoparts.com/products.html
This was included in one of the Mizumoauto kits from ebay. The kits seem to be fine otherwise but these cheap pumps from Singapore are hit and miss it seems. If you buy their kit get it with the Aisin water pump.
GD
McMaster has end mills for about $30:
3056A24 - $27.90
That's a four flute, center cutting, HSS endmill that will punch out the holes on a drill press in about 15 minutes.
GD
I'd like to think we aren't "rigid", but I suppose you're right: stock engines are what our customers are looking for when they come to us.
If you wanted to get into other types of builds - just register a new business name and build them alongside what you build now. Of course - with something like that you would want to test out the engines and see what they can do, etc. A lot of businesses do that - Rockford constant velocity has RCV Performance - their "custom" division - for example.
What exactly are you not fond of about the frankenmotor build? It's cheap, reliable performance. I call that "fun". With a good used 2.5 block you can put one together for a few hundered $. It's a lot cheaper and more accesible than the turbo's and opens up the hobby to a lot of people that otherwise wouldn't be able to afford it.
GD
The one in Renob123's Brat that lives here in my garage pulls HARD from 1200 up. Delta torque cams with hydro lifters.
GD
Yeah - you don't have the coil wires hooked up right I don't think. It's hard to tell what's going on with so many wires. There's usually 4 wires total - sometimes 5. Tach and distributor trigger on the negative, and then switched power and distributor power on the positive. And then sometimes a noise condensor thrown in.... but you don't need that except for radio interferance on the AM band.
GD
Check the fuel pressure if you suspect the pump. It is higly unlikely given your symptoms though. Fuel pumps generally either work or they do not work. It is relatively rare for fuel pumps to put out low pressure intermittantly.
Guessing will not help. Test. Verify. Replace.
GD
I'm glad it works for you. But, if we tried a technique like that on any of our engines, our customers would refuse to do business with us, especially dealers.
Your business is supplying stock engines without thinking outside the box. That's fine. Ivan and people like myself supply what each individual wants and we are open to alternatives and improvements in design as well as custom builds. It's a fundamentally different kind of business. We do things you and the dealers will not do. Would you build a 2.5/2.2 hybrid for your customers? Or a 255/257 with 205/25D heads? I doubt it. Your business model is too rigid and inflexible to handle that much out of the box.
Anyway I highly doubt it would cause either an increase in oil consumption or any structural damage to the piston.
I for one plan to give this a try if I can find the equipment or a machinist that has it.
GD
the shifter is worked out and on its way
Been waiting for that! No worries - we are patient folk. :-p
GD
No iron sleeves in a Subaru block as far as I know.
All Subaru blocks are sleeved. They are cast in place ductile iron sleeves.
GD
Mask what problem? The ECU is looking for a 35 Ohm load - be that a solenoid or a resistor..... Though you will need about a 10 watt resistor at least to fake it with. I used a 5 watt last time and it eventually burned out. The ECU just wants something to turn on and off. Doesn't care what that something is.
GD
Not even on Sunday.
GD
Loyale EJ swap
Posted
Legacy:
4110 - 810 = 3300
GL wagon:
3430 - 810 = 2620
So about 700 lbs difference.
Brat:
3460 - 850 = 2610
EA81 hatch:
3220 - 810 = 2410
Over 200 lbs lighter than either the Brat or the GL... and there's actually interior that can be removed and tossed in the hatch where the Brat has only the bare metal of the bed.... Also 5" shorter wheel-base and no overhang past the rear wheel.....
These numbers are only off the vehicle's data plate though. I've weighed Brat's at scrap metal scales, etc and seen them tip out at 2250 empty except for myself.... so I don't really put much faith in these numbers.
GD
