Everything posted by subakev
I checked to places looking to get a compression gauge on loan and wasnt able to find one today. But I did get my check enginge light codes run. There were 3 codes that popped up: P0100 - MAF sensor or circuit malfunction P0400 - EGR Flow Malfunction P0400 "Exhaust Pending" Im not sure what that last part means
Just one plug, cylinder 4. It came right off, wasn't very sticky. I didn't drop it or anything. Maybe I it rubbed against something when I put it in or pulled it out and I didn't notice. I will check into the compression, I will have to look up how to do that. Also I should probably pull the plug in a few days and check it out too huh?
I picked up new wires a and regapped my plugs (they were way off!), next time I will gap them myself. The idle is still rough, running up and down, but no where near as bad as before. And now the check engine light is back on. But the car runs much better now, I was able to drive it around the block without and knocking, hesitation or stalling. It was also suggested that I clean my throttle body and that the injectors needed cleaning. I've got some lucas oil additive to help with the injectors. I've been told that cleaning the throttle body is typically easy enough, but it seems intimidating to me. I know that subarus are tricky to adjust the idle on, and I dont know if taking the the throttle body off to clean it will mess with that. what do you guys think? When i took out a plug there was some kind of crud on it. These plugs hadnt even run for 20 minutes before this
So first off let me say hello, and thanks for this informative site. Im not very experienced in working on my own cars. Ive in a bit of a money crunch these days ad have decided to do some basic stuff myself. I have a Haynes manual which seems to help. Ive succesfully changed the fuel filter and replaced a cracked fuel line. The engine has been running really rough, and cutting off in the middle of the road, especially at stop lights, etc. I took it to the shop for a diagnostic and they said the spark plugs were fouled and the engine was running on three cylinders. I got some new plugs from car quest and they made sure they were gapped there for me. Nice guys, they have offered me some good info before. I changed out the plugs out no problem (didnt use a tork wrench though). The car wouldnt start. I tinkered with the plugs and tightened them a bit and got it running. But the car runs rough still, revving up and down when in park. I took for a spin and it cut off, same as before. I double checked my haynes manual and it looks like I have the wrong plugs and the gap we set it to was wrong. I just wanted to get some opinions and see what people thought, is this the problem? I cant get back to the store to get new plugs for a bit. Im hoping that this will fix the problem though.
