105
The wet clutchpack on that car needs the Duty Solenoid C to be open to un-pressurize the plates. That's the AWD system, the clutchpack and C solenoid control how much torque is transferred to the rear diff. Also, the rear diff on that car may have been Viscour Limited Slip - it might be bad now too. With no pump running and no TCU controlling the valves, the plates are in contact and the wheels are causing a bunch of stuff to turn with no fluid circulation so, everything heats up. Dunno if there could have been a pre-existing problem but, the tow didn't help anything.
Probably just the nature of the faulures involved. The towing likely burned up some clutches/bands (I'm no expert OK?) but the pump and seals seem to be intact. probably explains why reverse is OK. It wasn't towed in reverse and that clutch/band wasn't contacting anything that could cause wear. If it is affordable, your tranny may 'only' need some friction materials/parts replaced to work again (maybe just briefly though, could be risky,and other moving parts 'could' have had undue wear since the fluid wasn't being pumped through. Local heating of gears, etc. may have shortnend the lifespan of those parts. ) - it's just that a used tranny may be a cheaper way to proceed. Even the owner's manual has extensive warnings about towing the car. Some 5 speeds and I think some newer cars can be towed 4 down(with speed/distance limitations I think?), but the 4eat and 5eat (I think?) AWD models can't tolerate it. Even using the donut spare comes with speed/distance warnings and requires use of the FWD fuse on some Soobs.
On that Impala, I started with a hammer on the turned-around axled nut after usimng some PB Blaster. I eventually had to rent a huge gear-type puller to use on the hub and use the torch AND use the impact on the puller AND hammer on the puller. It was crazy stuck. (the first puller I had under the lug nuts, a lug nut stripped and shot around the garage and either it or the breaker bar handle hit me on the thumb - lucky I was'nt severely injured. had to buy lug nuts.. it can be frustrating working on cars) hope yours is easier. The 2 Subarus I've done, I just pushed the axle out with my thumbs! you might look around youtube for some videos.
the bearings would have to be monumentally bad. should be easy enough to put a vacuum gauge on the car just to confirn it's OK. There is a vacuum check valve in the vacuum line going to the booster. i have read of them getting moisture and freezing in the winter. I suppose it's possible they could get gummy or otherwise fail. they are supposed to maintain enough vacuum in the booster so you have a coupla easy stops if there's an engine failure on the road. I'd say there's a good chance you lost booster vacuum after you parked the car. Not sure why though. Booster leak or check-valve problem seems likely though.
You didn't take the strut mount nut off the strut did you? The 3 small nuts on the bearing mount come off and the unit comes down with the spring still compressed. Or has the car been in a wreck and the area's sheet metal has been deformed? Um - maybe you could post a picture of what you're dealing with.
I guess I thought you had no way to lift more than one side at a time. when I did my 03, I had the entire back up in the air - jackstand on each side. dunno if older models are the same, but i still had to use the scissor jack to push the hub down a little, and a floor jack to lift stuff a little to make getting that lower bolt in and out easier.
No ofense intended but, we get the entire range of car owners here and I do sometimes risk offending people by asking about basic stuff. If you check the oil regularly, then it wasn't underfilled at the last service. Recently, there have been threads where folks discovered the service guys had under or overfilled the crankcase during an oil change. Hmm, maybe some odd kind of PCV valve problem. They can get gummed-up and lead to some increased oil usage. Might need cleaning/changing. Inexpensive.
If the noise seems internal, the overheating episode may have damaged some bearings. Wonder where the oil went recently? Sending an oil sample to Blackstone labs might help. However, I'm betting an experienced soob mechanic will be able to tell you as well. fluids are the life-blood of your car, some moreso than others but, they need regular attention and occasional changing. Having a rattle tell you to check the oil is not good.
Split repair CV boot for newer Subarus?
1 Lucky Texan replied to mtsmiths's topic in Products for your Subaru
Decades ago I tried one to repair an outer CVJ on a '78 Honda. it didn't last 3 weeks.
