Need wiring diagram 1995 legacy
Legacy777 replied to hankosolder2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis is for the 97 Legacy, but should be similar. I think I may have the 95 one if this doesn't help. http://www.main.experiencetherave.com/subaru_manual_scans/1997_Legacy_FSM/
A/C system pressure/capacity
Legacy777 replied to bosango's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhen converting the first gen legacies to r134a, I usually recommend replacing the receiver drier with a new one, changing the oil to at the minimum esther based, but PAG is better, and charging the system to about 75-80% of its original capacity. The system refrigerant capacity will be listed on a sticker on the radiator core support. Take a look at my post over the Legacycentral BBS. I go into more detail there. The only thing I would suggest changing is the use of PAG oil over esther oil. That's one I have learned after doing a couple of these. http://bbs.legacycentral.org/viewtopic.php?f=11&t=1083
fuel pump not working
Legacy777 replied to daddycoolj's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGood deal. Keep us posted on how it turns out.
more tranny bushings help
Legacy777 replied to 97ej22's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhen I did the shifter bushings on my 97 impreza I had to remove the exhaust shield to get access at the bushings. I think I was able to wiggle the shield out without removing the exhaust, but yeah....it's not too fun.
Legacy777 replied to daddycoolj's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhen you tested for voltage on the plug going to the pump, were the green connectors still connected? The ECU only energizes the fuel pump relay for about 2-3 seconds to pressure up the fuel system, and then turns off until the engine actually starts. With the green diagnostic connectors connected, the ECU will cycle the relay and you should see 12v going on and off at the plug near the fuel pump. If you still don't see any voltage, I would then try and track down the fuel pump relay and check it.
Dealer recommendation in Mass
Legacy777 replied to CapeCodMike's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWelcome to the USMB Mike. Hopefully someone can give you some suggestions. If you don't get any responses in here, you may want to post in the meet & greet forum.
Legacy Sedan drift car
Legacy777 replied to brysawn's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHe's on the Legacycentral BBS. It's definitely a very unique car.
Legacy777 replied to daddycoolj's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would start by checking the connector under the passenger seat and see if it looks burnt. Sometimes the connection can get hot, cause an arc and fail. Also, I would check the relay. You can connect the green diagnostic connectors, which should cycle the relay, so you can hear if they are working or not.
Legacy Wagon cargo cover fitment question...
Legacy777 replied to SubieDaddy80's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt probably will be different, but hopefully someone can confirm.
Rust repair
Legacy777 replied to mikec03's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGood post and comments. I think you'll see more comments about rust repair in the old gen forum and some in the shop talk forum.
fuel pump
Legacy777 replied to ellets's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would start by checking the fuel pump relay. It's up under the dash on the driver's side (a real pain to get to). You can connect the green diagnostic connectors and it will cause the relays, including the fuel pump to cycle on and off. See if you can determine if the relay is good or not and go from there. This diagram shows the relay location http://surrealmirage.com/subaru/files/swap/elect_unit_loc/6-3_electrical_unit_location03.jpg Here's a picture of the connectors http://main.experiencetherave.com/subaru/images/ecuhide.jpg
95 leg stumbling and clacking
Legacy777 replied to powderhound's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHave you done any preventative maintenance recently? Air filter, plugs, wires, etc?
Legacy777 replied to 97ej22's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCan you provide some additional details as to what part specifically you're looking to replace.
cargo cover compatibility?
Legacy777 replied to greenleg88's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes they should be compatible.
new separator plate - no hardware
Legacy777 replied to tricked919's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere are different screws for the new plate. Here's what I just recently got. Plate - 11831AA210 (1PC) Bolts - 800406140 (5PCS) Bolt - 800406150 (1PC) The one separate bolt has thread locking compound on it. Not sure where that one is supposed to specifically go.
96 Legacy AC works with defrost, but not other vent settings
Legacy777 replied to JPX's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGood deal! Thanks for the updates and perseverance on troubleshooting the problem
90's EJ20 questions...
It shouldn't matter. The outer cam is typically setup for the throttle linkage and the inner cam is setup for the cruise linkange. The inner cam is slightly smaller and may give a little more resistance over the outer larger cam. The knock sensor should be just straight down if you're looking at the throttle cables. Here's a pic of the knock sensor. http://www.main.experiencetherave.com/subaru/images/injectors/DCP_2481.JPG http://www.main.experiencetherave.com/subaru/images/injectors/DCP_2475.JPG Not sure if I answered all your questions. If not, let us know.
Here's resistance values for the (2-wire) engine coolant temp sensor 2.0 - 3.0 kohms @ 20 deg C (68 deg F) 0.3 - 0.4 kohms @ 80 deg C (176 deg F) Here's the resistance values for the (1-wire) dash gauge sensor 187.6 ohms @ engine coolant temp 46 - 54 deg C (115 - 129 deg F) 19 ohms @ engine coolant temp 116 - 124 deg C (241 - 255 deg F) Here's a scan from the factory manual on the dash gauge. http://www.main.experiencetherave.com/subaru_manual_scans/FSM_Scans/1992_TLegacy_Dash_Temp_Diag_non-USDM.zip Here's the fuel gauge info I have. Similar to what ts39136 posted. E - 92 ohms 1/2 - 48.5 ohms F - 5 ohms
EJ25T Turbo selection and components
Welcome to the USMB. With that much power, I'd highly recommend a front mount over a top mount. Not sure about the turbo, but to make that kind of power, it's obviously going to be a huge turbo. External wastegate is also probably a must or highly desired. BTW, what are you planning to stick this motor into, and are you wanting 500 wheel horsepower or 500 crank horsepower?
You need to supply 12v to the CEL output on the ECU. Circuits always sink power better than supplying power. With the test meter, put one side on the CEL pin, and the other side to a 12v source. Even if there are no codes stored it will blink at a steady rate. All the codes can be found on my site. http://www.surrealmirage.com/subaru/engine.html I'll try and work on getting the values tonight. Been busy....
EJ22 vs EJ22 with 1.8 heads for my 93 IMP
Legacy777 replied to A DOG's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat year EJ22?
Engine and waranty
Legacy777 replied to Roger Stokes's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would not recommend putting it in the car. If they don't initially honor the warranty, I'd suggest getting a leak down test so they do. It'll be cheaper to spend the $100 now vs. trying to have to pull the motor out later to do the head gaskets.
Legacy777 replied to JPX's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah....I would check the circuit board again.....sounds more like that could be the problem.
Legacy777 replied to JPX's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWithout the diagrams I can't confirm or deny what you may have found. However, you should be able to get a recharge kit with gauge to check the pressure without the compressor running to see what it is. If it's less than about 30 psig, then it's probably too low.
92 Legacy trans acting up
Legacy777 replied to christliche's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWelcome to the USMB. I'd recommend changing the fluid and see how things work from there. Let us know when you change the fluid and if that helps or not.
