2
Posts posted by 1000 Pistes
I would like to know if I could use the first generation FWD Impreza gearbox, with the EA71 fat case engine.
Furthermore what kind of FWD 5speed gearbox I could using with the EA71 fat case.
The gearbox codes of the FWD Impeza????
I am searching to know where it was as standard equippment gearbox as following:
5 speed.top starter,with 3.7 CWP,
to "build",then,the desired gear ratios.
Any advice and knowledge welcomed.
I would like to "build"some 5GM with 3.7 for competition use.
This is the reason I am looking to find the right 5GM one.
thanks moosens.
only this 5speed gearbox is equipped with the 3.7 ???
what other models are equipped with 5speed with 3.7 CWP ????
the "5GM" is sticked on the gearbox ???
where exactly on the bellhousing is appeared the code ???
this one,you mentioned above,came from what model ???
I would like to know the code of the gearbox as the title,as well as in what cars was standard equipment.
Mine are standard Jap import 101hp EA81 dual carb motor carbs, in other words Craptachi's. I've got some IDF 36's to go on, just need to make a new set of intake manifolds which I really should get around to soon as my car bearly drives atm when cold and not to great when warm.
A single weber is better then dual hitachi's IMO.
any progress on quad carb(IDF) heads(EA71)???
I think the photo of the secret bits is the key , put together with a few comments by a rally fabricator I had fix my bullbar, many years ago. Brian was a Kiwi, and in the workshop of a big time Aussie rally champ. He told me that back in the day of the EA81 Subaru sold a 4WD sedan in NZ, but not here in Oz ( must be our better roads ) and he addedd that Subaru sold a kit to end up with twin webers mounted directly over the heads. Guess that is the head in the picture of parts - a 4 port head for EA81 - a performance enhancement over their already sought after now EX IN IN EX arranged EA81S twin Hitachi engine.
Man, a four port head on an EA81S, or any EA81 would be a snorting beast, maybe impossible to drive daily in traffic ??
Someone get onto a Chinese based foundry to make new ones ! !!
Any news about this Chinese operation ????
I would like to know if I could rebore the EA61 liners to accept bigger pistons as well as how much.
OK Leeroy.
When I''ll start the restoration I'll open a thread.
I am looking for cosmetic exterior parts(winscreen gaskets-nickel trims,door glass rubbers,exterior nickels,etc).
Hello,
Welcome to the forum....
I have got some1973 DL 4door Sedan too...
This time I am looking for doors glass rubbers and all over doors and below the doors nickel trims..
If I could offer to you of any assistance,I'll be here.
To be noted that I am located in Greece-Europe !!!!!
Let me know,please,if your GL is 4door or 2door sedan as well as if it is equipped with brake rotors on the front wheels or with drums.
I am looking for doors glass seals as well as for the over the doors and below the doors nickel trims for the 1973 4door DL Sedan.
How,also, about the onto the windscreens seals nickel trim?
Any advice welcomed.
hello,
I am looking (for my 73 4door DL Sedan) door window seals,too.
I am looking,also,for the all over the doors nickel trims(I don't know how exactly they called)and for the below the doors nickel trims...
any pictures of the cars?????
nice car...
nice work....
more pictures?????
- 1
Is it possible to bolt, directly,the EA81 heads on the EA71 block????
I saw some picture with some EA81 engine with EFI(MPi) system(with 4 separate fuel injectors).
Is it factory equipment of modified ????
Is this modifying possible to the EA71 heads????
what brake fluid exactly must be used in the ff1 brake system?????
What about the other blue ff1 project????
Any progress????
hello,
You beleave that these modifification could be done on the EA 71,EA 61 and EA 63 heads,too?
You are thinking to weld,on the heads, alloy tubes?
The angle of the welded alloy tubes it is important for the easy change of the spark plugs
Sure , as I get the chance I will.
OK,thank you....
You DO NOT want an EA63
EA71 , for sure.
Good luck.
OK,thank you .
Could you,please,to let me know if you have got some manuals,etc in pdf form,concerning the ff1 and the first generation of LEONEs ?
It could be very useful to me.
Where have you found your information on the Leones so far? Do you have documents? I'd like to try to cross-reference with some Baja racing setups.
Let me know if you would like knowing something about tthe old SUBARUs FIA homologation forms to pm you.it.
EA71 fat case with FWD Impreza transmission
in Historic Subaru Forum: 50's thru 70's
Posted · Edited by 1000 Pistes
Is it possible to fit the transmission(gearbox)of the EJ15- EJ16-EJ18 FWD to the fat case EA71????
Where I could find this EA-EJ adaptor????
