Jg02legacy
  1. I have the exact problem on my 02 suby and have done everything bushwick just told ya and im still having the same problems it's bizarre it keeps on getting worst
  2. I have a 02 legacy and I am having the same problem and have done everything you did and its starting to be costly!! i am not having the fuel problems but i do not have a crack in my pipe doubt it has anything to do with it tho i am sure it is something electrical but plugging in the diagnostic machine is wayyy to expensive
  3. Crazy hesitation while driving? Any luck with finding the problem? Im in the same boat as you and im abkut to give up
  4. I switched motors on my 02 legacy L about three weeks ago and it seams like we are having similar problems with poor idle, i have to turn my car off at long redlights sometimes it may or may not have any relation but Im running a diagnostic with my mecanic later this afternoon i will let you know
  5. Thanks for the knowledge p0447 the purge valve is stuck open indeed it is the first code that appears once i clear all then re-scan
  6. I dont know honestly the reason why i havent changed it yet but the bank one is the o2 sensor code , i just swapped motors due to hard head gasket leaks and thinking the o2 maybe be gunked up with a mixture of oil and coolant
  7. I am having the exact problem with the heavy bogging... Did you ever find out the source of the problem???
  8. On idle, engine seams to completely want to stale because of boggs. also while driving down highway it seems like when i need to let go gas to reduce speed , when its time to finally give gas, i get wat i call " gas pedal kicks" seems to be a misfire p301 p302 p303 p304? I get the code p0172 too lean banc 1 (i know its the 02 sensor and have purchased one) after reading some older forums it seems like it wont make a difference? Im just looking for someone who had the same problem in the past to maybe shorten the spending spree i have changes plugs, wires, the coil, fuel filter and air filter no change, i also get po447 evap system valve open Any advice or knowledge????
  9. On idle, engine seams to completely want to stale because of boggs. also while driving down highway it seems like when i need to let go gas to reduce speed , when its time to finally give gas, i get wat i call " gas pedal kicks" seems to be a misfire p301 p302 p303 p304? I get the code p0172 too lean banc 1 (i know its the 02 sensor and have purchased one) after reading some older forums it seems like it wont make a difference? Im just looking for someone who had the same problem in the past to maybe shorten the spending spree i have changes plugs, wires, the coil, fuel filter and air filter no change, i also get po447 evap system valve open
