moshem74
Everything posted by moshem74
hi thanks. the camera it's not so good, also i made the pic's smaller, in real the car looks a lot better.
hi to all. i update my subi site. enjoy. www.subaru4ever.hevre.co.il happy new year.
http://www.adverc.co.uk/products/batt/maxxima.asp http://www.adverc.co.uk/products/batteries.asp?app=-1&offset=120 are the maxxima batteries are the best for subaru loyale? they have 50AH with 900A Top Engine Start . are they good for subaru loyale? thank you all for your fast answer.
does anybody know this item , is it good thing to have ? http://cgi.ebay.com/SOLAR-PANEL-12-VOLT-BATTERY-CHARGER-CAR-TRUCK-BOAT-RV_W0QQitemZ5637018375QQcategoryZ14951QQrdZ1QQcmdZViewItem or this one: http://cgi.ebay.com/1-8W-Weatherproof-Solar-Car-Battery-Charger-Westfield_W0QQitemZ8015276751QQcategoryZ9895QQrdZ1QQcmdZViewItem thank you.
what do you have to say about my car = pic's
moshem74 replied to moshem74's topic in Old Gen.: 80's GL/DL/XT/Loyales...
most of it i made by my self. it has MSD ignition, 1800 carb,the engine is 1600cc. the interior i made by my self all of it. -
problem with the feul - leone 1.6 1993
moshem74 posted a topic in Old Gen.: 80's GL/DL/XT/Loyales...
hi to all. i have a problem with my leone 1.6 automatic year 1993. why whan im putting gaz in the fuel tank, all the fuel is comming out and i cant put fuel like i use to, i need to do it slowly,step by step, if not , all the fuel is comming out. i change the fuel tank cup and...no change. whats wrong with my car? -
hey... do you have a site to order good\profeshional sparkplugs cables to my leone 1600cc EA71 ? thank you.
hi and the loyale 1800 non turbo sparkplugs wires ....will it be the same as leone 1600cc? will it fit? if not , what car will be the same sparkplugs wires engths that will fit in my leone 1600cc carb ? thank you all.
hi to all. i'm looking for a spark plugs wires, but a good one 8mm or more... does the spark plugs wires of subaru leone 1600cc and subaru loyale 1800cc and subaru loyale 1800cc turbo, are the same? exacly the same...? i have leone 1600cc and i want to order from the net , spark plugs wires but they only have a set of loyale turbo...will it fit? thank you for your fast answer. moshe. also if someone hve a link from where to order....it will be nice.
Is this the idle screw?
moshem74 replied to Camelwagon's topic in Old Gen.: 80's GL/DL/XT/Loyales...
hi if you turn the car and close the right screw and the car will die, its ok because you close it, dont worry. look, you should let the car worm to its right temp , close the engine swich, close the right screw till the end and then open it 3-3.5 rounds, not more. now turn on the car and see if its shaking then close the left screw a little. the right screw should be 3-3.5 rounds open, after that, you should play only with the left screw. good luck. -
hi the right one is the air screw. the left one is the fuel screw. the right way to adjest it is to let the car worm up to the right temperatore and then, to close till the end the right screw(air) and to open it exacly 3 rounds and then to adjest the other screw(fuel), the left screw should adjest to 700-800 rpm in manuel or 800-900 in automatic. if you dont have a clock to see the RPM, then close it a little till the engine will be stady and not shacking...go for a ride and see if it o.k. good luck. -
hi let say i want to put new front seat in my loyala. what kind of seat will fit the best for my loyale with no problem,just taking out the old ones and put the new ones ? do i need to replace also the things that the seats are sitting on it? if yes, what will be the easy way + the 2 things that the seat's are sitting on. does legaci or impreza or other cars? i need information from someone how made it , before i'll go to buy it. thank you all for your fast answer. moshe.
this valve have 2 connction points, one up and one down, the upper is connecting to the fuel lines, the down is not conecting to no where. whan i mean broken, i mean = the down part of this 2 way valve its like missing par, just the down part of it, also i took it out and no fuel is there..... what do you say?
hi today i change my fuel filter and also i changed all the fuel lines under the car, all off them are new with new houses. now, i saw that i have something that is broken there, i put a pic from haynes loyale book, number 25 the haynes book saied its tow way valve...o.k. so....whay do i need it , should i buy a new one if it broken?, what is it? do i need it? i saw that this part is broken and also it have a line that come to it and secound line that going from this part is not connecting to nothing = to the open air, does it need to be this way? also my car is loyale carborator with no canister under the hood, maby this part is for canister only? can i take it out? what should i do with the line that come to it, should i close it? thank you for your fast answer. no one know what it is so....maby one here from the profeshional subaru will. thank you. moshe.
GAUGE-POD for subru loyale
hi you mean this one will fit? : http://cgi.ebay.com/ebaymotors/95-99-SUBARU-IMPREZA-BLACK-DUAL-GAUGE-POD-MOUNT-52mm_W0QQcmdZViewItemQQcategoryZ46100QQitemZ7989454935QQrdZ1QQsspagenameZWDVW -
hi i'm looking for GAUGE-POD for subru loyale, i want of 1 or 2 clocks, does anyone know what kind will fit the loyale the best? here is example of 3: http://cgi.ebay.com/ebaymotors/AUTOMETER-TRIPLE-PILLAR-GAUGE-POD-SUBARU-WRX-02-04_W0QQcmdZViewItemQQcategoryZ43951QQitemZ7988447872QQrdZ1 thank you all for your fast answer. moshe.
need your advice - coolant recovery tank loyale.
got it thank you all. -
hi i have subaru leone 1600cc automatic gear 3 speed , carburator, top speed 150 km\h , after 140km ..its take a while to go to 150...but i'm taking care of my subi ...like it was my lover...so i dont drive more then 100-110 km\h.
hi what is the best alarm system for the loyale? i want something good relaible and hard to breake. what is the best? clifford? viper? ......or something alse. also if you can give a link or something that i'll see how it looks like. also i saw at ebay a lot of car alarm system with biper or pager...like this one: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=5788303036&category=94833&rd=1 what company is it? is it wourth it? from what i saw, i think that this is the best of the best...but the price...ho...the price: look: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=7987324484&category=75329&ssPageName=WDVW&rd=1 or this one: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=5789951675&category=48611&ssPageName=WDVW&rd=1 thank you all. moshe.
