Posts posted by unibrook
Hi, Bumping this thread up with a followup question.
2001 forester 92k miles. cold engine squealing belt and lack of pwr steering assist until all warmed up a few minutes later, then all is normal. Fluid level ok.
Whereabouts is the power steering belt tension adjustment gizmo located? What procedure do I follow to tighten it a bit? thx.
gotta say it...this is why I love NOT having a sunroof on my Forester.
Yah hum, well there mr. honda lover, changed an alternator on a honda accord lately? enjoy!
Just in case anyone wanted to hear what the rear wheel bearing sounds like...and this is going only 20-30 mph! You should hear it at 50 mph!
Perfect, thanks Hohieu. Any way I can contact you offlist if I have further questions specific to this task? thx, nwlovell at yahoo.com
There's a hole in my bucket, dear Liza dear Liza...
Can you just use the tools included with the Hub Tamer to remove the rear hub on a Forester 2001? Or do you have to use a slide hammer? Can't seem to tell if the rear hubs are floating or trapped. Does anyone know?
Bearings can make a somewhat pulsating noise too. Not a perfectly smooth growl.
I can feel my bearings starting to snap, crackle pop and grind...just looking at those pics!
Fun and games continue with my inde shop and the rear bearings they put in less than 1 year and less than 5k miles ago. I called them up and asked if they would fix it for free. They said "bring the car in, if the bearing is still under warranty, we will fix it for free." So I take a couple of hours out of my workday to drive it in there, and when I get back to the office they called and said Subaru won't warranty the bearing for more than 6 months. My shop won't give me free labor to put another one in, they said. Soooooo, why couldn't they figure all that out and tell me that over the phone instead of wasting my time like this? The answer is, they could. But once they hassle you enough to drop your car off at the shop, they figure you will just buckle and say, "oh ok, since the car is already there, go ahead and replace the bearing again for $375." I told them not to touch it, I will pick it up and fix it myself. And they will get no more of my business.
If your front O2 sensor has not been replaced in the last 40k miles, I will bet that is the problem. It was for me, same car.
Is PB Blaster substantially better than WD40? Or does it not really matter much as long as you spray the bastard down for days.
But grossgary, if you replace the whole knuckle/hub assembly as a unit, you must still have to go through the hell of removing the lateral bolt, right? Seems to be the toughest part of the deal.
Just to echo what TIMINTC said, if your car is reasonably late model (1999 and newer) the rear wiper motor is probably not the culprit...it has a sensor in it to shut off if it feels too much resistance. So the motor rarely burns out. And the gears rarely strip. You will probably find what timintc and I did that the shaft itself is corroded/frozen. Remove the back gate plastic trim panel...some big phil-head screws, bunch of plastic pop out tabs. Take the motor backing plate off being careful not to strip the 6 small phil-head retaining screws...and get ready to catch the white nylon gears that might fall out. BTW, my wiper arm was corrosion welded onto the drive shaft, and I sheared the retaining nut and end of shaft off as I tried to remove it...turns out you don't REALLY need to separate the two pieces anyway. Then spend 30 mins spraying WD40 and or lith grease up and down the wiper shaft from both inside and out and slowly work the wiper arm back and forth and it will free up. I sprayed white lith grease on all of the plastic panel tabs b4 I put it back in place figuring that this wiper motor grease job will prob become a yearly maint chore. timintc, have you tried gooping some silicone onto the ouside of shaft to prevent water from running down it? I might try this.
Hohieu, I dunno if they used ball bearings. I would assume they used new roller bearings...if that is what gets sold as a replacement part. On the other hand, I am sure they went cheapest route possible. Maybe the bearings they got sucked, maybe my spindle has a lip on it. Dunno. So many dunno's when dealing with a shop. sorta why I want to just dig in and do it myself. Even though the hassle factor daunts me.
thanks guys, thems the leads I needs!
Hi Grossgary and Subaru360: where do I get used hubs? Can I mail order them? Any good source you have used? Or do I need to drive down to CT to a U-Pull-It junkyard? I live in Boston. thx.
don't feel badly, tcspeer. that first pic is unclear, and I also concluded that it looks like a female hole rather than the stub. curious to hear how this resolves.
I am interested in using a Hub Tamer Elite tool kit to change my rear wheel bearings on my 2001 Forester...drum brakes. Can this tool kit be used on my setup? I want to put the upgrade roller bearings in.
That was Dec 2007 I had both rear bearings replaced. Now it is Dec 2008 (< 5k miles later) and they are both howling like a banshee again. @#%&%$$^ I think I will take Gary's advice and try to just replace the whole hub assembly myself instead of paying another shop to screw it up for me. Any junkyards for Subies around Boston?
Thx RWEDDY, but will they replace both sides of HG's or only the one with evident leaking? (I fear I know the answer). thx.
Further to this, mine is 2001 Forester with 92k miles on her. I think driver side HG external leak is happening in fairly small way. I top up coolant once a year with a cup or two of premix. And yes, I had the super-duper official Subaru coolant additive put in under warranty. So, my question is, can I take my car into the dealer and point to the external leak and have them replace the HG for free, since it has under 100k on it? Anyone done this? thx.
See if your heat shield is hanging down. Could be that it is and doesn't let the cat heat up as well as it should to operate efficiently. Just a theory. But on mine, this did seem to be the prob, since I fixed it by reattaching the heat shield with a hose clamp...and the code hasn't come back on yet. (been 2 months.)
I am glad site is back too, but can I change this color scheme from light grey on dark grey to something easier on my eyes? Any idea how to do it? thx.
high pitched squealing at startup when cold.
Posted
Thx G, good points about adjusting just tight enough. Will do it this weekend.
