pickn4him Posted January 4, 2010 Author Share Posted January 4, 2010 The good news is there are no MOTOR oil leaks. The BAD news is......sigh.......it's the rack & pinion leaking. How do I know? The PS fluid is now on the low side and all other lubricant levels are staying steady. RATS!!! Quote Link to comment Share on other sites More sharing options...
nipper Posted January 4, 2010 Share Posted January 4, 2010 The good news is there are no MOTOR oil leaks. The BAD news is......sigh.......it's the rack & pinion leaking. How do I know? The PS fluid is now on the low side and all other lubricant levels are staying steady. RATS!!! Rather have that then an engine leak. Replacing the rack is easy Quote Link to comment Share on other sites More sharing options...
johnceggleston Posted January 4, 2010 Share Posted January 4, 2010 The good news is there are no MOTOR oil leaks. The BAD news is......sigh.......it's the rack & pinion leaking. How do I know? The PS fluid is now on the low side and all other lubricant levels are staying steady. RATS!!! rack or pump leak?? try some trans-x power steering stop leak first. you have nothing to loose, it can't hurt, you plan on replacing the rack anyway and it is cheap. this is the same company whose transmission fix in a botle works on the 99 auto trans with delayed engagement of gears. it worked great on my wife's 97 toyota avalon steering pump. i replaced the rack only to discover that the pump was leaking as well. the leak went from refill monthly to almost nothing. Quote Link to comment Share on other sites More sharing options...
Mike104 Posted January 13, 2010 Share Posted January 13, 2010 PS Leak could be the O-Ring on the reservoir above the pump. Cheap fix. I had a PS rack leak and after 1 bottle of Lucas ATF "Magic Fluid" it no longer leaks. Quote Link to comment Share on other sites More sharing options...
pickn4him Posted January 18, 2010 Author Share Posted January 18, 2010 So far I have tried the Lucas OIl PS stop leak. Only the smell has changed to a little differnet smell and has not stopped. I did the pump suction o-ring a while back when it was apparently sucking air & cavitating. That worked like a charm and super cheap! Quote Link to comment Share on other sites More sharing options...
idosubaru Posted January 18, 2010 Share Posted January 18, 2010 Power steering is really simple actually, nothing to it. I'd much rather do that than mess with oil pans, so what that tells me is you're way over qaulified for whatever this steering leak throws at you. Even if you have to swap racks it's super easy and Subaru steering racks very rarely fail which means used ones are dirt cheap. Quote Link to comment Share on other sites More sharing options...
