Everything posted by SuspiciousPizza
Seized ea81 engines
Totally shooting from the hip here, these are all ideas and I've never done any of these methods. 1. Maybe you could fill the piston from the bottom (use it as a bowl) and fill it with dry ice or liquid nitrogen. Maybe you could get the piston cold enough to get it to shrink and you could use your timber+hammer method to remove it then. You may have a temperature transfer to the cylinder walls so this may not work. But the sleeves and piston should contract at different rates. 2. Pour water into the cylinder all the way to the top. Reinstall the head (maybe add some cheap RTV or the like) and stick the block half with the head on into the freezer. Maybe the hydraulic pressure from the water freezing could remove the piston. Or you'll end up cracking the block or head so best use a head that is already too far gone.
EA82 93 Loyale didn't pass CA smog - maybe Exhaust Gas Temperature (EGT) Sensor?
That EGT sensor is correct. P/N 22629AA000.
I'm away from my service manual at the moment, but I'll check it later today to see what's up with the California emissions setup. I'd scan for codes first because that'd tell you if a sensor is sending out-of-spec values. Under the steering column, remove the two plastic panels. The panel closest to the pedals has a metal c-clip going around the steering shaft, just force the panel downwards and it'll pop right off. With the panels off you'll see the ECU with the three large connectors going to it. On the ECU will be a hole with a small LED inside. Turn the key to ON and watch the LED. Long light flashes are values of 10 short flashes are values of 1. So 2 long flashes and 4 short ones will give you a code 24, for example. There will be short pauses between codes. Let it cycle a few times to be sure you count the flashes properly. You can look up the codes online or in a hardcopy service manual if you have one. I'd imagine the EJ18 sensor you've shown above is different from the EA82 sensor. But I'm not super familiar with all the emissions hoopla you Californians have to deal with so I could be wrong. I can get you the part number for the sensors later today.
Calling All Dual Range Owners
Since this information is difficult to track down - I have a "Identification number" to part number match that I'm quite positive is correct. ID# 95AC-23 is part number SOA925H300R1 The axle in question is for the following models per my '85 GL/DL - '90 Loyale parts catalog. Hatchback: '88-'90 DL/GL/RS with SPFI '86 - '90 DL/GL/RS/Single Range 4WD (only turbo models) 4-Door: '85 GL-10 turbo with 3AT '88 - '90 DL/GL with SPFI '86 - '89 4WD turbo & RX turbo with automatic transmission '85 DL turbo/GL-10 turbo/RX turbo '86 - '90 DL turbo/ Single Range 4WD turbo/ RX turbo '88 - '89 full-time 4WD turbo with automatic transmission '86 - '90 DL turbo/ GL-10 turbo (2WD & automatic transmission only) Station Wagon '85 4WD turbo with automatic transmission '88 - '90 DL SPFI/GL SPFI/GL turbo/GL-10 turbo '86 - '89 4WD turbo with automatic transmission '86 - '89 DL turbo/ GL turbo/ GL-10 turbo/ Single Range 4WD turbo '88 - '89 full-time 4WD turbo with automatic transmission '86 - '90 DL turbo/GL turbo/GL-10 turbo (2WD and automatic transmission only) Alternate P/N's. 23221GA372, 23221GA373, 23221GA592, 23221GA593 If you have information that contradicts with anything above, please share. Thanks :]
I got my hands on a factory parts catalog and it's lead me down a confusing rabbit hole. I have an '89 GL, SPFI with the dual range transmission. It has the front CV axles with the ribbed inner joint and the two identification bands on the axle shaft near the outer joint. ID #87AC. The service manual says these axles are for the CARBED engine, not the fuel injected. If the reader of this post has an SPFI with the dual range, what axles do you have? Because I'm starting to think I may have the wrong axles (?) The parts manual is a joy to decipher on its own but the best I can tell the 87AC axles are not for the SPFI with dual range (I'm thinking the correct axles are the 95AC-23). Or does the SPFI fall under the "Carbureted" category since it's basically the e-cig version of the carburetor? Thanks :]
EA82 Compatible Con Rods
No, P/N 12100AA310 is NOT compatible with 12100AA011. None of the dimensions are the same. Too large of bearings and center-to-center distance is too long. Bummer. I hope I don't need rods or else I'm tearing into my spare ea81. I'm saving it for a TBI conversion.
'87 GL-10 Turbo, uneven running at higher power/RPM
There is no scan tool for these cars. Under the steering column (you gotta remove the two plastic panels beneath the steering column) you'll see the computer with the three large connectors. On the computer you'll see a hole with an LED, this light will flash and display the codes when you turn the key to On. Long flashes are values of 10, short flashes are values of 1. So 3 long flashes and 2 short flashes would give code #32, for instance. There will be short pauses between codes. The computer only reads electrical faults, it will not indicate a mechanical fault. You can find codes lists online as well as the service manuals. I'd deal with the codes first, in the order the computer displays, if that doesn't solve it, then dig further into the service manuals.
I've been Johnny Cash one-piece-at-a-time(ing) everything I need to build a fresh EA82 and I've been stumped on sourcing connecting rods. On several parts websites I've seen that EJ rods (P/N 12100AA310) are allegedly compatible with EA82 rods. However, the stock P/N for EA82 rods (12100AA011) doesn't show up in the supersession list. Has anyone tried putting EJ rods in an EA82? I've heard of others trying to get EJ pistons to work but I haven't heard of using EJ rods in an EA82. Thanks :]
Loyale 89 front bushings
I used DRW bushings. They work well and I've heard good things about them. Some bushings will need to be burned out with a blow torch and cleaned up with a steel pipe brush. Some bushings have metal sleeves that allowed them to be pressed in upon assembly at Fuji. If you burned out a bushing and the replacement one doesn't fit, check to see if there's a sleeve. The sleeves have to be cut out with a hacksaw (some bushings are designed to fit inside the sleeves so double-triple check before you go cutting away) It may be a good idea to inspect all the other bushings as well as your strut mounts.
XT Turbo drive shafts in Europe
Personal opinion: I'd stick to OEM axles over aftermarket ones. Specifically when looking for fronts, OEM axles will have the identification bands on the axle shaft. Aftermarket ones occasionally don't even have spline counts listed on the listings and this makes it a real crap-shoot trying to find the proper axle. I know rears are your main priority, but I do have a used axle (I haven't torn it down to check condition) and a new-in-box factory rebuilt axle. I believe both are for FT4WD. They have 3 bands on the axle shaft. I don't have a FT4WD transmission so I won't be using them anytime soon. I bought them as part of my crap-shoot trying to find 2-band axles for a D/R 5MT. If you're interested in them, I'd be willing to sell them or perhaps trade if you've got any 2-band axles or an EA82 cylinder head with single-port intake that isn't cracked. :]
SPFI EA82 Idle Stutter and Rattle
Solved I had a broken wire in my engine harness going to my IAC valve. Spliced in a new wire and she's been running good for over a week. Now I'm back to searching high and low for engine parts. I plan to do a full engine rebuild come summer and I am trying to plan for the worst. If anyone knows someone who knows someone who has parts, by all means any leads are appreciated. :] btw cotter pins slotted into female harness connectors make testing for continuity while bending wires a lot easier.
I believe the coolant leak from the radiator cap was caused by a worn plastic lip on the radiator. In the next few weeks I'll be doing a pressure test on the coolant system and a smoke test on the intake and vacuum system, as well as verify my timing (just gotta wait for the tools). More blurbs to come in a few weeks. If I don't see ya before the end of the year, happy holidays to all! :]
Replaced the timing belts, tensioners, and pulley. All went well. Started up, but I still had to keep my foot down. When I lifted my foot it did it's "normal" flutter idle at 250 RPM whereas before it was at 750 RPM (before it'd die below 500 RPM so small victory). Loud clicking from the center of the engine still there. As I went to go check on the clicking, it was PISSING coolant from the radiator cap. Well that's new. Could a head gasket issue cause the flutter and coolant leak? I'll keep posting as I chase this cornucopia of mysteries. Any suggestions or ideas are always welcome. :] Noah
Hi :]
Holy tinfoil hats, Batman! I love how planned obsolescence destroys good things. I'd almost rather the conspiracy of the parts being destroyed by a tsunami or nuclear disaster be true than dealers destroying parts. The search is the tedious, fun part for me. Requires networking, you meet cool people, and there's always a story. Keep 'em alive. If they've should have been thrown away then don't make them a blast to drive (modern vehicle corporations have picked up on this.)
Quick check of CTS, dizzy, and belt. CTS: Solid ground, 0.5 ohm resistance to ground. Haven't done the water temp test yet as I don't want to drain coolant for the umpteenth time if unnecessary. Dizzy: I can rock the car by the dizzy rotor. Dizzy seems solid in it's mounting. Belts: Uh-oh! I can deflect the belts with one finger. I know belts have a high-tension side and a low-tension side but perhaps my belt has stretched beyond limit? I have a factory service manual to follow, but any belt service procedure in layman's terms would be helpful as cross-reference. :] Noah
Hi :]
She's a Cali girl. It's made getting parts interesting since all GL's around had disintegrated 20 years ago. I rust treated her 80% of the way this year, and next year I'll be more thorough, addressing all the rust I can but most is up front underneath near the steering rack, and near the base of the windshield. I've been to Michigan for a replacement dual range transmission, Minnesota for a huge parts lot, and Illinois for an EA81 (only 60k miles!) which is my engine-swap if push comes to shove and I cannot source an EA82. All parts that aren't listed online are basically unobtanium, but that makes it fun. :] Noah
I did not purchase the belt kit, but if you have any OEM CV's up, then I've probably at least looked at them, been buying those like crazy lately. The reason my car is sitting is I blew the passenger DOJ boot, which sits right above the cat for some reason (can't imagine that's good for the grease nor boot.) So I'm taking the time to address old gremlins. I'll check the CTS, dizzy, and vac lines (I should be replacing those and their fittings anyways since I'm pretty sure the fittings are almost all original. But the rat's nest has always appeared intimidating.) I have a continental belt kit which has new idlers and I believe I have a new OEM tensioner as well, so I'll be checking that too. New fuel filters are on the way. Under hood one was WIX and I've seen others on here lamenting about them. Could it be an intake boot issue? I have a new-used one on standby. :] Noah
'89 GL SPFI. Has had an idle issue since I've bought it (6 months ago). RPM's will flutter approx plus or minus 25 RPM with idle set to 750 RPM. It will continue to flutter until 1250 RPM. Along with this is a rattle-tick that is too fast to be a cam or lifter (the noise comes from the center of the engine). It will stall when cold unless I keep the accelerator held above 1000 RPM until the needle reads just above cold. RPM's will not increase when cold, it wants to but it sounds like it bogs then catches itself, leading to a loping-idle. What's been replaced: Plugs, dizzy cap, rotor, ignition wires, coil, IAC valve, coolant temp sensor, thermostat, radiator cap (this has helped the issue, but it still lopes) My ideas: Timing issue, water in the fuel system (it sat about a month while doing full suspension work), some sort of vacuum leak (haven't tested with a gauge), fuel pump or injector issue, a computer issue, a ground/harness issue Any guidance or pointers? Hope you enjoyed the novel :]
Hi :]
Forum noob, From central Wisconsin, bought myself an '89 GL wagon (Dual Range, oohlala). Currently my daily and what I'm using to gain experience repairing my own vehicle. There will be questions.
