Everything posted by cookie
Gen 1 or Gen 2?
cookie replied to J A Blazer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck the stick above to see if it helps but I am fairly sure Outbacks got the phase 2 in 2000. Check to see if the headgasket treatment has been added or gaskets changed. Other than that look for all the standard stuff you would check on a used car. A 2000 should be ready for major service by now and if it has not been done plan to spend quite a few dollars and time on the car.
Vibration in Legacy GT Wagon
cookie replied to KiwiGT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheers Kiwi, Hope it all goes well.Thanks for the lesson on Silverdale, must have been near it from time to time.
the sound of running water
cookie replied to paulo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRemind me to tell you about the time my friend became the Easter Bunny on those.
cookie replied to paulo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI imagine those drugs are pretty good.......
cookie replied to paulo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNip means the HVAC box. If you want to bleed the heater it is the usual water system.You fill it first and most cars have a little plug on the right side of the radiator you remove to bleed it. I have not seen the problem with the HVAC nip is speaking about, but I have seen a few folks who had air in the cooling system who complained about a runniing water sound.
bianders?
cookie replied to trav's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo idea what you mean by biander but it is a non interference engine and should run with another belt. Make sure the water pump and tensioners are ok because one of them may have failed taking out the belt. If you have the time and money the front seals would be good to do while it's apart.
cookie replied to KiwiGT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsecond the driveshaft shop. u joints like bearings tend to be standard sizes.
cookie replied to KiwiGT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhere is Silverdale? I have relatives in Queenstown, New Plymouth, and Auckland. If you can't get a Subi fixed in Kiwi I guess you can't get one fixed anywhere. Good luck and I would also look for a U joint as that seems cheapest.
Price for 05 Outback XT in AZ
cookie replied to skins's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI imagine nobody has been shopping there. you might try Kelly blue book or Nasioc and see if you can find a matchup.
Ignition Key Issue-- Help!
cookie replied to shysiren's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat's a common problem with all cars, after a few years and miles. I'd probably fiddle with it myself but a locksmith is a good idea.
WTK: Cheapest place to buy Cats for 2000 OB???
cookie replied to Green Beast's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMnay brands of car do have this behavior. My daily driver is a BMW so I always check the BMW boards. Before that I had a Mercedes. Cat problems, PO420, and changing the front ox sensor seems pretty common on a car over 100,000 miles, and many cars don't make that.
Forester thread, anyone?
cookie replied to MJJ's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've got a 99 too. 125,000 miles or so on it. It required major maintence around 90,000 but it seems like it's good to go for several years now.
Why no one talks about rebuilding a motor
cookie replied to zzzasy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've done quite a number myself where I did not change pistons. The limiting factor is really cylinder wall wear. A lot of these guys don't take the time to really check things properly. I've pulled apart engines that had stock size rings in an overbore. I had a good machinist for some years but he is retired now and I think it might be tough to find someone as good.
cookie replied to zzzasy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt may be different in your area Nip and folks are more sane, but most rebuilds here juat get a clean up bore and new pistons of whatever brand the rebuilder gets cheap. You can always pay extra or buy your own pistons. On my last rebuild I went 10 over and used genuine Mercedes piston and seals. That engine was better than it came from the factory.
Fuel pump relay and fuse location!? 1995 Legacy
cookie replied to TeamPSI's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI thought the green connector was supposed to be a test wire that should not be connected.
cookie replied to Green Beast's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI put a new front ox sensor on my 99 and it got rid of the code. The front one works the hardest so I tried that first. It has been a few months now and no more PO420, I guess I'll see how long this works.
Front 02Sensor Location on 2000 OBW
cookie replied to mwells's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOn my Forester you open the hood and look down on the passenger's side exhasut pipe. You can't quite see it but you can see the wires going to it. I just leaned down and changed it there, but I am in CA with little rust.
cookie replied to zzzasy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPrice it in your area, perhaps they will let you do some work around the shop also where you'd learn something as well as get the job done.
2004 piston slap? or only older models?
cookie replied to DMc-DE's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think they have been putting suspension in high speed rail wheels and working on sensors to tell when the track has a ripple. You aren't far off.
what does a piston slap sound like?
cookie replied to eventoday's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCold and how long it has had to drain back all the oil make a big difference in my 99 2.5. If I leave it a week it hammers quite loudly until warmed up and if it get in the high 30s here it is noisier. If I drive it after only sitting overnight in the 40s it only rattles for 30 seconds or so. I suspect if somebody had this car in Alaska it would really rattle until warm.
cookie replied to DMc-DE's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAh, now I see what you mean. I was not think of comparing it to the 2.2 it came from. It probably saved a lot of money not raising the deck as you could use all the same machinery. basically it is just a 2.2 with the typical hot rod tricks. I'm glad you got a famous amp back on the road where it belongs! I think an active wheel might very well work these days. They have done a lot of interesting things on trains you might look at.
speedo stopped
cookie replied to mulcheese's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhen cars go down the production line parts are often used until they are gone. This make for some interesting match ups when you have a car that is near the end or beginning of one model year. Somtimes it's really neat as the last 1967 Volvo wagons got the 144 engine and 144 seats.
cookie replied to DMc-DE's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI like your electronics idea Blitz, sign me up for the first prototype. As for the piston what did raising the piston top and wrist pin achive? Less friction? I have always assumed that they got the slap when they cut the skirt, but I've never seen the pistons side by side to compare.
How many Subaru owners have/live with piston slap?
cookie replied to jcole01108's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo piston slap is not the same as valve tap. Sometimes it's hard to tell the difference though. Piston slap is the psiton hitting the cylinder wall and valve tap is excessive clearance in the valve train. Anybody got a link to how it works for this person?
cookie replied to DMc-DE's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBlitz soon you will be able to put your skill in electronics to good use. As Subaru owners age a switch on the hearing aid would be very handy for this issue.
