2
Posts posted by 1000 Pistes
Only those, EA 63 type, was equipped with 5speed gearbox?
Some other with EA 71 engine compatible?
what type of 5speed gearbox(from what model) I could mount on the eA 71 engine,always for FWD car?
Subaru GSubaru GSubaru G
- 1
I would like to build an EA 71 rally engine for competition use in VHC.
To be noted that accordingly to the F.I.A. homologation form of the Leone of 70s(A22L,A31L,A32L,A33L,A26L)are permitted only the EA 63 and EA 71 engines.
Because of those types of engine are very rare,here in Greece,I would like to collect all possible infos,experiences,suggestions,etc, before starting building it.
I have in mind to machining the intake ports of the heads to accept twin WEBER carbs,one twin on each head.
I would like to know,also,if the EA 63 heads are most preffered than those of the EA 71 ones.
Furthermore I would like to know in what models I could find 5gear gearbox,compatible with the EA 71 engine.
In the F.I.A. homologation form of the time I saw that there is 5gear gearbox with the following ratios:
1st : 3.31 (43/13)
2nd : 2.53 (38/15)
3rd : 1.96 (45/23)
4th : 1.52 (41/27)
5th : 1.03 (35/34)
and final drive(CWP) : 4.13 (33/8).
Could i found those ratios in some model?
This car in NZ has the EA71 engine?
I would like to know the way I could mount the twin WEBERs on the heads.
These heads are special heads or could modyfying some original heads to do it?
Factory Twin Carb Subaru EA Engines were available on both the EA71 (1600) and EA81 (1800), Both engines were defined by a following "S" at the end on their engine codes. This was Subaru's way of calling it the Sports model. The engines were a completely different design to the standard models. The "S" models had Dual Ports and Opposite Valve configuration, which means different cams and rocker gear.
They were available in Japan in the Subaru Leone GSR and in the later RX Models. These engines has Higher Compression Ratio and had ~10% more power output. They were used heavily in the late 70s and early 80s Rally cars.
Do you Mean like This? (this is an EA71):
I've seen such conversions, even done to EJ engines:
Usually done for VolksWagens
Yes!
Yes, it is this:
And this are Photos of the Car on the 1983 Safari Rally Race:
When Subaru Developed that Head-Mounted Twin downdraft Weber Carb EA81 engine with Reversed Valves, they already had the Turbo EFi Technology, so very Few of those were made, since Subaru started to sell the "Turbo Traction" Models in the same 1983 year...
But very Few Twin Weber Carb Models were Available for Sale, mainly in Japan and New Zealand,
like This one, which was for sale some months ago:
I'll Love to Own one of those Later Twin Carb RX!
Kind Regards.
Hello mate,
Would you,please,to pass me photos(and other infos) from the EA engines with twin carbs,mainly WEBER?
I have in mind to make an EA71 engine with twin carbs,for rally use.
Any other advice concerning special parts for more power is welcomed.
"Making a safe car that is fun to drive”Improving enjoyment by adding safety.
“In an age where cars are more common and people who don’t drive become the exception, it is imperative that safety issues are not overlooked. Safety testing methods are sure to evolve and in the near future we may even develop cars that can drive themselves. However, I really would feel sad if people lost the enjoyment that you can get from driving. If the focus of such advancement is limited to safety and the car is totally controlled by computer, car lovers would never feel satisfied. I believe that the second generation Leone has achieved a high level of both primary and secondary safety and I hope that this car can deliver the enjoyment of driving freely.”
Mr. Horiguchi realized that no matter how much you focus on safety, you must never forget the feeling the owner will get when driving. From now on, we hope to continue the spirit and enthusiasm of these engineers to create cars that allow the driver to experience the enjoyment of safe driving.
Extract from Cartopia Vol. 89 (Issued September 2nd 1979)
Did you know someone by what model year and onwards, fitted 5-speed gearbox on the EA63 & EA71 engine types.
I would like to know,also,if this 5 speed gearbox could fitted on both the engines as above,as well as the ratios of this gearbox.
To be noted that I am looking infos(and ratios) about all possible 5speed gearboxes could fitted on EA63 & EA71 engines
The horsepower of the engine of the normal ff1-G 1300 was 80 PS for 685kg of body,in 1971 !!!!!
The one of the REAL G Sports Sedan was over 90 PS !!!!!!!! -
where I could find some intake manifold for twin WEBER carb?
hello,
thank you for your reply.
I see that you coudn't help me.
First take a look at the thin vacuum hose(from the advance regurator,on the dizzy,to the intake manifold) if it is broken,then you have to adjust the firing advance(by turning the dizzy left or right).
Good luck....
How much could sell some perfect ff1 today???
Maybe this one was an up to 1976 model....
Nice car !!!!!!!
These fender extensions were original equipement or aftermarket??????
I would like to know which LEONE models of 70s, exactly,(VIN type,serial number,country,etc.) was equipped with the 5gear gearbox with the ratios as following:
1st : 3.31 43/13
2nd : 2.53 38/15
3rd : 1.96 45/23
4th : 1.52 41/27
5th : 1.03 35/34
and final drive : 4.13 33/8
No reply ???????
What model,exactly,was equiped with front inboard discs?????
Do you have got some pictures????
What spares are disponible????
Have you ever seen,in the USA or elswhere,ff1s with front inboard disc brakes?????
Hello mate,
I am looking for the ff1 parts book or pdf.
Let me know,please,if you could help me....
What about the progress on the blue ff1 project ???????
I am looking for a website with OEM parts for the SUBARU ff1-STAR(1968-1971) and the DL-Leone (1972-1979).
Making Love In A Subaru !!!!!!!!!!!!!!!!!!!!!!!!!!!!
Could you,Subie Gal,to let me know the way you fabricated the front valance???
EA 71. Building a rally engine and gearbox. I need some help.
in Historic Subaru Forum: 50's thru 70's
Posted
Some other 5speed gearbox coming from the late(after the 1979) Leones,to be compatible with the EA 71 engine?
