October 25, 200916 yr so my motor is bleeding to death from possibly several places. it just wont hold oil. but i just got enought money to just put a new damn motor in the thing because it will be trying to seal it. my car is a 1990 legacy ls with the 2.2 and the motor im getting is from an auto wrecking yard in town which is a '93-'96 ej18. i guess they lost the paperwork on the motor, but it has good compression. my question is... is everything just going to hook up? i would like to just do this in a day, but im not sure if there are any suprises in store. thanks for the imput.
October 25, 200916 yr dude, get a seal kit and just reseal your 2.2 its easier and a whole lot cheaper than trying to make a EJ18 work.
October 25, 200916 yr Author i dont have that much time and i have enough to get the motor. i know i can reseal the motor. my question was asking if the 18 will just drop in... thanks...
October 25, 200916 yr The EJ18 will drop in. I've swapped EJ18, EJ22's, EJ25's...it'll drop right in. Swap long blocks and keep your EJ22 intake manifold. They should both have EGR but i'm not 100% versed on the 90-94 stuff so best to check if emissions matters to you. EJ18 won't have a knock sensor, but the hole and threads will be there! It's kind of a silly fix though, a 15+ year old motor is highly likely to leak. It's just a matter of time for old seals, particularly having sat in yard or inoperable vehicle for X years.
October 26, 200916 yr dud4e, you can do it in the time it will take you to pull and replace....just reseal it , put anew timing belt and such on it.all for the same price as an entire motor cheers, brian
October 26, 200916 yr I agree, a re-seal is way too easy to pass up. You can pull the motor, re-seal it, and drop it back in all within a day, easy, done, no worries.
October 27, 200916 yr i tried to tell him the same thing when we got the car and i helped him reseal the V/C's at my house, (before i got ripped off) but he didn't wanna listen.
