Caramanos2000 Posted November 4, 2009 Share Posted November 4, 2009 I bought a 9004 HID kit, can I just use the connector it comes with or do I have to solder the wires because the 87 GL is wired different? Quote Link to comment Share on other sites More sharing options...
crazyman03 Posted November 4, 2009 Share Posted November 4, 2009 to render a guess - the connector that it comes with should be the one to use. It goes with the bulb, should be the right gauge. If i remember correctly, you hook up the HID system to the end where the current bulbs go. and the HID Bulbs replace the stock bulbs. -Justin Quote Link to comment Share on other sites More sharing options...
eulogious Posted November 4, 2009 Share Posted November 4, 2009 What kit did you buy? I am interested in doing this as well. Post your results with pics too please! I would like to see if it really is worth the price Quote Link to comment Share on other sites More sharing options...
Caramanos2000 Posted November 4, 2009 Author Share Posted November 4, 2009 Not a problem already have them up and running. I bought a Bi-Xenon kit off ebay it was $80 shipped priority (not from china). I will post pics tonight of the results Quote Link to comment Share on other sites More sharing options...
simple monkey Posted November 4, 2009 Share Posted November 4, 2009 one thing about HID kit's is that they glare in headlights not designed for HID bulbs. Glare shields can easily be made for the bulb like the one in this link. http://www.elantraxd.com/forums/showthread.php?t=20195 with HID's installed, oncoming motorists should be kept in mind. Quote Link to comment Share on other sites More sharing options...
Caramanos2000 Posted November 4, 2009 Author Share Posted November 4, 2009 I made something like that but slightly smaller and more rounded so I could fir it over the bulb. If I made it to big the light would hit it when I turned the high beams on :-\ Works now though, cant someone turn the sun off for a seocnd? Quote Link to comment Share on other sites More sharing options...
simple monkey Posted November 4, 2009 Share Posted November 4, 2009 I made something like that but slightly smaller and more rounded so I could fir it over the bulb. If I made it to big the light would hit it when I turned the high beams on :-\ Works now though, cant someone turn the sun off for a seocnd? please post pictures, sounds very interesting. Quote Link to comment Share on other sites More sharing options...
2K4 STI Posted November 4, 2009 Share Posted November 4, 2009 Yes Pics please And a link to the kit you bought also Quote Link to comment Share on other sites More sharing options...
suberdave Posted November 6, 2009 Share Posted November 6, 2009 I bought a 9004 HID kit, can I just use the connector it comes with or do I have to solder the wires because the 87 GL is wired different? check your wires... most cars use one ground and two powers (one for high and one for low) Subarus use two grounds and one power. so you have to do some wiring to make it work. this is what i had to do when i installed HID's in my car... Quote Link to comment Share on other sites More sharing options...
