Easiest way to replace clutch
Last time i did this job, i pulled the engine. It was easier that way, but now that my Sube is lifted, would it be easier to drop the tranny instead?
The throwout bearing in the 84 Wagon is gone. Makes a god awful noise while the clutch is in. Doesnt have much longer, and i need to replace it soon... and still have time to drive to work the next day. I dont have access to a hoist or a tranny jack, so im trying to juggle my options.
-Brian
use a jack to support the tranny and do a tranny drop.....
the DOJ pins; the bolts and stud'd nuts that atach to the engine; the rear shaft's carrier barring support's 2 bolts; the tranny support bar's bolts; the two 8mm nuts on the clutch cable and the HH unit; the speedo cable at the speedo(easier to pop it off then unscrew it from the tranny......
JUST WATCHOUT for the gearlube dripping out the tail of it tipps to far aft!
did I forget anything?
if i were you i'd stick to pulling the engine a lot less to deal with and it beats laying on your back the whole time that and it's quicker
but....
we don't know...
1. did he use an engine hoist? and does he have use of it now - for this event?
2. garage space and temp control environment for cold ground (IE cardboard and a blanket for distance from cold cement)
3. which is this person *More comfy with*? as well?
You an a friend can lift the engine out, and put it back in.... problem with the tranny is that it takes three people if you don't have a transmission jack to put it back in. It *can* be done with two people - using a rope around the tailshaft of the tranny, and closing that in the drivers door, but you still need someone to lift the front of the thing while you crawl under it, and manhandle it into place. I would pull the engine.
Actually - if your good, you don't even have to pull the engine - on an EA81, you can simple pull it forward - with the radiator removed, there's enough room to pull the engine forward, and off the tranny. It's tight, but if your only replacing the release bearing..... should be able to do that without pulling anything. Just a thought if the clutch is still good.
welll GD I disagree on the need's and "*can*" factors but, hey its all good.
that said I'm goin to bed now... good night and good luck(as always)
I dont have a hoist or jack (as stated in my original post). The garage is small, but its not as bad as working outside by all means.
I think i'll just go rent a hoist and pull the engine. it needs a re-seal anyhow.
-Brian
that's what i meant GD thanks for explaining. not to pull the motor but just to pull it forward :D
and if you have an extra person you could do it in a hour with nothing but hand tools EM
