05 OBW tranny and Trans X product
Legacy777 replied to bigbearrick's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes it always not shift out of first until things warm up, or is it only in colder ambient temperatures?
Impreza Cruise Control Part Numbers
Legacy777 replied to jarz21's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've got the same problem. I tried to piece the parts together to put cruise on my 97 OBS a couple years ago. The main hurdle was that the cable was too short. It just hasn't been at the top of my priority list, but I really need to see if I can find a shop that will make a cable that is 1" longer. I've got an ECU, but don't know where it is at the moment. I believe it was out of a 94 Impreza though. I'm not sure why any MT cruise ECU wouldn't work....
EJ 205 IC question (turbo newb)
Legacy777 replied to Txakura's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou're welcome.
2000 Legacy stalls when clutch is depressed
Legacy777 replied to 2000 Legacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd second that recommendation as well!
Legacy777 replied to Txakura's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOn turbo motors, the bypass valve needs to be fitted somewhere on the piping between the discharge side of turbo and throttle plate/body. For this instance, it's on the intercooler. It needs to be piped back to the piping before the compressor side of the turbo. The bypass valve vents the pressurized air that gets trapped in the intercooler/piping when the throttle plate snaps shut. This keeps the turbo compressor from going into surge and potentially flowing backwards. The vacuum source on the bypass valve needs to be hooked up to a port on the intake manifold. Hope that helps.
Throwout Bearing ??
Legacy777 replied to garwood1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe sleeve is meant to help a worn transmission snout. The TOB ride/slides along the snout of the transmission. If it gets heavily grooved or worn, that can create issues with the TOB. This sleeve/kit is meant to put a new wearing surface (sleeve) over the transmission snout and provides a "new" surface for the slightly larger TOB to ride upon. When your mechanic put everything back together, I'm assuming he greased all the joints and pivot points of the clutch fork real well? I think a pilot bearing would give you a different noise/issue if that was the culprit.
Tensioner Bracket
Legacy777 replied to nickb21's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've read that people have replaced it, but I'm still running the old style without any issues. I'm sure others are too.
Legacy777 replied to 2000 Legacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo you know what kind of spark plugs were put in? It may not be a bad idea to pull the plugs to look at them and see how they are wearing and if the gap may need to be adjusted.
97 Outback mystery part
Legacy777 replied to AEROCOOK's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm not sure what that is, but hopefully someone else can help you out.
2002 Legacy L
Legacy777 replied to Grammy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWelcome to the USMB Chris. Does the current owner have any service records for it? Besides the items you mentioned, (which I don't have much direct experience with on that particular model/year) the automatic transmissions can give you issues if the fluid has not been changed regularly. I'd suggest checking it over, or bringing it to a mechanic to check over if you're serious on purchasing it.
front seat swap Q's
Legacy777 replied to 97obs's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNewer Subaru seats will work. I've got a set of 2002 WRX seats in my 97 Impreza outback sport.
Adjusting temp control cable-95 Legacy
Legacy777 replied to brighton98's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's probably behind inside the control unit.
Forester heated mirrors
Legacy777 replied to mdjdc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah, there's probably a relay or fuse. Do you happen to have a wiring diagram? If not, maybe someone on here may.
Got a New "noise" can't locate it...
Legacy777 replied to Loyale93v's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat happens if you jack up that corner and spin the tire by hand? Do you hear the noise?
Legacy777 replied to brighton98's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo is the problem that the lever/door does not stay put where you set it. Or does the selector not indicate the correct position for what the door is positioned for? If the issue is the first, there's probably a screw or nut to tighten that will increase the resistance on the door movement, or keep the selector lever from moving.
1990 Legacy Turbo vs. non turbo parts
Legacy777 replied to notnowles's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe main issue you run into with swapping motors in the newer cars is that they are OBD2. So you need to utilize the sensors meant for the OBD2 ECU. You may be able to utilize the long or short block, but I don't think things will be a direct plug & play swap.
97 EJ22 Impreza ECU differences - could it be EGR?
Legacy777 replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah I would probably say it's an EGR issue. 22611-AC830 has been superceeded by 22611-AC831. So there's really only two ECU's. Since they've done that, 30 & 31 were pretty much the same.
width of Forester and OBS cargo covers
Legacy777 replied to mcbrat's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMick, I could get a measurement from my 97 Impreza OBS if that would help? If so, let me know.
Timing Bearing Components
This is what happens when one of those ball bearings gets lodged in the race and locks up.... http://www.main.experiencetherave.com/subaru/images/shreddedtbelt/
Legacy777 replied to 2000 Legacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd definitely would suggest the coolant temp sensor. Other thing to check is the idle air control valve. I believe on your motor it is a plunger type valve on the throttle body. They can sometimes get gunked up, and not flow the appropriate amount of air. You can remove it and clean the carbon/oil build up from it. That may help. When you reinstall it and first start up the car, the rpms may race until the IAC valve has a chance to reset it's base position. Regarding the coil pack, the test procedure and resistance values should be in the factory manual on my server. http://www.main.experiencetherave.com/subaru_manual_scans/2000+_Legacy_FSM/ A quick and easy method to test whether the coil pack has any cracks is at night with the engine running, use a spray bottle that sprays a fine mist, and spray the coil pack. Look for any sparks or arching.
97 legacy gt , rear wheels camber adjustment
Legacy777 replied to dakos's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou may need to slot (cut a larger hole) in the strut where the camber bolt goes. This will give you a little more room to move the strut to give you the negative camber you want. I wouldn't cut too large a hole, just do a little bit at a time.
Chicago NW suburbs
Legacy777 replied to crowheart's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you don't find an answer here, you may want to ask in the regional forums on NASIOC, http://forums.nasioc.com/forums
'95 legacy transmission noise
Legacy777 replied to excalibur5's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've heard of this issue on the 1st gen legacies. There's a check valve that keeps the fluid from draining out of the torque converter. Over time that wears out and the fluid drains out when the car sits for a while. I don't know however where exactly that check valve is located.
location of ECU?
Legacy777 replied to lionel025's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHere's a pic of the driver's side lower dash panel. http://main.experiencetherave.com/subaru/images/ecuhide.jpg
Legacy777 replied to 2000 Legacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe fact you have misfire codes all the time should be an indication of something. Are they the only codes that are currently stored? Or is the O2 sensor also a current code? Bank 1, sensor 1 is the front O2 sensor. Bank 1, sensor 2 should be the rear O2 sensor. If you have an active code for the O2 sensor, I'd suggest replacing it. However I don't think it is going to be your problem. Why did you replace the ignition coil? You mention it is not OEM. What happens if you come to a stop light or stop sign, quickly move the gear shifter from gear into neutral and then let off of the clutch? I just can't see any real correlation with stalling and depressing the clutch. As mentioned, I'd probably go back to the OEM coil.
