Everything posted by Al Zhiemer
Random oil burn/plug foul
It could be valve stem seals, usually the first sign is blue smoke on start up, unusual for valve stem seals to just collapse like that. Even when parked on a level surface, it should still blow some blue smoke. If its an intermittent issue, it may be worth popping the rocker covers off and checking that one of the valve stem seals hasn't moved the next time it happens. Have you tried parking the opposite way around to see if it affects both banks of cylinders? Does it do it when parked on any angle with the left side lower than the right? Has the engine got above normal operating temp? Cheers, Al
Threads wiped out on rear shock support, 1986/7 GL 2wd
Also check out Recoil Thread Repair kits, I prefer these over heli-coil. I find they give a far more secure thread when finished. Sound like they are very similar to the ones DaveT mentioned. They are a great spark plug repair if it ever strips out. Just make sure you have them seated properly because once they are in, they are there to stay. Learnt this the hard way. Cheers, Al
Bed Time Story... Third time lucky... I hope
And yeah, they came of a Toyota Hilux. Apparently they'd only been on there far a couple of weeks, which I could believe seeing the condition they are in but once again, its an unknown. Cheers, Al
@jono Have studied tyre sizes until I'm blue in the face. I'm looking for more of an off road tyre which means having to go bigger, will see how these Maxxis wear and ride like and work it out after that. If they prove to be ok and they keep bringing them into the country, I'll stay with this tyre combination as I really don't want to go any higher in lift or tyre size. Only time will tell. Cheers, Al
WOOHOOOO SCORE!!! Since deciding on eventually changing to 15" rims in the future, I decided to give up on the search for tyres for the time being but I did need something a little bit bigger as the 175/65X14 just weren't going to cut it anymore with the lift. Off to the wreckers this morning to find a descent set of tyres on the cheap. After searching the entire yard for anything that may have been suitable and finding nothing, I was about to give up hope of finding anything. Walking back out the gate, I noticed a little shed of to the side with tyres in it, never been in there and figured there probably isn't a thing in there for me, they all looked larger 16"-18" car tyres and 4WD tyres. Now, I'm fairly well known at the wreckers and pretty much well have free access to everywhere, in I went just out of curiosity for later reference more than anything else but low and behold... BINGO!!! Found a nice set of Maxxis 753 in a 185R14 size, almost brand new and manufactured in the 36th week of 2017 so still a new tyre and well with in date. For $150 and access to the tyre changing machine, I handed over my money and said I'll be back a little later. I knew these tyres were out there but avoided them because they are a light truck tyre, makes it a heavy tyre and usually a lot stiffer sidewalls which has its good points and bad but for $150, I'm pretty sure I can make do with them for awhile. Cheers, Al
Also, had a little epiphany this afternoon. I remembered this afternoon that the adapter plate that sits between the inlet manifold and the weber carbie is dodgey as. Won't mention the reputable company that I bought this from here but let me just say that I have notified them of a crap product, first one the threads stripped out of with minimum tension, second one the stud holes didn't line up and this one is well... Anyway, the problem is that if you don't position the adapter perfectly when fitting and make sure it doesn't shift when fitting the carbie, it leaks water. Pretty sure I got this right but stranger things have happened. The gasket also seems to be awfully moist as well, which is a little unusual and would explain why there is so much steam as its going into all 4 cylinders. Thinking I might need to check this before I go to far, really don't think its the problem but its worth a shot before I pull the motor out (I got side tracked on Sunday tearing down the other 2 motors I have). I dragged out the spark plug thread saver kit and have repaired that this afternoon so I can check the carbie fitment in the morning and give it another go. Fingers crossed. Cheers, Al
Don't even get me started on bloody tyres!!! If I had of known what I know now I would have just built a 3" lift and be done with it. It seems that it won't be long until 215/70 or 75X15 is going to be our only choice if we want a descent all terrain or mud tyre. Another reason I'm now glad I grabbed the 4.44's and stuck in the shed for later reference and all the more reason for an EJ swap. It seems the manufacturers at this stage aren't going to bring in any more 27" tyres, in the not to distant future, the Nankang all terrains will be our only choice (how long for is an unknown) and they are nothing more than a glorified road tyre as far as I'm concerned. The Kuhmo's are a very limited stock and reports are, they will no longer be bringing anymore in. We maybe able to do a group buy but I still don't think there would be enough of us wanting them to make it worth their while. @pease004Other than splitting the box, your choice would be custom made shafts. Custom shafts have good points and bad, these are the top of each for me. Good - You can get them made as strong or as week as you please, your options are only limited by the size of your bank account. Bad - Something goes wrong, it isn't a simple case of going to the local parts store and ordering an off the shelf unit and if you are in a remote area... That could be an issue. If I went custom shafts, I'd look at getting a spare made up at the same time just for those emergency situations. Especially if you are looking at travelling into remote areas. Cheers, Al
I'd like to build a similar box to yours, I could just get away with AWD for what I do but things can get pretty muddy around here pretty bloody quick and Rainbow Beach, Fraser Island are my playgrounds so I think still being able to have the 4WD option could be handy. And yes, putting in a front LSD is on the cards. A rear LSD would be great as well, will tackle that problem when I work out how to get the R180 rear diff I have sitting here mounted in to Ruby. I haven't had a close inspection of the two diffs side by side yet, there doesn't seem to be to much difference in physical size so hopefully it should fit without to much difficulty. Oh yeah... I cheated when it came to mounting the centre bearing, not that I ended up having much choice with the wreckers being closed and for some reason the circuit breaker on the house kept throwing out when I tried to weld the "L" series bracket into place. And its definitely not a MIG problem, its a two month old Cigweld 185 Multi-Process welder. Think I might have finally pushed the electricals in this old place to their limits with all the welding and fabrication work that has been going on around here lately. So in the end I fabricated a bracket out 25mm X 50mm box section, I cut the box down the middle of the 25mm side, leaving 50mm X 50mm X 25mm square on one end to bolt the centre bearing to. The other end I left about 300 mm long, drilled and tapped 4 holes into it and bolted it in through the floor. Personally, I can't ever see there being enough twisting force placed on the centre bearing to ever twist the floor or pull the bolts out. I would have preferred to use the "L" series mount but it wasn't to be in the time frame I had and lets face it, its not as though the "L" series is a really strong design either. Maybe when I paint her I might fill the holes in and place the "L" series mounts into her then when she is upside down just to give it a clean finish. Cheers, Al
I'd like to go all wheel drive oneday, even went and checked out what was supposedly a vortex 5 speed with a lockable center diff, which turned out to be FWD only, rather disappointing to say the least ☹ But to be honest, far to much work involved for me at the moment with my limited resources... Unless of course you are offering to build me a box Beanie?? LOL Yes... EJ will be great! Have been looking for awhile now for one, it has pretty much come to the point of having to rebuild one before installation. Nothing but high mileage vehicles around here. For other reasons, I was hoping to do it the other way, get the fabrication side of things done and then rebuild it while the engine bay gets painted. I had a plan to paint her the new (10 yr old now probably) Mazda red with factory style AgQuip stickers but done in a charcoal, grey and black colour scheme. These days I'm leaning toward painting her back to original. Still not sure which way to go there yet either. PS pump is a piece of cake to remove and head gaskets can probably be done in vehicle as well or throw a can of head gasket sealer in her and hope for the best but I guess if I do it this way I can pick the best bits and hopefully get a reliable engine for awhile LOL Cheers, Al
Help testing junkyard 5MT from EA82
Definitely makes life easier to have the 5 speed shifter and linkages. The 4 speed 4WD range selector could be modified to work easily enough, you have to cut and lengthen this one anyway if you want to keep it looking factory. A short length of round bar with one end flattened out and drilled so you could get the pin in at the gearbox end and then weld the other end at the appropriate spot to the 4 speed linkage. Jobs done. Cheers, Al
Yeah, done on a proper keyboard. To do on a phone/tablet, it probably would have been put in the to hard basket LOL Hope I've fixed the viabration as well, haven't been able to give it a descent spin up to tell for sure so at the moment, it's a case of still having all my appendages crossed that this hasn't been for nothing. Hope you enjoyed the read. Cheers, Al
Ok, first off, this is a long read. Like the title says, its a bedtime story on the patience and frustration required to keep these old girls on the road or any older vehicle for that fact and how sometimes, doing what we do by keeping these fantastic old cars on the road and running can at times leave you feeling demoralized and defeated but I think in part, that makes up a little of who we are as individuals and the type of people we really are. We are attatched to our little out dated and dying platform but no matter what, we will do everything we can to keep it going for as long as we can and this afternoon, all you want to do is burn it to the ground but at the crack of dawn tomorrow, you'll be out there throwing spanners around the shed, whistling a tune and happily working away on the old girl again. And I love this about car enthusiasts. After all, isn't this why we gather here? To share information, tips and the stories involved and the lessons learned along the way? If nothing else, I hope this inspires someone else to persist with their project at a time when they feel its kicking their arse and they just want to give up on it. All I have to say to that is, don't! The struggle and battle will be so much more worth it when its done and dusted. So yeah, this afternoon I was feeling like I was a one legged man in an arse kicking competition and my arse was the number one target. Not sure if I'm a good story teller or not but I hope you enjoy the read. If it wasn't for s@#t luck, I wouldn't have any at all. I'd just like to say that in my defence, up until recently, Ruby had been getting a little neglected. My job involved me working away from home for weeks on end and when I did get home, it could be for 2 hrs as I passed through and did some washing or I might have been lucky and got 2 days off. Ruby had taken a back seat and it was really starting to tell and now with time on my hands, I could show her the TLC she deserved. A few months ago little Ruby (1992 Subaru Brumby EA81 with 4 speed dual range), decided to start giving me some issues in the way of an intermittent vibration, most of the time it was barely noticeable but others... My god it was bad!!! Very nerve racking at 100 km/h coming into a bend over the crest of a hill and she decides to start shaking the crap out of you, let me tell you, my arse was puckered so tight that I could have rolled the car and my arse would have held me to the seat. No fancy racing seats or harnesses required. After that little exercise, I decided it was time to do something about it. Previous investigation revealed nothing and not being able to find anything visible from the outside or under neath, I settled on it being the old 4 speed transmission finally giving death throws. After all, 12 months and 6,000 km's ago, I was changing the gearbox oil in her and one of the little tabs that go with the syncro's fell out as well. I always check my oils for signs of metal but damn, that was a pretty visible sized piece of metal and definitely not something you want to see when changing the oil and a pretty sure sign that an imminent failure was approaching soon. Having a wagon sitting up the back for the last 18 months with a good motor, 4 speed manual and the power steering in it that was bought to go into Ruby, I thought this was an appropriate time to just do the complete change over and problem solved. Knowing in the future that an EJ conversion is on the cards, I really wasn't intending on going to to much effort on the swap over and with life commitments, that could still be 6 to 12 months before the EJ project is finished. I pulled the old wagon out and got the old girl running, blew a bit of crude out of the exhaust, coughed, farted and smoked for a little but cleared up within a couple of minutes and sat there idling away beautifully (I would go and start it every few months, well, when ever I got the opportunity and it wasn't an easy thing to do, I had rigged up a external fuel pump and 5L container as the fuel pump in the car had died and it was being used as my parts storage shed both inside and on top of). Great, looking good so far. Grab the compression tester out, checked 3 out of the 4 cylinders, not great but it'll serve its purpose. In the process of doing this, I came across one spark plug that just did not want to come undone, oh well, no biggy, all the other cylinders have tested good enough to get me out of having to swap engines and Ruby's engine has more leaks than a sieve at the moment so I didn't really want to put it back in. Plus, this one is running beautifully and only has to last me 6 to 12 months. Lets just rip that sucker out as one complete package on the sub-frame and we'll get that plug out later. Got all new hoses and belts, new sump gaskets, rocker cover gaskets and the usual blah blah blah. Motor and gearbox is in and running, sweet, jobs done. Drove up the road and back to make sure everything was working as it should be, parked her up and put her back up on jack stands to finish off some other odd jobs. In the process of waiting for some parts to turn up, I decided to investigate if Ruby's original motor had the 225mm flywheel to do the 5 speed conversion, after all, I've got everything I need stashed out back and wouldn't you know it, its the right flywheel. WooHoooo Jumps of joy and excitement After all, power steering, 2" lift plus all the other little things I've done and a 5 speed gearbox, it is definitely happy days at Al's place. That's it, pulling that motor and gearbox out again (Second time in 2 weeks) so I can put the 5 speed behind it while I get ready to do the EJ swap. Now, I know when I originally pulled Ruby's engine that it would have made sense to check it then rather than go to all the extra trouble of having to remove the engine and gearbox again but at the time, I was on a bit of a dead line and with that missed I could take my time and do it now. Conversion went like clock work, got everything in and wired up, started it breifly (I still had no exhaust attached after the conversion and it was dumping straight out of the header pipes and just a garden hose plugged into the radiator hose for a cooling system. Yeah I know, I was trained at Dog Auto's because we're ruff ), cycled it through the gears and the range box, everything is functioning perfectly, I have all gears and they are selecting smoothly and the clutch seems to be doing what its meant to. Now keeping in mind, this whole process is going on over the course of the last month in between life and other commitments and other work that is being performed on Ruby herself. Now is when it all just turns to a large steaming pile of warm crapolla... After slaving away and tidying up all manner of little odd jobs that needed to be taken care of, I finally got to the stage of filling Ruby up with water and firing her up and give her a little shack down on the jack stands and running her up to operating temperature. At first, everything seemed fine, motor just fired straight on up. No choke, the usual two pumps on the accelerator pedal and straight to life, very little throttle input to clear her throat and she just sat there idling away as nice as can be. The gearbox is changing nicely and the clutch is all good. Happy Days Feeling pretty chuffed with myself after the huge amount of work I had put in to her and to hear Ruby-Doo sitting there after a little fine tuning sounding better than she has ever done was music to my ears and the sign that I was almost at completion and Ruby and I could drive off into the sunset and life was just perfect Oh crap... Hang on... WTF?? Why is there so much smoke pouring out of the exhaust still?? Hhmmmm... That doesn't look good... Ok, take a moment, breath and settle Al. You've just put a different exhaust on it and it really hasn't been run up to operating temperature before now, maybe there is oil in the exhaust from the previous engine, with all the rain we've had over the last couple of days, maybe its moisture in the system. Who knows?? Just give it a few minutes. Oh s@#t... Nope, that is definitely not something you want to see. Wander around to the back of the vehicle and pays closer attention to the smoke... Hhmmmm... Bubbles in the radiator, smoke having a sweet smell to it and upon closer examination it was actually massive amounts of steam and not the usual smell of burning oil. And when I say massive amounts of steam, I would have given a coal powered electricity plant a run for their money. Never in my 35 yr history of being around some form of engine have I seen something produce so much steam, to be honest, I never even thought it was possible BUGGER!!! (Not the actual word I used but you get my drift). And to top it off, in the hunt to try and find which cylinder may have blown through the gasket, I decided in my wisdom (And right here was where I went wrong, thinking I had any sort of wisdom) that now was a good time to get that pesky spark plug out and have a look at it as well. After soaking it in all manner of lubricants for several hours and running the engine up to almost operating temperature, I went to work on the plug. After much grunting and groaning to the point of feeling like I'd just turned my freckle inside out annnnnnd CRACK!!! Yeah, that loosened it... Oh... Wait... Maybe that loosened it a little to much... Just stripped the thread out of the head trying to undo the bloody plug . So the bloody thing has now done a head gasket, stripped number 3 spark plug and now with the power steering pump in place, number three is a real pain in the arse to get at. Am starting to get the feeling of one of two things, either Ruby wants to die peacefully and left be or that she is rejecting the temporary heart transplant and wants her old engine back. Have already ordered a complete gasket set, will start stripping down Ruby's original engine tomorrow, re-seal it and for the third time I will remove the engine and put it back on there and see if I can have a bit better luck this time around. Yeah, she is testing my patience a little, well, lets be honest, a lot lately but I love my little s@#tbox... Ruby-Doo for life!!! I've got three motors sitting here, I'm damn sure I can piece together one good motor to keep you going you little b@#%h!!! You ain't quitting on me now, I'll tell you when you can die Ruby and it won't be happening on my watch. On a side note, I scored what appears to be a 2 and 5/16th of an inch or just under a 60mm in real lingo inside diameter exhaust system that was made for an EJ converted Brumby. I was just going to cut it up and use it to relocate the cat but decided to fit the whole system in prep for the EJ conversion. Made a huge difference to note and performance, thinking maybe my old cat converter may have been on the way out and starting to block up. But the moral of the story is that at the moment while testing I'm not running the rear muffler box (modifying the brackets to get it to sit a bit nicer and fitting a joint for easy removal), it's running through the cat and exiting straight out of the mid section pipe just before the rear axle and god DAMN it'd be nice to leave it like that for awhile. I wouldn't like to drive far in her but she sure does make some beautiful music under revs and when you back it off LOL Hhmmmm, Now that I think about it. Probably not such a good idea, probably already upset the neighbours Any way, I'm off to bed, I got to be up at daylight to pull an engine out. Have a great Sunday everybody Cheers, Al
Replacement Dashboard speak for second gen?
I could be wrong but I think they are a custom size made for Subaru to suit where they wanted to fit them. Cheers Al
How to remove mouse nest/debris from around heater core?
A really important thing to note when removing a dash is that, if you are removing the wiring harness to get the dash out, STOP right there. The wiring harness and the dash will come out as one complete unit, the only wiring that may require removing is any wires that have been put in after the factory. If you separate the wiring harness from the dash, it makes it a real bitch to get back in neat. Other than that, as the others have said, it's a very easy process. Take your time, and watch where you remove everything from, all the plugs are either colour coded or different in some way to each other. Or a bit of masking tape and a pen soon fixes the problem of what goes where. Cheers, Al
L Series 5 Speed Wiring?
God Damn It!!! Spent the better part of the day trying to figure out why I no longer had low or high beams working, yet they would flash if you pulled back on the combination switch. Cut out the remote central locking kit, thinking I may have wired something wrong in there, all to no avail. Spot lights worked, fog lights worked, everything worked bar the headlights. Had me absolutely stuffed what was going on. Swapped over all of the relays I could find, checked power everywhere, it just didn't make sense, nothing I did seem to make any difference. Turn the headlights on and you would have power there but no light, changed over the switch thinking it may have something to do with that, nope, still the same problem. Eventually in a last ditch effort I started tracing back all of the wiring, testing everything I could along the way, everything was perfect... Except... When I changed over to the tilt steering column, everything all plugged in and seemed to be sweet but NNOOOOOOOO... In their wisdom, there is a slight difference in the wiring at the plug from the indicator combination switch and the main loom. Didn't even think there would be an issue here, same plugs, same number of wires and at first glance, same wire combination. Swapped over to my original combination switch and all is well. I hate it when it takes so long to figure out such a simple little problem.
Many thanks to both you and Subarino buddy. Give Subarino my thanks and appreciation next time you're speaking to him. Thanks again, Al
Thanks guys, think I've got it sorted this morning. I was having a few electrical gremlins before swapping the box over so I think today is dedicated to sorting those out, which I think can mostly be put down to bad earths. Getting ready to put a dual battery system in and doing the wiring for that today as well, think I might take this opportunity to add a few more earth points and see if that helps the situation also. Not sure what you are meaning about the red 626 Jono? But if you are looking for a 626 to get the center bearing mounts out of, I can have a look for you next time I'm out there. They're currently shut until the 07/01/19 so it won't be until after that. Cheers guys, Al
Unfortunately at the moment my instrument cluster is non 4WD and doesn't have the lights. Main concern at this stage is to get reverse lights and I'll work the rest out later. I found a thread over on AUSubaru referring to this but there is no image/link visible :-( Thanks bud
Thanks Bennie. That link has at least given me which switch's are what and I can trace it back from there and adapt it to suit from there. Once again, thanks for your help Bennie
Yeah asked my mate Google and he wasn't all that helpful, will check out their site and see what comes up. Thanks Bennie
So I'm about to start sorting out the wiring for the L series box into my Brumby. Just wondering if anyone could save me a little time and let me know which wires are which at the 6 pin round plug please? Cheers, Al
Does Anybody Have??
Thanks mate, I've got a couple of sets of the original 13" center caps but they don't fit unfortunately. Thanks for the offer though. Cheers, Al
changed the wheel bearings and seals on my 87
Been looking around at tyres a lot lately, have stumbled across a lot of 13" and 14" winter tyres on the web... Doesn't mean they are still available in your area but there is at least hope. Cheers, Al
poop! exh port gasket shot EA82T
If you have the room to get at it, go down to your local hardware store and get yourself a good hot torch and try putting some heat into the block before undoing them. I always re-assemble these with a good quality high temp anti-seize compound on them as well, makes life so much easier if you have to pull them apart again at a later date. Cheers, Al
Introducing Ruby-Doo
Sorry Bennie, I meant that the wiring for the electric mirrors won't be that difficult to figure out. Unless of course you actually meant the mirror mode LOL And I was joking about it taking you 8 years to do and yes, unfortunately,sometimes life takes priorities in another direction... Not always the one we want to be going in :-( Take it Easy, Al
