EJ22T swap wiring questions
The cam & crank sensors are wired backwards between the non-turbo & turbo engines. If I understand how you did the wiring, all you should need to do is swap the positive pins for the cam & crank sensors. Have you checked the wiring for all pins at the ECU to make sure they have continuity to the sensor they are supposed to be wired to?
HVAC recycling damper
Legacy777 replied to wallaceg's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe fresh air door is behind the glove box. If you remove the glovebox you should be able to see the door and the cable.
Engine Stalls & Codes 0325 & 0440
Legacy777 replied to kopin's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFirst thing I would probably check is that he reinstalled all the connectors properly. He may have taken something apart and forgot to put it back together again. I don't see how else the error codes could be related to the work....assuming nothing else didn't get screw up.
93 Leg sedan sounds like a CVJ but its not?
Legacy777 replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAuto or manual trans? If auto, what happens if you put a fuse in the FWD fuse holder?
I need a mechanic in the Atlanta area!
Legacy777 replied to RachaelB's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWelcome to the USMB. You may want to try the meet & greet forum as well. If you don't get any info there, you may want to check out the regional forums on NASIOC http://forums.nasioc.com/forums There's quite a few Subaru owners in the area, and they can probably recommend a mechanic.
Shift bushing woes...
Legacy777 replied to Fairtax4me's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't know if you're going to be able to modify the FWD shifter assembly to work on your AWD. I'd probably suggest going and trying to find one for an AWD car.
Lock your shop! Hide your tools! Yell at strangers!
Yeah, I'm rather cautious who I have in my garage, and lock everything up when I'm out of town. Got way too much crap in there.
Headlights !!!
Legacy777 replied to BRATDUDE's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHere is the diagram for the 90-94 Legacy. http://main.experiencetherave.com/subaru_manual_scans/FSM_Scans/Legacy_headlight_wiring_diag_(US).zip A switched ground setup means that only one power source is fed to the common pin on the headlamp, and that two separate grounds are then fed back through the switch. I think you'll understand once you see the diagram.
More from the 2009 Tokyo Auto Show
Legacy777 replied to mtsmiths's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI actually like this concept......I'm sure it will be bashed/torn apart and yuckified before it hits the masses.
P0710 and Oil Temp High Troubleshoot
Legacy777 replied to mikerayvt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd tend to agree with 0B99W. You may need a better meter. The chances of both TCM's being bad are pretty slim. Anything can happen, but chances aren't too great.
Headlights !!!
Legacy777 replied to BRATDUDE's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSubaru uses a switched ground headlight setup. I don't have any diagrams for the forester, but hopefully someone will be able to help you out.
Brochures for the boxer diesels
Legacy777 replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPDF's are not one of the allowable file extensions to upload. Email the brochure and I will host on my server.
Needed picture of internals of Forester/Outback differential
Legacy777 replied to Phizinza's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe pics in your link are for a clutch based LSD. The VSLD are sealed units and use a silicone based fluid with the torque transferring coupler.
Transmission; Anyone Know of a Free Mileage Check?
Legacy777 replied to Bbob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCarfax is probably the way to go. You could see if someone else with an active carfax account could run it for you.
99 Impreza OBS 4th gear slipping problem
My 97 OBS howls pretty good in all gears. Those year transmissions may have had issues. I'm just going to run it until it dies......if it does.
1992 Legacy won't start/cold weather
Legacy777 replied to labrador's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you are having temperature related starting issues, I'd suggest replacing the coolant temp sensors. These cars have no problems starting in very cold temps when everything is working correctly. The coolant temp sensor can drastically affect cold starting ability.
NO BRAKE LIGHTS!! 99 Legacy/Brighton
Legacy777 replied to Loyale93v's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes there is a little switch at the brake pedal. If you look down there, you should see it. Make sure all the connector is connected and the wires look good. If everything looks good, I'd probably suggest replacing the switch.
obd1 to obd11, ej25 to ej 22
Legacy777 replied to dunnahog69's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDon't the newer TB's have the IAC valve on the TB....If so, I think you're going to run into issues.
Legacy777 replied to Phizinza's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA properly working rear VLSD will spin both wheels at the same time, even if you just jack up the rear wheels and spin them. There should be no "ramp up" time heat up the silicone fluid inside the coupler.
If it was linkage, you'd probably see issues in other gears as well...
Legacy777 replied to dunnahog69's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou need to swap the entire throttle body. I'm not sure if the 3-wire throttle body will bolt up to the 93 ej22. Sensors, are the crank & cam triggers the same between the two engines? Was your EJ25 a DOHC or SOHC?
Legacy777 replied to mikerayvt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHmmm....that does sound a little funky. Probably as you indicated a wire inside the transmission. But without digging inside it'd be hard to verify and test. Is the temp sensor internal or external to the transmission?
Legacy777 replied to mikerayvt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you've replace the TCM, the wiring from the TCM to the temp sensor, and the temp sensor itself.....I can't see your problem being any one of those three. I would check your grounds. Is the temp sensor a 1-wire or 2-wire sensor? The 1-wire sensors ground through the trans and if the grounds are not right, that may cause a problem.
It's probably something inside of the transmission. The external linkage shouldn't really affect things.
new bee needs help 05 legace
Legacy777 replied to lajeunesserick's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWelcome to the board. I would check the wiring around the coil pack which leads to the spark plugs
