nicksubaru
Everything posted by nicksubaru
So im on about close to a $500 budget, ill do all work/labor myself so that's whatever, and ill get any special tools needed for the job. This car im planning on selling as soon as its fix. So i can't really change the pistons to the flat top ones or anything that reasonably dont need to be changed. That's why u was asking for a single kit or 2 kits, timing belt and headgasket. But it seems that the parts wont be in just one kit..
@GeneralDisorder. You are very helpful. Ive read alot of older posts from other things of yours. Keep up the good work. So if i were to cut the id to 1.385" then ill be good to go? What would be the best, easiest, cheapest way for an at home kinda guy to do that? Or.... What about other options like a Toyota or Nissan TOB? I just really need this car back together already lol
So i believe that there is a repair sleeve on this transmission... So now i have a new TOB (throw out bearing) that i cant use. And i have no idea out to pull off this sleeve. It is not like the repair sleeves ive looked up with the little screws on the sides. Its just pressed on or something. I found one repair kit with oversized TOB. But it was $160. The clutch kit was $230. Any idea if i sand down the inside of the TOB that i have to make it fit? Bad idea, or good idea? The sleeve thats on there now isnt in bad shape
So i when to put everything that i got together, put the new clutch in, put the motor back in and all that. 1st time for me....i didnt know that i needed to resurface my flywheel. So i cleaned it up myself and before i was going to take it to resurface it, i sew hair line cracks on it. I have a 92 legacy ej22 part car. And it had a lighter flywheel, looks a little bit different then the ej25 Flywheel just slightly. And the gear ring for the starter is in better shape. So my question is should i try to resurface the hairline crack ej25 Flywheel or resurface the "no cracks" ej22 out of the 92 legacy?
