Everything posted by 4x4moose
What do ya think about this steering?
4x4moose replied to markjw's topic in Old Gen.: 80's GL/DL/XT/Loyales...
what aa doesn't make lifts anymore? lets see some pics! any problems with the lift? -
sean here, yes that is a non power Steering Knuckle Extension. so when are you goint to get one of those browning 50 cal. from AA and mount it on top of your ride so you can really get some hunting done?. oh and my 3 good pugs could be up for sell soon, just have to see how my t-leg is going to do
i just got myself a 92 tleg to add to my collection, and well she has a few problems so what. the car likes to idle high like 2-3k and sometimes will kick down but she takes her time to do so, but if you turn her off then back on she idles just find till you give it gas again then right back to 2-3k. i tried to test the tps, according to my haynes manual it says to test the 1 and 2 pins but i get nothing at all, i tested 3 and 4 to c what hapens and i get a low reading with the throttle closed and as you open it the resistance increase. is there anything else that i could be over looking that would cause such a problem? a good vacume leak is the only other thing i can really think of or egr but i don't have a vacume pump to test it. what vacume lines would effect the idle like so? all or just a few?
i was told it was a bushing that i could replace.
so i think its time to rebuild my disty. my tach is jumping any were from 500 to 2k or more and there is major play in the rotor like 8th of an inch or so and the new cap has some deep scrach marks on the pickups for the rotor hiting them. is there any thing else that would cause my tach to jump like that? is my disty going to crap out on me at any time? how diffcult is it to rebuild a disty? i have a spare but its needs to be rebuilt to.
oil pump broke off in block, ea-81fixed!
4x4moose replied to 4x4moose's topic in Old Gen.: 80's GL/DL/XT/Loyales...
damn that was to easy. i started beating on it and it came out. so happy, i thought that i was screwed. thanks everyone for your help! -
mcbrat, that what i'm going to do. i already broke a piece, and now a whole lot more has to come off, only if i had a big hammer and a sharper chisel. i think the peice inside the bore does spine the tinnest amount. now i get to stay up late and get up at 5am. is the metal the oil pump is made of softer then the block? -
yeah the round section is broke off from the rest of the pump. give me a sec and i will get some real pics up, i forgot about the roommate's cam:lol:. i guess you could say it was almost as if someone glued it to the block. pic 1(left) is whats stuck in the block. 2(right) i whats came off the motor. -
were it is in red and then some of the flat area. i would be easer to explain it to someone that knows ea-81. i have now drill or tap, that would work if i had them. oilpump.bmp -
so i got the crank pulley off. but ran in to a bigger problem. if i had a picture it would help me explain it all. i have part of my oil pump broke off in my block and not sure how to go about removing it. 1. i don't want to mess up the mateing serface on the block. 2. i don't have a whole lot of tools to work with right now. a hammer and chisel is about it. so any ea-81 masters around tonight?
i like my mwe's just fine, i've put about 10k on them and haven't hear any clicking yet and they are powercoated blue to!
EA81 4sp D/R to ?? trans swap
4x4moose replied to Zebisko's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i know who knows, you need to talk to brat avenger. i believe he did it on his brat. i was talking to him cause i wanted to do it on my hatch. -
Allied Armament Update 300 Hp Wagon
4x4moose replied to Allied Armament's topic in Old Gen.: 80's GL/DL/XT/Loyales...
yeah you can say that might make your pants wet! -
so if you are stanign in front of the motor (ea-81) witch way does it spin?
you guys like tricked out brats? (pics)
4x4moose replied to HATCHY's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i wan't some rims like that for the hatch. -
i have no idea why its not working i've done it before to replace a front manin seal. but i think i put the end of the pipe on diver's left and i used a real braker bar.
would that be drivers right on the ea-82? i've have tried it on both side and it didn't loosen it
yeah that was my next step, go to are ************y rump roast ace hardware. and a possilbe wet bike ride.
i need a braker bar so i can remove my main pully so i can take off my oil pump, anyone have one that i could use for a few minutes? i tried a rachet and a peice of pipe but it just kind of bent and broke the pipe. anybody got any other tricks? i havce a tourque wrench but i have always been told not to use it as a breaker bar but its the only thing that is long enough (i'm trying to use my starter to brake the bolt loose, some of you know what i'm talking about).
ea-81, i didn't mean to post that twice.
ea-86, i didn't mean to post that twice.
is there any way i can get you to go look at yours. i'm talking about on the other side of the firewall in the engine comaprtment.
they don't seem to be breaking in the same place all the time, i look i didnt seen an burs that might be cuting the couble. i just need to get it overwith right now cause i have to drive home to night and i have a lot of ************ to do to day, i was going to try and find out when i had more time.
