Everything posted by elgigante
miata coilovers on wagon
So do the fronts fit aswell?
Perfect, so how come everyone resorts to subaru legacy coilovers when miata ones can be found for way cheaper
Saw that miata struts work on the Subaru gl. Will rear coilovers work?
finally fixed my wagon!
As some of you know I been blowing up this forum with countless help threads. Thanks everyone who helped especially "jonno" I traded the car for a flat screen tv I won in a raffle and $250. When I went to go look at the car it was sitting in a field. The turbo was off, along with all the vacuum lines. The only way I could figure this all out was wait for a rx to show up in a pick n pull and take pictures. Finally one showed uo in chico,ca. Got all my vacuum hoses correct and snagged a few parts. After getting everything hooked up and having no information on this motor besides having the previous owner tell me the head gaskets were changed and "good luck" everytime I would drive the car it would fall straight on its rump roast. Rev to about 2500 and then drop rpms. I figured id try seafoaming the car. This is when my engine bay started smoking. I had an exhaust leak! Ordered some exhaust manifold gaskets and bang! The car was 10x quiter and would actually drive! Boost leak was my issue. Now I just need to figure out why my cel will sometimes come on until I hit the throttle a little. Im thinking knock sensor?
single wire 02 on 3 plug heated 02
Would running a single wire non heated 02 sensor (universal) work on my 3 plug ea82? I understand I have to splice but will I get a code?
idle jump at steady rpm
Also no vacuum leaks and recently changed intake manifold gaskets Could the culprit be knock sensor or 02?
I desperately need help. If I hold my car at a steady idle of about 2500 it will drop down about 100rpm then go back to 2500. Just changed spark plugs and gapped to 1.1mm also put a new dist cap. The idle is also very low. When I drive once it gets past the 2500 mark its a sudden burst of power. Car is mpfi ea82t
88 gl, 5 speed transmission fluid
Car is a 5 speed transmission with a button for 4wd. Is there only one dipstick? Also what weight fluid? Capacity? Etc
2 plug tps? mpfi ea82
so how do I go about multimetering this thing out?
ea82 wheen should I be boosting
Any help?
Purchasing first GL/Loyale
Ill sell you mine for $800 located in sacramento. Same car, but 88 5 speed 4wd, still turbo
Thats confusing, you have pictures?
Yea how would I hook it back up? The straight part to turbo? Bottom to waste gate? Back of the solenoid to the vacuum on manifold
I have the wastegate connected to the turbo it self as I saw on a rx when I went to pick n pull, is this not correct? Or should I connect the waste gate duty supply? And if I do connect it will this help?
Never drove a ea82 until I purchased one. I dont know how they run when running good. When driving on the highway when I get to about 4k the car feels like boost kicked in. Is this right? Also sometimes the green turbo light will stay on until I punch the throttle. I thought it only goes on when im boosting
EA82 Idle Air Control Valve
for the mpfi guys: http://www.youtube.com/watch?v=IgJUVW4SUJI
California Car...
My 88 wagon ea82t does not have a egr valve. But has egr solenoid.
I got a rx tps. Its a 3 plug. Could I make this work?
85 rx come turbo?
Just got back. Snagged a few things.
Hey thanks, kinda confusing though, to me it says you can use a spider tps, but then you cant. Am I reading this right? "To make this style work with a Spider TPS you just need to combine the 2 ground wires(or just cut ff one of them, since they are already combined further up the harness) and match the remaining 3 to their respective pins(power, signal, Idle) on the Spider TPS. As far as using a Spider TPS with the older type, I can't see how it would work. The old style is not a potentiometer"
So I need help on how to dial this two plug tps in. Mine has two wires going to the tps (room for 2) then a plug with three wires. Anyhelp? And is there any way to mod a different tps to this car as I cannot find one anywhere
Don't use A/C, can I take off the belt permanently?
I took mine off. My ac is on the outer side. It made it run smoother and more quiet
