Cormfra
Everything posted by Cormfra
  1. You can see in this picture f44 the yellow ones there the the black and whit goes to the plug on holding and the black they comes form the other side of the plug grounds to the block
  2. And then wy wire thet go to the control unit is not getting voltage at the plug or the controls unit is that supposed to be like that Is it a ground?
  3. I have a Subaru loyale the last wiring to the ignition coil it’s all weird looking there and extra plug if anyone can help thank you so much. and if any one has any pictures of there ignition coil wiring that would be great
  4. I have just been checking the spark by pulling the spark plug wire of if the distributor and seeing if it will ark off of a group.
  5. I have a 90 loyale that has a no start I have replaced the coil and there is no spark right after the coil I am wondering what these plug goes too will show in picture it is the same kind of plug that plugs in the the transistor the weird thing on the ig coil bracket
  6. Can someone tell me the PIN numbers on a 90 loyale control unit
  7. Okay so now both eyelets are reading 12 ish. But that when it’s on the coil. They might be on the opposite way but I’m not sure
  8. Is the catalytic converter still in there? I had a Dodge van where the catalytic converters melted and cluged the exhaust making to much back pressure and it won’t start and if it did it would run really ruff im not sure why it melted but it runs now
  9. See here I don’t understand what’s ground and what’s not is the ignition start witch that goes the the coil is that positive or negative and what about for the one thst goes to the transistor
  10. So those two go to the ig coil but Which one is +&- and what about those other two plugs one goes to the transistor but what about the other one
