Everything posted by UMT
HELP! No start 99 Impreza Outack
UMT replied to UMT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNevermind! Got on my knees, got under dash and jiggled the connection a bit for the clutch switch,,,,,,,,,, and it started right up. Must just be the cold weather.. Thanks
This is odd: COLD here in Northwoods WI.! I've had my 99 Impreza Outback Sport in retirement since the fall. Wanted to get the car started up to use for a project. Made sure battery was charged (Brand NEW battery) Ye olde Suby fired right up! Ran it for about an hour. Get up this morning and go to start the car and the lights come on in the dash, the 'ding' starts going off as I have a key in the ignition and I make sure the clutch is all the way to the floor as it's a manual,,,, and it will not turn over. If there is a 'click' when you hit the start button, it's so faint I'm not hearing it. Odd. Get my HD marine battery out of the garage to jump it,,,, same thing. Odd. That battery is fully charged. Jump it with my Saturn Vue (New battery AND a new alternator) and the same thing: nothing.... Any idea what is going on? I pulled the battery cables this morning and cleaned them up with a wire brush. They didn't really need it but I did it anyway. So, at the moment, I'm trying to figure out what might be going on here. Any ideas?
Need forum help: How to get REALLY tight nuts off?
UMT replied to UMT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHOW IT ALL TURNED OUT: Well, after trying everything under the sun to get this axle nut off, I finally broke down and visited a small local shop and asked if they wanted to do the work. I told them about the nut situation. They looked at it and quoted me a very cheap price. The car was fixed and now drives like a new one. I asked the tech who did the work about the nut. He said an impact wrench wouldn't budge it so he ended up heating it until it was cherry red with a torch to get it off. I sure wish I would have thought far enough ahead and tried to get this nut off before I ordered the parts and started the job. Then again, I've not had that much of a problem in the past. Thanks to all for the suggestions and those who PM'd me offering help!
UMT replied to UMT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks all! I have the nasty feeling that this is going to be a tough one so I'm going to break down and buy some 3/4" stuff. I have a several repairs that are coming up where these might come in handy. Sorry for the inadvertent sexual slang. I'll be more careful in the future knowing that some of you guys are still thinking first with your 'other head.' Ha.
UMT replied to UMT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBy the way, I edited my post: I'm using a 1/2" ratchet... Any huge advantage to going to a 3/4" ?
UMT replied to UMT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm replacing the bearings so I haven't been real worried about that part.
I posted recently on this Harbor Freight front wheel bearing kit that I am going to try out. Picked up the kit yesterday. Started on the job today and got as far as the front axle nut and I can't get it off. Put a propane torch to it for about 5 minutes, doused it in cold water, (a 'trick' that I've used in the past with great success) put my trusty electric impact on it and it wouldn't budge. So I put a good 1/2" ratchet on it with a piece of pipe and ended up breaking the end off the ratchet! (Aaargh) I should also mention that I soaked it in Power Blaster for about 8 hours before I started. I live in the boons, work on my own stuff, don't have a big air compressor, etc... In applying heat, how long do you need to put the heat to it? (I already assume that maybe this 5 minutes of propane torch probably wasn't enough) So, Forum Folk, let's hear all your tips on how to remove a really hard nut. (bolt?) Thanks, UMT
Front Wheel Bearing Replacement Tool: Anyone tried these?
UMT replied to UMT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFunny you should mention the HF Strut Spring compressors. I bought a set of those too to replace the struts on my 96 Geo and soon on my Suby... I have to tell you I was really hesitant to get into replacing the struts. I had bad thoughts about rusted bolts, twisting off bolts, compressed springs flying around killing my dog and stuff and a extremely nasty job BUT, I finally got started last week AND it turned out to be a easy job. Electric impact (I don't have a big air compressor), can of PB, HF spring compressors and off we go! The HF spring compressors worked great. Well designed for safety. Switched out 2 rear struts in about 4 hours. I buy HF tools alot because I just can't justify spending the big bucks on tools that I only use on the occasional job. If I were even a semi-pro and used my tools alot, I'ld be buying brand name, highly regarded stuff. As an example, I use my trusty electric impact alot and therefore, instead of buying HF, I bought a brand name one. (I can't say enough about electric impacts. I had one of these zip off an axle nut in the dead of winter when a good size rented air compressor and impact wouldn't budge it) I've read alot of reviews regarding the 'drive bolt' on this wheel bearing set and if I have to pick up a better bolt at a hardware store, I'm still better off. So, I hope to get to this job sometime this week. I'll be sure to let everyone know how it all works out.
UMT replied to UMT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX"HF also sells a 12 ton press for around $120-130 I believe" I had no idea that HF had that many presses! I'ld get one but then you still need the bearing adapters so I'm just going to try this kit. If I did alot of bearing work, I'ld buy a press but hopefully, I WON'T be doing alot of bearing work! Ha. I just did a YouTube search for 'wheel bearing replace' and there is actually several video's showing guys using this type of kit to R&R bearings, front and rear, if anyone else is interested. Like I said, with 20% off, if I get thru a total of 2 uses,, I'm ahead on the dollar side of it. Any more than 2 is gravy. Like to hear more comments from others but I will post again when I get this done so everyone knows how it went. Probably won't be until the end of the week tho.......
99 Impeza Outback Sport: Ok, I live in the boons. EVERYTHING out here is worth gold! Unless you want to sell something, of course. Want to replace front wheel bearings on my Suby... Talked to a couple local shops, and quite frankly, they are nuts. If I want to pay 120.00 hour for labor, I'll spend the money to take it to a Suby dealership. At least there I know someone has probably worked on a Subaru before. Anyway, handy gent that I am, I got to looking closer at doing the job myself. I have the tools I need with the exception of pressing in/out the bearings. (Yeah, I checked with the shops on just doing that too, and they are still nuts) So, I'm digging around 'Ye Olde Harbor Freight' online and spot this kit,,, something I've never seen before. http://www.harborfreight.com/fwd-front-wheel-bearing-adapters-66829.html So, I read the reviews. Of course you always have the few 'this is krap!' reviews but most of them reviewed the product favorably. I also looked for the same type of thing on Amazon and, lo and behold, they have the same thing for $50.00 more and the reviews are almost identical. (It appears the main problem occurs when guys try to put a impact wrench to turn the bolt and it strips the threads. ) I looked on YouTube and there is a young guy using a set like this to R&R wheel bearings in his front yard and it doesn't look like that big a deal. HF has also got a 20% off coupon going on so it's kind of a no-brainer IF, I say IF, the product works as advertised and the reviews that I have read are accurate. Yes, it would be 'slightly' more than pulling the hubs myself and having a local shop do the press work but I would own the tools, I could always sell them if I don't want them, and/or will hold onto them for the next job. Question: Has anyone HERE used a tool like this to R&R wheel bearings? Thanks, UMT
Getting a wheel off the rim!
Thanks to all. The wheel sat, soaked in PB, all nite. I got a 6' long piece of steel behind it this morning and after two firm tugs, the wheel popped right off the hub. Ultimately, it took me longer to get the wheel off than it did to remove the strut assembly! Ha.. I've had wheels that were 'sticky' in the past but none this bad. Thought I'ld better check with the board before I really screwed something up. Thanks!
Thanks. No, I'm not about to drive around like a nut with no lug nuts. Sorry I didn't explain the situation very well.
Folks, I'm generally posting about my 99 Impreza Outback Sport but about six months ago, I picked up a 96 Geo Prism from a kid. Great engine/trans (Toyota) and I knew it needed new front wheel bearings and a set of rear struts. Long story short: for a bunch of reasons, the car sat outside in the No. WI.. weather for six months. Got to work on the rear struts today and ran into a snag trying to get the rear tire off! Aaaargh. Whoever this kid had working on the car, obviously used an impact wrench on the wheel lugs and they were REALLY tight. Now I can't get the rim off the wheel. I know by reading the forum that someone had once suggested loosening the lug nuts up and driving around crazily (I can do that!) but I'm reluctant to do that UNLESS it's the best and fastest way. Beat on it with a BFH,,,,, (big F hammer) and got nowhere. Sprayed it down with PB Blaster and going to let it sit overnite. So, I need some ideas. I know this has been talked about before but I couldn't find it in a search. Thanks, UMT
Gas Tank Filler Tube Solutions?
UMT replied to UMT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah, that's what I did to solve just the issue of dropping gas. Used black 'gaffers tape.' Product used by musicians/sound/stagecraft guys. Like duct tape only stronger and stickier. Will probably end up biting the bullet and replacing with a new one. Thanks for the reply's!
Ok folks, here we are AGAIN with my 99 Impreza Outback Sport. I bought this car with 105k on it and it now has (apx) 245k. Actually, it's been a great car BUT it's at that point where everytime I turn around, something needs replacing. Noticed gas leaking out of filler tube the other day while on a long trip. Got home, pulled the plastic cover over the filler tube (broke 2 of 3 screws, tons of mud and other crap stuck in there) and sure as shootin,' the filler tube has developed a quarter size hole (rust!) about 6" down from the gas cap. The sensors, etc.. up there are full of rust! (sigh) Any ideas on a quick fix for these? I'm really at that point where I don't know if I'm going to keep the car much longer and I just HATE dealing with all the rusted bolts/screws etc.. involved in a total remove and replace. Searched the forum but still could use some ideas................ Thanks in advance, UMT
Inner Tie Rod? Outer Tie Rod? Ball Joints? or Struts?
UMT replied to UMT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOk,, I've been paying close attention to my issue since I made the original post. Got the car up in the air today and checked the tie rods and there is no movement at all when I grab the tire and move it side to side. NONE. Nice and tight on both sides and they look fine also. Checked the sway bar links, etc.. and it looks like those have been replaced. Ball joints look terrible. Rubber all torn up, etc... So I think at this point it only makes sense to put new ball joints in and see what that does. Any hints/tips/tricks on replacing these? While I'm at it, anyway to check them? Thanks, UMT
UMT replied to UMT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks for all the suggestions. Will let the board know when I get it figured out. Going to start replacing stuff until it goes away!
99 Impreza Outback Sport, 5 Speed, 237K miles.. I developed a slight 'knocking' in the front end when hitting bumps. Also developed a 'wheel shimmy' about the same time. Newer tires and I'm sure alignment and balancing are correct. I first thought it was probably front struts. I got underneath (both wheels) and cannot find any play in the ball joints or outer tie rod ends although rubber covers look rough on the tie rod ends. Leaning towards tie rods as I noticed the 'knock' when going going over a very slight bump in the road the other day. Bump shouldn't have been enough to put much strain, if any, on the struts. Also would seem to be likely culprit for the wheel shimmy??? Just finished watching a YouTube video on tie rod replacement and realized that this could very well be a INNER tie rod issue???? Put car in the air and check for play in the wheel??? I fully realize that with the amount of miles on this car, it's probably time to replace them all and that will probably happen part by part in time but would like some thoughts on the most likely culprit now. Thanks, UMT
OT: Anyone wear rubber gloves while wrenching?
UMT replied to UMT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOk guys, thanks. I thought it might make alot of sense so as I conveniently have a handy dandy HF coupon for a hunsky of the nitrile ones,,, I'll give them a try.
Watched a YouTube video the other day and a guy was wearing rubber gloves while working on his car. He said he didn't like getting his hands dirty. I watched a few more videos and noticed that some guys were wearing rubber gloves. Got me curious as I'm a musician and try to take care of my hands. (probably the only reason I didn't go into wrenching full time) I've tried working with 'mechanics' gloves and miss the sense of feel when threading bolts/nuts, etc... Curious to see what yous guys think. UMT
Dash Speedo Light blown?
UMT replied to UMT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX99 Impreza Outback Sport: Took a quick look at the dash.. Have never had to remove anything like this before... I take it the 'bolts' are underneath the dash? How about a quick lesson, tips on how to remove? Thanks, UMT
DIY - Wheel bearing replacement?
UMT replied to UMT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX99 Impreza Outback for those who are interested. I went and looked at the tool and wasn't sure it was large enough to do the job so I decided to forget about it. Will just remove the hubs (front) and take to the shop. If I would have had my act together when I ordered the bearings,,, I could have just ordered the hub assembly for just a little bit more. That's what I'll do next time I'm replacing bearings.. Thanks, guys! UMT
Guys, I need to replace some wheel bearings. Harbor Freight has a set of bearing drivers for 15.00 (good enough for my extremely occasional use) or am I just better off taking to the shop? Never done it before and would like opinions on whether this is a PITA or better off to spend 20 or so at the shop. Thanks, UMT
99 Impreza Outback Sport: all of a sudden, my speedo is dark from 0 - 30 MPH...! I'm assuming a blown led??? How hard to remove dash and replace? Thanks, UMT
Trouble code 420 and 440?
UMT replied to UMT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOoops, looks like you gents are correct. Is there a quick fix? Thanks, UMT
