UMT
Everything posted by UMT
I have a 99 Subaru Impreza Outback Sport 5 Speed Tranny with 195K miles on it. Started a different job and am traveling about 80 miles a day. Anyhow, I've done different things to improve mileage and so far, I've got some improvement but I was browsing the forum over the weekend and there was a somewhat related discussion that got me to thinking so............................. Tell me if removing the FWD fuse may improve my gas mileage and/or if there are problems that can pop up doing this? Thanks, UMT
Ok, so I was changing the spark plugs on the 99 Subby Outback Sport the other day and when I pulled the spark plug wires, they are all covered with oil! Got the plugs out and the plugs are covered with oil. Spark plug tips are nice and white. Car doesn't seem to use any oil or smoke. Runs like a top. Any ideas? Thanks, UMT
That might be it. When I went to put the neg cable back on, fully tightened, it was still loose. Put a finishing nail between the cable and post as a temporary fix. My keyless remote still doesn't work. Going to replace the battery in it tomorrow and see what happens. All is ok now, but strange stuff...
There I was, leaving work in my 99 Subaru Outback Sport. I turned on the key, started the car and all of a sudden, my dome light, marker lights, open door light on are flashing, and the doors would automatically lock like every 5 seconds????? WTF, over! Has my car been invaded by aliens? Poltergeists? Oh yeah, my doors remote control doesn't work all of a sudden? Somebody tell me what is up with this! Thanks, UMT
Well, guys! The light went out by itself! For about 1 1/2 weeks. Then it came back on! So, I did the Seafoam thing: 1/3 brake booster vacuum, 1/3 in the crankcase and the last third in the gas tank. (U Tube 'Seafoam' and there are several video's) 1 day later: light is gone. Getting MUCH better gas mileage! Car is running great with 193k on it. I'm still looking at replacing the PCV valve and going to test the oxygen sensors but I'm also going to change the plugs as they are overdue. Question: Alot of guys say NGK. Standard or 'Platinum?' The last set of plugs I put in were a real fancy pair by Bosch that were supposed to give me 2-3 MPG gas mileage and it never happened. Kinda soured me on paying big bucks for plugs. What makes the 'Platinum' so much better? Any experience? Thanks, UMT
There I was, putting new rotors/front brakes on Ye Olde 99 Outback Sport! The drivers side went slicker than snot. All was going well on the passenger side until I got to the LAST bolt! (why is it always the last bolt?) It's the bolt that holds the part of the brake assembly to the 'wheel.' Try as I might, I could not get that bolt to budge. Lubed it all up with Liquid Wrench, let it sit and tried a electric impact wrench on it, to no avail. Got out a longer 1/2 " drive socket wrench and put in on the impact socket, put a piece of pipe over the wrench and using my almost Superman like strength, I got it to move! I says: "Aha!" I pulled on it to turn it some more,,,,, and the bolt twisted off. A friend of mine had suggested putting some heat to it first, but I didn't! (Live and learn) So now I'm looking at using an 'EZ out' to get that bolt out. It has to come out in order to get the old rotor off the wheel. Any suggestions, hints or whatever on making this job a little easier? What is the size of that bolt anyway? Thanks, UMT
1999 Impreza Outback Sport. Engine light came on about a week ago and finally got to Autozone and the put the code reader on it. 1) Rich air/fuel mixture 2) Oxygen sensors 3) plugged catalytic convertor... Guy who checked it for me was a Subby owner. Said first check the air cleaner. Looked at it this morning and it is fine. He said to remove the oxygen sensors and clean them, that may clear up the problem. Another guy I talked to said that was a waste of time. Lastly, pull the catalytic convertor and see if it's plugged up. So, tell me about oxygen sensors? Are they able to be cleaned? If I have to replace, are the aftermarket parts any good? Do I need a special tool to pull them? Checking gas mileage and thinking it may have gone down some. Any and all advice appreciated. Thanks, UMT
Ok folks, Getting ready to replace front brake rotors as they are long overdue for replacement. Will replace the pads (which I've done several times) while I'm at it. I'm thinking the axle nut may be a be-otch to get off? Do I need a impact wrench? What size is the nut? 99 Impreza Outback Sport.. Steer me in the right direction before I get started as I now live out in the boons and am miles from a parts store. Thanks, UMT
Ok, wired up my 99 Outback Sport with a trailer hitch as I'm moving this week and pulling a trailer. Looks like the last time I closed the hatch, the trailer wire was right in/or by the U hook that holds the hatch closed. Now I can't get it to open! The 'hook' that goes thru the 'U Hook' that keeps the hatch closed,,,, does that 'hook' on the passenger or drivers side??? I'm thinking I can get a screwdriver in there to help release it???? Any other ideas???? Thanks, UMT
Well, decided to just get a new knock sensor when I found one on Ebay from Chandler Motors in Wisconsin. $20.00 DELIVERED. Got it in 3 days. Pulled the old one and could not see any cracks of any sort but where it sat on the engine block was a bit corroded. Probably could have just cleaned it up and used it again but decided to install the new one and kept the old one for a spare, should I ever need one, which is probably doubtful at this point. Total R&R time, about 20 minutes. Piece of cake. This car always ran well but it seems to run even a bit better with the new knock sensor! Makes sense I suppose, now that the 'little men with the very fast calculators' are getting better input! Ha. Anyway, thanks to all who posted for the information and advice. UMT
