A Tire Shop Really Messed me up! Ball joint/Tie rod end
Legacy777 replied to JGromada's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSee if you can get some more details on the actual parts/bolt that failed.
fuel pump noise 2000 legacy
Legacy777 replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot sure what color it is. You can probably find that info in the FSM's on my server. http://main.experiencetherave.com/subaru_manual_scans/2000+_Legacy_FSM/
Legacy777 replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe fuel pump relay should be in the passenger compartment up under the dash.
forester floor mats: carpet or rubber ?
Legacy777 replied to damian's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd recommend the mats from Subaru as they fit the car much better. I believe the mats have a little hook to keep them in place, at least in the front. As for carpet or rubber....that's really up to you, and what you're going to do with the vehicle. I picked up a set of carpet mats on ebay a couple years ago, and then got a cheap set of clear rubber mats, cut them to match the factory mats and just placed them on top of the carpet to help keep the carpet clean. The Subaru rubber ones are nice though. They have big channels for water and gunk to collect. Cleaning is easy.
EJ22 injector differences?
These are top feed and do not fit the first gen legacies.
1998 GT ECU pinout needed asap!
Legacy777 replied to EastCoastEJ22T's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou're welcome.
The AT / MT thing doesn't really make that big a deal as long as the ECU matches MAF sensor, IAC sensor, and injectors. The other differences aren't that big a deal. The above is only applicable on the 90-91 non turbo models. 92-94 they all had JECS based electronics.
Legacy777 replied to EastCoastEJ22T's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHere you go http://www.main.experiencetherave.com/subaru_manual_scans/FSM_Scans/1998_Legacy_ECU_I-O.pdf
Central Florida Subaru Expert?
Legacy777 replied to Lucenut's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think there are a few people from Florida on the board that may be able to chime in. If not, you may want to ask in the regional forum on NASIOC http://forums.nasioc.com/forums
1993 Legacy Keyless entry...Seattle?
Legacy777 replied to starkiller's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXbump
OBD1 vs OBD2 hacked
All USDM 90 legacies had an EJ22.
96 Outback-Transmission Question-Over rev
Legacy777 replied to matt4irish's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre you experiencing any other issues? Like you suggested, I'd start with the transmission fluid. You may have a solenoid that is sticking. New fluid should help.
The gearing is different between the 90-91 AT's & the 92-94 AT's. That probably accounts for some of what you're seeing. This spreadsheet shows the gearing difference. http://main.experiencetherave.com/subaru/techinfo/Legacy_Speed_Calculator.xls
There is a difference between injector types between the 90-91 AT & MT non turbo models. I don't know if there is a size difference, but the type matches the ECU type, Hitachi or JECS. The 92-94 non-turbo models have a completely different type (red top) and I've heard rumors they flow a little more than the 90-91 non-turbo models. The 92's are rated at 270 cc/min. The 91-94 turbos are pink and rated at 370 cc/min.
No VSS - how do I fool ECU?
Legacy777 replied to dssenne's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre you talking about the plastic gear inside the differential? To replace it, you need to take apart the front diff to get at everything, at least that's my understanding.
Knoxville Subaru Owner's Dragon Meet 11-21-09 *56k attn*
Legacy777 replied to Durania's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe NASIOC guys get together occasionally and do the lime creek rd in the Austin hill country area. I haven't had a chance to make it up there though.
Legacy outback p0400 problem
Legacy777 replied to surf685's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWelcome to the USMB. Have you tried clearing the codes with a reader? Do they come back immediately or take a little while to come back?
Legacy777 replied to Durania's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLooks like fun!
code 45 and no boost :( (kinda long, need help)
Legacy777 replied to bmxkelowna's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd suggest clearing the codes and then see what codes come back. http://www.surrealmirage.com/subaru/engine.html
Top speed on 94 legacy sport
Legacy777 replied to martimus919's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPut together a little spreadsheet that will calculate the theoretical top speed. http://main.experiencetherave.com/subaru/techinfo/legacy_speed_calculator.xls From my own experience in my Legacy, I think these may be a little inflated. While I was AT & FWD, each gear would give about a 40 mph increase in speed. But you can use this to estimate a top speed. You can change the engine RPM and rev / mile numbers and that will update the spreadsheet.
Legacy777 replied to martimus919's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAs long as you have the power, gearing will be your top speed limiter. I've hit 130 when my car was FWD AT. The gearing is higher in the FWD models vs. the AWD cars.
One more issue with my auto manual swap
Legacy777 replied to Gsir08's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have heard of people leaving the TCU in there. If it's working fine with the TCU in there, I'd just leave it.
Starter clicks 2-8 times, then starts
Legacy777 replied to ryanw's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's probably the starter solenoid contacts. They are a couple bucks and can be replaced. There's several threads, please try searching and if you can't find anything, let us know.
89 legacy starts but dies
Legacy777 replied to r0gera's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, can you please indicate whether you're in the US or not. The 1990 model year was the first year the Legacy was offered in the states, and it was only offerred with multi-point fuel injection. Overseas models did get single point throttle body fuel injection....and I think even a carb model some places.
Emission passing w/ swapped in non-egr ej22
I'd go the ECU route. Doing the other stuff just sounds like more of a pain. Only concern I can see with the ECU, is if the ECU has a year/date on it, and they try and match that to the VIN records. This is for an auto trans car correct? Other option I suggest would be to just plug in the EGR valve from the old motor and not have it hooked up to anything. Not sure what sort of feedback loop is setup....but if there's not something checking things, you might be able to get away with that..
