Everything posted by cookie
Oversteer and Wobble
cookie replied to Chef's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA bit frustrating becuase one can't see or feel anything. In this case you have violated at least a couple of the usual rules. First never mix shocks and second remove all play and align a car after any major work. If I was young and low on cash I would try to align the car using old basic methods like tape measures and string. If I had nothing I would loosen the tie rods a turn at a time to spread the toe until I could drive it. Once in a while lowering tire pressure can help to make a diver driveable. Make sure the rear is not higher than the front as that ruins caster.
Help! Dead Outback
cookie replied to stephinator's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIts kind of hard to tell from your post. it sounded like a blown clutch until you said it stopped. Was the engine still running? I think you need to have someone you trust who knows cars look at it in person if possible.I wonder if you live near anyone on the board?
screeching brakes (02 impreza)
cookie replied to luca_brasi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI pull them all at least a couple of times a year. I measure wear on each brake and log the measurement in the chart in that car's file. I can pretty much tell you when I am going to need to change brakes on a car months ahead.
hopefully an air pocket on my 97 outback..
cookie replied to kents1stoutback's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you do a search you may find that some folks have limped by with no thermostat until they could fix it.How about just fixing the gasket on the blown side?
cookie replied to kents1stoutback's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSorry, it sounds like head gaskets to me.
2006 Legacy 2.5i SE VIN problems
cookie replied to Deserter's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy Insurance company had to be guided through insuring my BMW. According to them and CA DMV the model does not exist. There were only about 9,000 or so made so I can see they are not a priority. On my GTO CA DMV insists it is a Tempest. They have had since 1965 to get this right so perhaps they need a few more years. On the other hand in this case the car was registered cheaper for years so I can see not many would complain. Here you can go in person and show your reciept to prove what you paid so that is a plus. It's so time consuming that it has to be a fair amount of bucks to bother.
HELP 97 Legacy 2.2 blown head gaskets?!?!
cookie replied to SubiPilot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMoab, those have not been working 100% on slightly leaking subie gaskets. The good thing I have heard is that they don't give you a false positive. When the gasket is quite bad they get easy to find on all common tests.
Random overheating of 98 Forester
cookie replied to Top's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIts up to you but if it was my car I'd change the head gaskets and check all the other usual stuff like valves and oil seperator while it was out.
key wont turn
cookie replied to vanfajo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI am sure you tried stomping on the brake to in case it has an interlock.
Grettings
cookie replied to falcon7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYep my summer 25 was 22.44 today.
Loud engine tapping in idle 2.2L '93
cookie replied to illanrob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXProbably a lifter bled down.
trouble starting
cookie replied to scofomo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRun a jumper wire or a remote starter switch to the solenoid energizeing contact to test.
Gen1 Legacy: AWD, diffs and computers
cookie replied to SakoTGrimes's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA big 10-4 on that guy. Sometimes you even get dust on you changing a computer.
Buying a used Subaru - '02 and newer
cookie replied to BlueSkies's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIts a pain in the butt but many modern cars have piston slap. It tends to go away when warm. This is because of emissions regulations. Odds are pretty that is what you folks were hearing. If you go to Bob is the oil guy you can see my oil test where Blackstone labs says it is common and does not seem to hurt.
overheating again, and again
cookie replied to loonmobile's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGo to a dealer and get the glop and a sticker. Next week go to a dealer and ask if you are covered.
cookie replied to loonmobile's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAny chance the dealer will cover it on the extended warranty? That goes up to 100,000 miles on the head gaskets.
Anti lock questions
cookie replied to Joe719's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhen you hear the chattering and feel the brake pedal pulseing the ABS is working. It can't do miracles but it does make it a bit more likely to steer. One has to exercise caution on ice and begin to stop much furthur back.
"ridges" on cylinder head mating surfaces?
cookie replied to a97obw's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSure looks blown.
2000 OBW: Ext. HG Leak
cookie replied to the_bard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAnd it does seem that Subaru is stepping up to the plate this time.
Rear Brakes 97 OBW
cookie replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEverybody has thier favorites but I have used PBR deluxes the last few times and I quite like them. no squeak, low dust, no problem. I've fitted ceramics to a couple of cars but those belonged to friends so I don't really know the results. These are people who get a brake job when they have loud noises.
cookie replied to loonmobile's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt is rare for a phase 2 to blow a head gasket with an internal leak. Losing that hose could easily have done it though.
cookie replied to SubiPilot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNip, a lot of folks aren't clever enough to realize that you can use an emissions sniffer here. I was at a shop here in CA where a guy had the whole dyno outfit and the old type who did not realize he could use it for that.Of course here we are quite lucky if a mechanic speaks English...
impreza problems
cookie replied to seanski06's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXVery believeable to me.
impreza problems
cookie replied to seanski06's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGood point Nip.
impreza problems
cookie replied to seanski06's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNip is more patient than I am. I'd pop off the drive belt first and if the noise stopped I would be pretty sure it was in that system.
