Everything posted by moshem74
PVC valve - i need help.
hi. 1). does the pvc valve is taking the fresh air into the engine or out? 2). can i connect PVC valve of other kind of subaru if its fit? like impreza? i have a new PVC valve of impreza , and i chacked and it's the same size, and i can connect it insted the old one that i have now. 3). i disconnected the lines that comes from the 2 head's of the engine(each side) and connect each line to an small open filter, now, i disconnect also the line of the PVC valve from the air cleaner box and i don't know what to connect to it in it's end, does a normal fuel filter will be good for that and,if the PVC valve takes the oil gass out, it will distroy the fuel filter no? do i have to connect something in it's end? does the fuel filter will do dhe job? or i have to buy another small open air filter? can i leave it without nothing in it's end? the car is subaru leone auto 1993. thank you all for your fast answer. moshe.
battery question
hi. look, if you changing the alternator to a new one, and your battery is old or not in good condition, the new alternator will damage very fast because whan the battery it's not good,the alternator will make the oposit charge that he sephose to do,so if you changing the alternator, you have to chack your battery that need to be in perfect condition. dead battery would damage the alternator.
vacum unit or someting alse - pic's - pleas i need help.
now everything is clear. thank you very much for the information. moshe.
how much fuel pressure should be?
got it. o.k. thanks. moshe.
can i take this thing out ? or to leave it the way it is? why it's there? can someone know? thank you all. moshe.
msd ignition
hi i have the : http://www.msdignition.com/ Simple to install with no cutting or disconnecting wires. Powerful capacitive discharge sparks improve combustion for increased performance. Diagnostic LED confirms operation at a glance. Models for most any application from distributors, to coil packs and individual coils per cylinder. MSD Stacker Ignition, PN 7000 The MSD Stacker Ignition Control features MSD’s powerful multiple sparking, CD circuitry in a compact housing that is easy to install. The Stacker connects to your vehicle’s wiring without disconnecting anything! Actually, the factory ignition remains in place and the Stacker delivers a powerful CD spark to improve the initial ionization of the plug gap to improve combustion in the cylinder. The two spark profiles work together to give you a great boost in ignition power in an economical ignition control. Plus, since the Stacker “piggyback’s” the factory ignition wiring the ECU continues to see the factory ignition signals so there will be no check engine lights or tachometer problems. Stacker Ignition, Single Channel, Distributors PN 7000 For 4, 6 or 8-cylinder engines with a distributor, points or electronic. *Not recommended for certain Ford Escort|Focus|Escape models. Please call our Tech Line for more details 915-855-7123. OPERATING SPECIFICATIONS FOR STACKER IGNITION Operating Voltage: 10-18VCurrent Requirements: 1A per 1000 RPMRPM Range: 15,000 RPMSpark Duration: 20° Crankshaft RotationEnergy Output Max: 120 mJ 250VWeight and Size: 2.25 lbs, 6"Lx3.5"Wx1.75"HVoltage Output Max: 250 VoltsEXECUTIVE ORDERD-40-36 Stacker Ignition, Single Channel, Distributors PN 7000 + strong coil with MSD wires + iredium sparkplugs. i want to add or change other things for better performance in my car. can someone tell me or send me please information about what can i add or change . what will fit to my car if so. i'm talking here just about electrice parts, ignition system and other . thank you for your fast answer. moshe mina. the car is: subaru leone 1600cc year 1989 carborator with automatic transmission. thank you .
Oil Catch Tank
hi does anyone know how can i make a DIY oil catch tank? i disconnect the 2 lines from the valve covers ,that will go to the open air , and also close the lines on the air filter box. do i need to connect something to the lines that comes from the valve covers, or just to leave them like this without connecting them to nothing? thank you. moshe.
transmission shift mecahanism problem
hi thank you, i asked some friends, it sephose to be like this, i don't know why i tought it does'nt. moshe.
hi today i realize in the first time with my car, whan the engine it's off, i got out and push the car a little forword to my yard,i found out that i can push the car forword or backword even whan the gear not just on N ,even when the gear is on D or in R ,i can still push it , how can it be? whan it's on P , i can't do it but, if i'll move it to D or R , i can push it like it was on N..... how can it be? whats wrong? can anyone please halp me with that... can it damage other things in the transmission if i'll leave it like this? thank you all. moshe.
ground wire , automatic transmision to body.
hi i had a problem with the automatic transmision , i took the governer out ,fix something, put it back with 3 new screw's, before i took it out all the 3 screw were half open, the screw were damage, i replace them with 3 new one's, close the governer with black silicon, put the new screw's and close it well. before i did it , there were a wire that connect to the body ,and the other side to the governer screw. i moved this wire that is connecting now to the engine and the other side stay connected to the body, i did it because the old screw damage and this wire take place and the new screw won't close well with it . is it o.k. that the automatic transmision without a ground wire? can i leave it this way , or it's critical and it's better to make a new wire and connect it again from the body to a place that i can hold it on the gear? thank you all for your fast answer moshe.
o.k. thats what i'm gone do . and another thing: can i take out the fuel filter that is under the car in the back? it's connecting before the fuel pamp, mabe it's there because it wont let the rust to go in to the fuel pump and damage it, mabe it's better to leave the originat fuel filter in his place??? thank you for your fast answer. moshe.
4" Super-red Air Intake Filter
hi i got this air filter to my subaru leone. http://www.andale.com/stores/sf_itemHome.jsp?foo=bar&sid=226101&cid=12996316&lid=92400499&mode=1&catId=1356783&parentCatId=1299729 can someone tell me plaese how can i connect it ,i have an 4" pipe and the stoke air filter box, i just dont know where is the best location for it. if someone have pic's it will be great. thank you all. moshe.
hi if the fuel pressure should be from 3psi to 8 psi , it's mean that it's better to have 8 pssi all the time or what? if i connect fuel pressure reguator before the carborator, how much pressure i need to adjest it? thank you. moshe.
why we have on the back window plastik for?
subaru leone year 93 1600cc. back window ,2 side's have black plastic, not in the car - from outside. thank you all moshe.
why we have on the back window plastik for? on the back window on 2 sides of the window , there are black plastik. does anyone know what it for? why do i need them? can i take them out? moshe.
and if i have filter king - its a filter regulator that connect on the line before the carb, can i connect it? i can change the regulator fuel from 1 to 5 PSI, in weber carb , they say that max should be 5 psi, never more than 5 psi. i want to know if the stronger is better? if its from 3 to 8 on carborator than 8psi its better to have all the time no? can i connect this malfasi fuel filter regulator and leave it on 4 psi? i have this fuel pump for better performance: P/N 99009.131 Electric Fuel Pump and i want to know if i can connect this one on the line and adjest it 4 psi: 99901.419 Filter King adjustable fuel pressure regulator and fuel filter http://www.piercemanifolds.com/linkage.htm http://www.freewebtown.com/adventures/fuelpressreg.htm thank you all . moshe.
how much fuel pressure in PSI should be before the carborator in subaru leone 1600cc? does anyone knows? thank you for your fast answer. moshe.
cooler subaru leone ,oil transmision to radiator
It Does'nt Matter For Shour? Can I Connect It Where Ever I Want ? Thank You Moshe.
hi one line (the blue one) connect to the vacum with T connector. the middle pipe connecting to the engine upper part. low pipe doesnt connect to no where. this part works like this: whan the vacum is normal - all the lines are close. whan the vacum is high(whan you press the gas) this part have inside it diafragma that let the lines open,whan the vacum is high, its open the line and let the gases from the engine upper part , to go out to the air - it has a pipe that goes under the car. now , why do i need this part for? do my engine will work better without it? i can close the vacum from the engine- the line that connect to this part , and let the line that connect to the engine - set it free to the air - that the gases can go out free all the time. everyone with subaru with carborator have this part on the side of the carb- near the battery. thank you all for your fast answer moshe.
hi now i dont see it. stupit pic's if you are the only one who saw it(wow ) maby you can tell better than me what is this mistery. moshe.
hi can someone tell me please how to connet the 2 pipes ,2 lines that come from the automatic transmision to the radiator(oil cooler), in all the subaru with automatic transmision there is in the radiator, a part of the radiator is an oil cooler for the gear, it has 2 pipes that go to the gear, how do i connect them?up on the radiator to up on the gear , or up on the radiator to down on the gear. i'm stuck with 2 pipes that i don't know how to connect them. please someone can look under the hood in his car and tell me, i dont know how to connect it. is it matter anyway? thank you for your fast answer. in haynes it doesnt say anything about it. thank you all. moshe.
spark plugs for EA82T
WWW.SPARKPLUGS.COM
Universal AUTOMATIC Black/Silver SHIFTER
hi maby someone can tell me if this part will fit to an automatic shift in subaru leone http://www.andale.com/stores/sf_itemHome.jsp?foo=bar&sid=226101&cid=12996316&lid=92455037&mode=1&catId=1356777&parentCatId=1356776 thank you. if someone have pic's of installing shift knob, i'll be happy to see...
here are some pic: http://www.carsforum.co.il/vb/attac...achmentid=20902 http://www.carsforum.co.il/vb/attac...achmentid=20903 http://www.carsforum.co.il/vb/attac...achmentid=20904 user name is: m&t password is: puchicho thank you all.
to much gear oil ....?
hi everyone that have subaru with automatic transmision can see where the pipes connect to.... if someone will open maby his hood ant let me know...i'll be very happy. i have also HAYNES book , but it does'nt show it. thanks.
