Where to find black plastic plug for DOHC EJ25 heads?
Legacy777 replied to jelly man's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre they the things mentioned in this thread? http://ultimatesubaru.org/forum/showthread.php?t=105254&highlight=half+moon
1997 owb seat warmers
Legacy777 replied to 1997outback's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSee if there is some diagnostic info in the FSM. http://www.main.experiencetherave.com/subaru_manual_scans/1997_Legacy_FSM/
cutting out while driving
Legacy777 replied to lewisd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLooks like you have one of the elusive and few MAP based Subaru's.
One more issue with my auto manual swap
Legacy777 replied to Gsir08's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid you do anything with the MT/AT identifier pin on the ECU? If you take care of this, idle should be good, and the ECU should recognize that the car now is a MT.
OBD1 vs OBD2 hacked
This is very true. The early OBD2 cars are much more limited in what ECU parameters you can change/observe. One thing I would highly recommend is that you verify/test all the wiring prior to the swap, because on more than one occasion I've found the wiring diagrams provided by Subaru to be incorrect.
Steering rack bushings
Legacy777 replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd suggest the whiteline stuff. There are two different ones, the KSR200's and KSR202's. The KSR202's are predominantly the ones that fit the US Subarus. There's a few odd balls in the mix, but that's probably what I would start with.
My trunk wont open
Legacy777 replied to Uberoo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCan you open the trunk from the outside of the car with the key? If not, it's probably not the cable, but the lock mechanism.
Legacy777 replied to lewisd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHmmm....that's odd. Any chance you could snap a picture of your engine and intake setup?
Manual tranmission mount? Wheres a good place to buy?
Legacy777 replied to Gsir08's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can try getting one used, or you get one of the firmer mounts for about $66. Part # D1010FE020 https://www.chaplinssubarugenuineparts.com/oe_parts_cat.html
Legacy777 replied to lewisd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe MAF sensor is not located near the throttle body. It is near the airbox by the fender. Here's a few pictures http://main.experiencetherave.com/subaru/images/mafsensor.jpg http://main.experiencetherave.com/subaru/images/mafsensorpins1.jpg
head bolt torque sequence & spec.,valve clearance spec.
Legacy777 replied to RussellW's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXbump. If nobody has the info here, I'd suggest try searching on http://forums.nasioc.com/forums
Squeaky mornings PS pump driving belt 02' Legacy GT
Legacy777 replied to 740gle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt sounds like just the belt. I'd suggest getting a new belt. Shouldn't be more than $10-$20 at the most.
heater controls 90 legacy
Legacy777 replied to pamike's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah, it's gotta be the controls. Here's pics from my resoldering job. http://www.main.experiencetherave.com/subaru/images/hvac/
1994 Legacy Crazy Electrical Gremlins
Legacy777 replied to torxxx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would say you have a short or a ground issue. The yellow & black connectors you mention, yes should not have anything connected to them. Here's the 1992 Legacy FSM (engine & electrical http://www.main.experiencetherave.com/subaru_manual_scans/1992_FSM_(Engine_&_Electrical)/ I've got some other various manuals on my server as well. I'd suggest taking a look at the wiring diagrams and checking all the wiring/pins to the ECU to verify they are still wired/functioning correctly. If you do all that, and still nothing, then I'd suggest replacing the ECU.
Swapping out AT to MT...who has done it?
Here's my swap write-up. It is covers FWD to AWD, but should give you an idea of what's involved. http://www.surrealmirage.com/subaru/swap
2000 impreza rs- how do i remove the sunroof for repair
Legacy777 replied to milkman111083's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou need to remove the headliner, which usually requires removing the trim around the doors/windows. Once the headliner is out, the sun roof should be all one mechanism to be removed.
Interchangeability Questions
Legacy777 replied to tobiasglass's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAnything's possible, and I'm sure you could most likely swap over the springs. Bumpers probably would work...but might require some tweaking.
Code P1507
Legacy777 replied to BushmasterSI's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks for the pictures. Those old plastic PCV pieces tend to get brittle and crack....no fun.
Help:Need detail pictures for leggie turbo
Legacy777 replied to Dangerdave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.surrealmirage.com/vrg3/vacuum/
Quick power window question
Legacy777 replied to Gsir08's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI suppose if the relay is shorted out inside it could happen.
2000 impreza interchangeable Trans
Legacy777 replied to 2000impreza's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo you have the owner's manual for your car? If so, look in it and determine what your final drive ratio is. You may be able to use a transmission with a different final drive ratio if you swap the rear diff. It's not too big a deal. As for the auto to manual swap, yes it can be done. Here's my write up. Not everything will be applicable to you since I was also swapping from FWD to AWD. However it should give you an idea of what's involved. http://www.surrealmirage.com/subaru/swap
Legacy777 replied to Gsir08's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJohn, Replied to your email. Here's info on how to pull the codes from the ABS computer. http://main.experiencetherave.com/subaru_manual_scans/FSM_Scans/abs-2E-diagnostics.gif http://main.experiencetherave.com/subaru_manual_scans/FSM_Scans/abs_diagnostics.pdf
02 impreza 2.5 RS
Legacy777 replied to RussellW's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou've got a lot of questions. I don't think I can give you answers on everything. Regarding the head gaskets, I believe there has been some improvements/changes. I'd suggest talking with one of the local subaru dealership service centers to see if they can clarify that. I haven't heard about the bearing issue. Regarding the transmission. It probably is a bearing. My 97 impreza outback sport has the same symptoms. I'm just going to drive it until something craps out on it. I'd suggest searching over on NASIOC as there are more impreza owners over there that may have experienced similar problems.
lifted baja?
Legacy777 replied to dughrt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXScorpion does make a lift kit. There may be a few others. I'd recommend searching the board. Here's a link to Scorpion's site http://scorpionsubaru.com/index.html
Legacy777 replied to Gsir08's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSomeone could have rewired it so the windows work when key is removed. Other thought is you may have a bad relay or something....
