Everything posted by Downwash77
EA82 Help Asap
Yes 10×1.25 is correct, flange nuts are prefferable.
Clutch extension spring location
Hello does anyone know exactly where the extension spring, (that's helps pull the clutch fork back) connects to? Thanks
Help Me Choose Wheels...
I'd be torn between the alloy H and the white spoke wagons. The H alloys are very unique but you can't beat the rugged iconic look of the wagon wheels. The alloys are hard to come by they may never cross your path if you decide to change
Correct transmission mounts for 5 speed Swap
Hello, my brat came equipped with a 5 speed Duel range transmission. The transmission mounting was way to half rump roast form my liking, what is the correct way or configuration to do this? Any info would be helpfull thanks
EA81 crank pulley bolt RH or LH
Thanks the rope trick savedyou rump roast!
Thanks!
Is the front crank pulley bolt left or right hand, can't get it off with impact, don't know if I'm making it tighter. Thanks
How do you check for valve leakage with the heads off ?
Dump alcohol in the port sides, if it leaks through the valve is not sealing. In fair condition the valves hold wd40 without leaking though
5mt duel range clutch fork
Thanks all. I will order tonite
Hello, I need to replace the clutch fork on my 5mt duel range. The transmission is in a brat therefore I don't know the correct type or year to order the part for. I think 85 89 but I'm not positive. Thanks
5Mt duel range transmission identification
Thanks!! I will order one asap
I need to change the clutch in my brat that was equipped with a 5mt duel range.I don't know what clutch to order because I don't know what the transmission came out of, any thoughts, thanks
Second generation brush gaurd for sale in ct
The brush gaurd has been sold.
I have a second generation brush gaurd for sale $75 860 840 1005 for pics
Head gasket sealant
Looks lIke I will put felpro gaskets on and call it a day. Thanks all for your help
Head gasket sealant
It is so, according to subaru's literature ver Batem ( apply sealant "three bond 1201" or equivalent evenly to both sides of cylinder head gasket with a brush) .
Head gasket sealant
Head gasket sealant
My factory shop manual says to use sealant when replacing the head gaskets, it says to use tri bond or equivalent, what is the equivalent? Is sealant even nessacary? Thanks
Vinyl paint color for tan interior
Does anyone know the best paint brand match and color for ea81 tan interior. Thanks
32 36 webber carburator and ac install
Will a idle Boost be required with ac install with a aftermarket webber carburators. What is used as a idle stabilizer with stock carbs? Solinoid? Vacume diaphragm? Thanks
1987 GL Wagon 85K For Sale @ $2500. Q: Is it worth it?
If your just looking for a good reliable car, you can get something much newer for 2500. Sounds overpriced anyway it wouldn't be worth much more then 2500 in mint condition. I've been following older subaru values for years, so there is my two cents.
Door activated chime troubleshooting
The fact that the chime works with the key out indicates that the problem may be in the ignition switch. It seems the switch may not be turned back far enough but still releasing the key. My 01 and 83 do that intermittently. Try turning the key in the more off position if it's chiming when it's not so posed to. Removing the annoying noisemaker is also an option
Transmission swap options for ea81current 3at
Thank you very much.
Does anyone know the speed vs rpm in top gear for 4 speed duel range and also 5 speed duel range. Thanks
