Can the seats from 2004 OB fit in 98 Forester???
Legacy777 replied to pearlm30's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey probably will, but couldn't tell you for sure.
2010 Outback Review
Legacy777 replied to 9098's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat was a pretty good read.....and very true in my opinion.
just a light question
Legacy777 replied to imprezaII's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou're welcome.
Longer sway bar linkages? (2001 OBW)
Legacy777 replied to baccaruda's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't know of any subaru end links that are longer. You're probably better off just looking for some generic end links that might work. There's a lot of stuff you could probably find in some of the four wheel drive magazines.
How to remove backwindow strips of 91 legacy
Legacy777 replied to rverdoold's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd suggest checking out the Body & Chassis forum on legacy central BBS http://www.bbs.legacycentral.org There's a current rust repair thread in there. Plus I'm sure there are others that may be able to give you specifics on the trim. I am pretty sure it can be removed.
Legacy777 replied to imprezaII's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat vehicle is this for? This document has some good info http://candlepowerinc.com/pdfs/H4_9003.pdf Just saw you're in Canada. You can upgrade to the H4's without any issues.
tips on disassembling a strut?
Legacy777 replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCouple things to note. When you remove the top bolt that holds the strut to the knuckle, mark it's orientation. It is a camber bolt, so you want to try and get it back in the ball park when you reinstall the new strut. As for orientation of the strut, it'll be obvious. However you want to mark/note the orientation of the upper strut hat (just below the mount). I believe the hats have an arrow that points outward to help with the orientation, but in the event it doesn't or has been corroded over, you should make note of how that top hat sits. An impact gun helps with the removal & installation of that top nut onto the strut shaft.
2010 Legacy Test Drive
Legacy777 replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat's the thing....I don't like CVT's! I've driven a Nissan with it, and is feels like it's slipping, and not really accelerating that much. I think if you drive like a grandma (no offense meant to hell-raising grandmothers out there ) the CVT could prove to be ok. However if you tend to drive a little like me the more frequent & harder acceleration will probably cause WORSE gas mileage. Just my thoughts.
Price Of 4:11 Diff
Legacy777 replied to Mugs's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSorry, should have clarified. All 90-91 non turbo (incl. AT & MT) have 4.111 final drive ratio All 91-94 turbo (incl. AT & MT) have 3.90 final drive ratio All 92-94 non turbo AT's have 3.90 final drive ratio All 92-94 non turbo MT's have 4.111 final drive ratio
Price Of 4:11 Diff
Legacy777 replied to Mugs's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid it come out of an original 92 Legacy? The 92-94 Legacies had a 3.9 final drive ratio from the factory. The 90-91's had the 4.11.
Roof rails on a 99 Forester
Legacy777 replied to 033197m's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre they actual Subaru rails? Probably your best bet would be to try contacting a lock smith to see if there's anything they can do.
Rear EJ drum brake question from a noob
Legacy777 replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey sound like they've got enough pad left on them. Other than that, I'd just make sure everything is adjusted properly, and maybe apply a little grease to the pivot points where movement takes place.
what year vcd's interchange?
Legacy777 replied to wally's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWelcome. What exactly are you referring to as vcd? viscous coupling differential? The coupling can be replaced separately from the differential. As for interchanagability between model years, I don't know specific years, but I think the 96 MY would probably work as well, and maybe the 90-94 legacies.
A Shoptalk Problem!
I just moved all the specific model threads recently posted. I do try to keep an eye on things in this forum.
New (2me) 95 Impeza L AWD
Legacy777 replied to myhilo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFor the compression test, just pull the plugs, disconnect the connector going to the coil pack, and open the throttle all the way while cranking. The cv axles from the Legacy should be interchangable.
Subaru independant shop in East Lansing, MI
Moved to meet & greet to get more exposure.
Suabru 2.5 dohc head gaskets
Legacy777 replied to littlecars's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMoving to new gen forum.
'05 Impressa automatic
Legacy777 replied to shortlid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd expect in the low to mid 20's, possible upper-mid 20's depending on how he drives. I'm pretty sure the head gasket issue has been resolved by then, but will allow others to comment that may have more experience with those cars.
Adding cruise to my 1993 Impreza isn't working
Legacy777 replied to Dodge Aries K's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis is for the 1997 cruise add on, but may help http://main.experiencetherave.com/subaru_manual_scans/FSM_Scans/1997_Impreza_Cruise_add-on.pdf
Gas gauge up and downs
Legacy777 replied to mudduck's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo you have any issues with the guage while driving, or only after startup? Does it happen at cold starts only?
Can 2004 Outback Struts Fit 98 Forester???
Legacy777 replied to pearlm30's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot sure. Anybody else?
P 0483 code and possbile overheat?
Legacy777 replied to vwbuge1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou may have air trapped in the system. With the engine cooled off, open the radiator cap and check the coolant level. Add coolant if need, leave the cap off, and start the car. Let it run and warm up with the cap off. Put the cap back on and see how things run. You may have other issues if that doesn't help.
Legacy777 replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI hate CVT's!
Correlation b/t oil level and baffle leak?
Legacy777 replied to goof_ball's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere might be a correlation, but it'd be hard to tell unless you could see specifically where the oil leak was coming from. By the time it's under the car and everything is slimey, it'd be hard to say.
Craftsman storage cabinet
I don't think it's rated to carry combustibles. However I will most likely be putting aerosols in it. I thought about doing that, but there are predefined spots for the shelves, and where I would for one to go, there's no slot for it to go....I'll probably look for a shelve of some kind with legs I can stick in there
