90 Legacy radio wiring
Legacy777 replied to daddycoolj's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.main.experiencetherave.com/subaru_manual_scans/FSM_Scans/Legacyradiodiag.jpg
2010 Legacy Test Drive
Legacy777 replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe car has just grown into a pig. The styling is bland....knock off of most other cars out there. I'm just not a fan of the little things they've changed. I've always been a legacy fan over the impreza, but I feel that tide has changed. I prefer the styling of the new impreza over the legacy....
sluggish Impreza
Legacy777 replied to AVDEEV's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre you experiencing any specific symptoms of the car not running properly? Or does it just feel different? If so, how long has it been doing this?
92 Legacy Wagon non-turbo Auto to 5mt conversion
Legacy777 replied to mountainchef's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHere's my write up. http://www.surrealmirage.com/subaru/swap
Rear end singing
Legacy777 replied to eppoh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTry inserting a fuse in the FWD fuse holder. This will temporarily disable the AWD. If the noise is unchanged, the problem is probably a wheel bearing.
rear strut interchange impreza vs legacy
Legacy777 replied to aa8jzdial's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey would probably work, however I'd suggest being cautious about using struts from vehicles that old. They are probably not great.
97 1.5 impreza ...HELP please
Legacy777 replied to kiwisub's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm not sure if you're going to find much info on here, as the US didn't get the 1.5 liter model either. You may want to try a Subaru board in Europe/UK. Other suggestion would be to find specs from newer subarus without hydraulic lifters and use that. You may have to do some trial and error.
Craftsman storage cabinet
Picked up a Craftsman storage cabinet the other week. They were having a sale, and discount for Club members. Anyway, it's pretty nice, and assembly went pretty well. My only complaint is the shelving. There really should be one more shelf in between the top & middle shelf. Due to the locking mechanism needing to be at a certain level, it limits your middle shelf location. Here's some pics http://www.main.experiencetherave.com/images/storagecab/
Craftsman C3 Powertool kit
You're not going to get much torque out of a battery pack impact wrench. You'd be surprised at how much torque you can provide with a good breaker bar/wrench.
Rear end singing
Legacy777 replied to eppoh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSubaru's tend to have a little bit more drivetrain noise, but it shouldn't be that prevelent...
swaping from ej 16 to ej 20 with manual trns
Legacy777 replied to DL92SW's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI wouldn't see any problem with swapping the motor and leaving the trans. What year ej20 are you looking to get? I'd suggest getting one around a similar year range as your 97.
No AWD – help!
Legacy777 replied to dashton's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou would probably be best off staying with the same model line. You may be able to use a Legacy TCM, but I kind of doubt the TCM connectors would be the same.
what model of utec uses a wrx 07 with a 05 sti engine ?
Legacy777 replied to abelsubarupr's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWelcome. You may want to ask that quesiton over in the engine management forum on NASIOC http://forums.nasioc.com/forums
Hesitation at 6300 elev.
Legacy777 replied to usasail's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHi Monty, Welcome to the board. If your O2 sensor is old, you may want to go ahead and replace it. The ECU will automatically adjust for changes in elevation. Another you can possibly do is reset the ECU so it's learning memory is starting off from higher elevations, rather than lower elevations. That should help speed up the learning of the ECU.
No AWD – help!
Legacy777 replied to dashton's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat TCU is listed for the the EJ25D. Other TCU's will probably work. They're programmed for shift points and agressiveness. The 2.5 RS TCU is probably a little more agressive then say a regular impreza or legacy.
2005 OB Recall/Service Program
Legacy777 replied to brus brother's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGood to know.
Ecm
Legacy777 replied to rvac99's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat codes do you have show up? How do you know it's running on two cylinders?
2007 Outback Sport Evap problems
Legacy777 replied to torxxx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou may want to check out http://forums.nasioc.com/forums Someone on there may have some info on diagrams.
91 legacy AC question
Legacy777 replied to pigmaster's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX134a works fine in these systems. I'd suggest reading over my tutorial on the Legacycentral BBS http://bbs.legacycentral.org/viewtopic.php?t=1083 My only suggestion/change to that tutorial would be to flush the system out, and use PAG 100 oil instead of esther. Esther does not do as good a job lubricating.
how to get trouble codes
Legacy777 replied to seth3030's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPlease read the FAQ Sticky http://www.ultimatesubaru.org/forum/showthread.php?p=428662
2004 impreza 2.5rs
Legacy777 replied to pamike's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo, the turbos didn't seem to have the headgasket issues that the non-turbos did.
94 Leggy Fails CA Smog - Labeled Gross Poluter:-(
Legacy777 replied to Sonicfrog's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXVoltage will cycle back and forth between 0 volts & 1 volts.
99 legacy brighton prewired for rear speakers?
Legacy777 replied to dlove's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLook for a taped up connector. If you can find one, that is probably for the speakers. If you don't find a connector, the speaker wires are probably not there.
Just bought first Subaru
Legacy777 replied to ahipps's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWelcome Andrew. Regarding the AC, check out this thread. http://bbs.legacycentral.org/viewtopic.php?t=1142 If you haven't stumbled across it yet, check out the legacycentral BBS. There's tons of info there for the first gen legacy. You can post in the WTB forum here or parts shed over on the BBS for the window switch.
"p0122 P" code?
Legacy777 replied to greenleg88's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo idea.....may just be a repeat....
