moshem74
Everything posted by moshem74
  1. hi http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7943332490&category=33704#ebayphotohosting does it fit to my 1993 subaru DL? if i'll take my steering wheel out and put this one that on ebay, it will work with no problems? thank you all for your fast answer. moshe.
  2. hi maby the vacum pipe is disconnect or maby it's a very old pipe and let some air to go out......change this pipe that connecting to the diafragma.
  3. hi can you scan the diagram of the fuel system that we will see it? does all subaru fuel tank have this filter? thank you.
  4. hi http://website.lineone.net/~da.cushman/misc/mannject.html is it good on any car or just on turbo cars? thank you. moshe.
  5. hi also there is another sprey coating, the same material here: this one have less sprey (300gram) cost a lot more: Dynashield Products: Dynashield Spray Can | Dynashield Jug | Dynashield Spray Gun 10.5 oz Dynashield Spray canContains one 10.5 oz of Dynashieldfor use on roofs, floors, behind trim panels, inside speaker enclosures and inside door pillars Part Number: # 12005 Name: Dynashield SprayCoverage: 4.0 ft2 (0.37 m2)Content volume: 10.5 oz (0.62 liters) Recommended Thickness: 0.070" (1.78 mm) Application: Use on roofs, floors, behind trim panels, inside speaker enclosures and inside door pillars Price:$19.95 US Retail Red denotes metric measurements i called them and asked them about this sprey and why it cost more then the other, they told me that it also a under coating but not the same material,it's a lot better, you need each one to each wheel, so i need 4 of them = 80$!!!.....i dont know if it true anyway.... i think the BONDO will do the job. moshe.
  6. hii dont have rusty areas at all on all over the car,i want to use it only for reducing noise thet comming from the road. thenk you. moshe.
  7. hi ondo rubberized under coating - wheel wells. if i'll use this sprey , on the wheel wells, it will help for deadens road sound? i saw this "bondo" sprey in the shop, it saied deadens sound wheel wells,reducing vibration nois ......provides an effective sound barrier.... is it that good ? it cost me 4$ each one = 510gram,for all 4 wheels , to sprey twice (it takes 8 hours to dry), let say i need 4 = 16$. is it wourth it? is someone use this materiel? thank you all for your fast answer. moshe.
  8. from what i heard, the stronger\higher pressure there is, the car ill go faster....so...i'm thinking, maby there is something i can do to make it higher\stronger...
  9. hi can i play with the vacum pressure, let say i want to make the pressure to be stronger or higer , is there something that i can change for it to make it stronger from what it is now thank you?
  10. if i want to do this "project", do i need to take out the carb from the engine ? thank you.
  11. hi i saw this upgeade in the hitachi carb: http://www.ultimatesubaru.org/forum/article.php?a=7 do i need to take out the carb from the engine or i can do it without disconnecting anything? can someone explain to me step by step what i should do after i take out the 3 screw's that holding the diafragm....? thank you all for your fast answer. moshe.
  12. hi subaru leone carbureted. after the fuel tank-after the fuel pump-after the fuel filter - there is something that called 2-WAY VALVE.....what is this thing for? (it's looks like a very small fuel filter that his inlet and outlet pipes are in the same side). also after this thing , there is something alse,it called FILLER TUBE ? what is the filler tube and why it's for? i saw in the haynes repair manual but it does'nt say what they are for. thank you all. moshe.
  13. thank you ,now i know what i have, i have in my subaru the EA71 engine, it's 1.6L auto. moshe.
  14. hi. can someone tell me please what are the difrent between subaru engine EA82 and EA71 ? thank you for your fast answer. moshe.
  15. hi it looks very very nice....tell me something, this paint will stay on the trim for long time, i mean, with the rain and the strong sun.....the color won't go away or wont change to lighter color? i also paint some parts on the car, i used primery grey color first and after i used white lack sprey(dulpli color) - white hige gloss finish,i painted it 2 times, it become very nice also but i dont know if it will stay like this for a long time.....after i saw your work, i'm thinking to paint the trim on my car with white, first primery and after lack white,does someone do that already and can tell me if it will stay like this for some years, or after some time it won't look nice... thank you for your fast answer. moshe.
  16. hi. i have haynes repair manual of subaru 1600&1800 1980 thru 1994. in this manual the engine type is OHC engine, so if someone knows what sparkplugs gap is the best for my 1600cc engine, it could help to hear enother opinion. thank you. moshe. and if someone know about enother good book for subaru leone, please write me the name,or the adrees so i can order it.
  17. hi why everyone in every shop tells me or 0.7mm or 0.9mm? from where they get their information? moshe.
  18. hi it's EA82. thank you.
  19. hi. what is the best oil for leone 93 ,carb, 1600cc in very good condition with 70,000 mile ? is the LM 10w40mos2, will be the best one that i can use, or there is something better? here is the LM 10w40mos2 : MoS2 LEICHTLAUF 10 W-40 HD The MoS2 anti-friction lubricant forms a high load-bearing film of lubricant on all friction and sliding surfaces. The MoS2-lubricant film reduces the resistance to friction and allows engines to run -- so they conserve more energy even under extreme conditions. MoS2 Energy Conserving guarantees: significantly less fuel and oil consumption. Significant wear reduction, fewer breakdowns and emergency lubrication properties. Stable to ageing and stable viscosity. Good cold-start behaviour and high operational reliability. Prevents sludge formation. Tested on catalytic converters and turbochargers. Operational area: Year-round oil for petrol and Diesel engi- nes with extra wear protection. Car manufacturer´s approval: API SH / EC / CF, API SJ / CF; ACEA A3-98 / B3-98 Basisöl entspricht: BMW Spezialöl, MB 229.1, VW 500.00 (1/97) Container ContentsPallet UnitPackaging UnitPart- No. 1 ltr 5 ltr 20 ltr 60 ltr 205 ltr 576 112 28 6 2 12 4 1 1 1 1091 1092 1089 1090 1094 thank you all for your fast answer. moshe.
  20. hiyes, i was wrong, I mean 0.7, 0.8, 0.9 or 1.4mm. it's imazing because no one knows for 100% what the sparkplugs gap should be. maby someone can help me? i've been told that for best performance i need to make it 0.7mm, is it true? what will make a small or bigger gap ? the car is leone 1600cc year 1993 with carb. thank you all. moshe.
  21. hi how much should be the spark plugs gap? in mm....7mm , 8mm or 9mm or 14mm? the car is subaru leone 160cc year 1993. in www.sparkplugs.com the gap it's 14mm???!!! so how much it should be and if i put bigger gap or smaller gap, what will haphand? what is the best for better performance? thank you all for your fast answer. moshe.
  22. very nice... moshe.
  23. hi i saw on some site's , "car dash cover" , something that you put on the dash, look nice in the pic's, does someone have a dash cover on subaru leone\loyale\dl\gl\brat dash? i want to know how it's gone look on subaru dash, if someone have pic's, it wiil be great. and also, what is the best material to use for the dash cover, how long it stay nice (with the sun and everything....) ? thank you all. moshe.
  24. hi i want to lower the nois from the fenderwells , front wheel's, how can i do that? is there any spray to use for it ? something that will reduse the noise? thank you. moshe.
  25. hi thank you all for your answers. i chacked today, i took out the PVC valve, i clean it and it's working great, also i chacked the impreza PVC valve, and it's look the same but , with the impreza valve, it can move air in or out, my PVC just air in,out it cant go-just one way. today i'm gone connect it back and also i'll use T connection to connect it with the left side line , and to an open small filter. it's better to put the open small filter near the PVC valve or near the engine head? it's make any difrent? thank you all. moshe.
