Everything posted by Eikari
legacy struts on Impreza Coupee=bad knock?
Eikari replied to dome24's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy rear strut on the right is knocking bad when i drive over a bump. Have checked the nuts on the upper strut mount and they seem to be tightened properly. Could it be that the top nut on the shock is loose?
Coolant temp sensor
Eikari replied to subestyle18's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks!
Coolant temp sensor
Eikari replied to subestyle18's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBut do you have to remove the intake manifold to replace the coolant temp sensor?
Coolant temp sensor
Eikari replied to subestyle18's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI´m now trying to replace the sensor and having a few problems. 1) How is the electrical connector disconnected from the sensor? 2) Do i have to take the manifold off to replace the sensor or can i just use a deep socket to get to it properly? Thanks in advance Einar
subaru police cars?
Eikari replied to Jack in Norfolk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSubaru Legacy are very common as police cars here in Iceland.
Fluctuating Idle
Eikari replied to alec_syncro's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXClean the Idle Air Control valve or replace it.
Air control valve
Eikari replied to Eikari's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI´ll probably get a used IAC valve soon at a parts sale. But does a IAC from 1.8 or 2.0 subaru engine fit to a 2.2? Are they the same or is there some difference?
Air control valve
Eikari replied to Eikari's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe IAC valve is very expensive. I cleaned it last summer and the car idled smoother for some time. Last thing i want to do is to buy a new one because i´m a student! What can i do to make it last longer, cleaning it or some adjustments?
Air control valve
When i start the car cold, it sometimes runs very rough and the rpm start to descend and finally it stalls and it shows a CEL light. I checked the code and it was a Error code.24, which is the air control valve. Is it the same as the idle air control valve or is there a another air control valve on the engine that i don´t know about? The car is ´91 Legacy 2,2.
What size
Eikari replied to Eikari's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, 19 mm is the right size. Don´t know how much wear was on the old PCV valve but i doubt it has been replaced before. In what areas of engine does the PCV affect the engine. In what areas should i see improvement, better mileage, less fuel consumption?
What size
I´m gonna replace the PCV valve. What size of socket do i need?
Change the steering wheel
The steering wheel on my ´91 Legacy is very worn out. I can twist the rubber on the wheel and i´m not comfortable with that, want to have it stiff! Do steering wheels on newer gen. of Legacys and even Imprezas fit on my car or are they different? And also, do i need special tools to get the wheel off?
Waterpump
Eikari replied to Eikari's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI also have one bad rear wheel bearing and am going to replace it soon. Should i just change both wheel bearing or do they wear differently out?
Waterpump
Eikari replied to Eikari's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes i changed the timing belt recently but didn´t think about the other subsystems, such as the oil and waterpump:-\. What about changing the fuel filter, OEM or Japanparts?
Waterpump
Thinking about changing the waterpump as a preventive maintance. Is the OEM WP the only one you trust to use. I was wandering about buying a WP from Japanparts as i assume it´s cheaper. And also what seals should i replace on the engine. Is it the camseals, crankshaft, oilpump 0-ring, valve covers. What am i forgetting?
96 Impreza OB Wagon Differential Fluid
Eikari replied to sregor13's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOn my Legacy it´s recommended to use API Gl-5 SAE 80W-90 gear oil.
Genuine Subaru Coolant
Eikari replied to Chris4141's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat chemical cleaner do you use to remove rust and and scale from the engine and cooling tube surfaces? I saw it in Haynes manual that the flushing action of water will just remove sediments from the radiator but not the rust and scale.
Ticking from motor
Eikari replied to Boddi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI once owned a Subaru 1800 and one day the started to tick horribly! This classic Subaru symptom is because dirt gets into hydraulic lifters and the HL therefor can´t refill themselves. So the solution is and it WORKS! Change the oil in your car and add one liter of ATF with the motor( if the oil capacity is 4 l , use 3 l MO and 1 l ATF , don´t overfill the engine!) Then let the engine run for some time and maybe drive 20-30 KM. Then change the oil and filter . Try using 10W-30 oil. This worked for me and hopefully for you.
Erratic running Outback, surging, code P0172
Eikari replied to TheCorkans's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck the tightness of the spark plugs.
Brake problem
Eikari replied to Eikari's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe rotors are relativly new . If i step on the brakes with normal pressure they squeel. But if i step hard on the brakes the squeel stops. Could anyone show a pic of how the "Shims" look like?
Subaru capital of the US?
What is Subaru´s marketshare in U.S?
normal AWD resistance?
Eikari replied to Midwst's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI can feel that torque bind if i´m taking tight turns and so on. But isn´t just usual to have some torque bind on a 4wd. But it probably increases as the drivetrain and tranny get more worn out.
Eikari replied to Midwst's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat is the "figure 8 test"?
Front wheel drive?
Eikari replied to Eikari's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell it seems to me after reading the post that there isn´t any gain in fuel by having the car FWD. Probably not good for the drivetrain. The FWD circuit is only i think for when towing the car or have a mismatch tire.
Front wheel drive?
Eikari replied to Eikari's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI got a new tire which is the same size as the others. I was just wondering if i could save some fuel by having the car in FWD
