cookie
Everything posted by cookie
Bob, Subaru's socket is pretty lousy and a few fires and a lot of short circuits have come from it. If you are going to go to the trouble to add one get a good socket from another car. I know the BMW one is fine becuase I have one of those. Heck any GM or Ford should ahve one too. All you need to do is drill a hole for the socket and run a heavy power line and fuse. If it were mine I would pick up power under the hood and run it back, but its your baby.
Code P0420
cookie replied to rugbyben's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
And seem to cost nearly as much. -
My Forester has about the same mileage. I figure the cats are borderline now and I knew oxegen sensors should be cahnged around 100,000 miles. I changed the front ox sensor and the light has stayed out for about a month. My light only came on when someting cooled the cats enough to throw off the efficiency.The real cure will probaly be to change at least the front cat, but if the light stays off for a few more months it might mean the oxegen sensor was enough to get by for a while. I am sure I don't have to tell you how much cheaper an oxegen sensor is that a cat.
Some of them are balanced together. Hint, when you remove a clutch or torque converter mark the postion with a scribe if you are going to reinstall the same unit.You know the balance was good before right? On busses we would start them up and run the engine with the tranny off and balance the clutch with washers.
H6 STi
cookie replied to Durania's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
The new corporate snout seems kind of a shame. I bet the B9 is a nice driving car too, but no car dressed for Halloween is ever going to be in my driveway. -
Fuse problem
cookie replied to olivo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
We can see if this link works. It is in the archives if it does not. http://www.endwrench.com/archive/syselec.html -
In the clear. The recall went to 2003 if I remember correctly. I have the post 2003 gaskets on mine now and I am not sure when they hit the production line. It does not matter much becuse if they think you could leak they will ask you to come in for the goop. If you add the goop you are warrented to 100,000 miles. I had mine replaced way before Subaru recognised the problem and they still paid me back on a second owner car way over the mileage.
Fuse problem
this is so common Subrau has issued a bulletin on it and posted it on Endwrench. -
One thing that can do that is a slightly worn cam that gets mated witha slightly worn follower. The adjustment can be fine at the top but wear on the ramp can make a tick and it will look OK.I had a tick on my Mercedes that made me near nuts until I pulled the cam and had it on the bench where I could see the worn spot.
Code P0420
I was thinking it was earlier than that. Great, this gives you a pretty good chance! -
I can't complain about the Michellins on my Forester. They seem to be called Weatherwise. I'm not even sure you can still get them as they are a few years old. The car has 122,000 miles and the first set lasted over 60,000 miles and were replaced after a tire was trashed on a cross country trip. These have been on the car ever since and still have way too much tread to change. They are fairly quiet and go very well in Tahoe's snow and the mud I see regulary this time of year.
