tehweej Posted November 25, 2009 Share Posted November 25, 2009 now that the weather has finally cooled off, when i go to start my lovely sube in the morning, it starts fine, revs fine, usually wont stay running unless i give it some gas, and if i try to drive off too soon, the engine will stall and wont start up again unless the throttle is wide open. then it will chug at around 50 rpm for while and then eventually picks up. other times it doesnt stall, but will be very hesistant and i have trouble getting up to 35mph until the engine is up to full operating temp. any input on where to start would be awesome, thanks guys! Quote Link to comment Share on other sites More sharing options...
98obster Posted November 25, 2009 Share Posted November 25, 2009 air, fuel or spark..take your pick. I'm leaning toward fuel. (pun intended) Quote Link to comment Share on other sites More sharing options...
Dirk Posted November 25, 2009 Share Posted November 25, 2009 air, fuel or spark..take your pick. I'm leaning toward fuel. (pun intended) I think what 98obster means is that the choke is not working. I assume its an automatic choke? Quote Link to comment Share on other sites More sharing options...
hardtail_pride Posted November 25, 2009 Share Posted November 25, 2009 Same problem. Tried adjusting screws and i think thats were i went wrong. My car is a Loyale EA82. Quote Link to comment Share on other sites More sharing options...
tehweej Posted November 25, 2009 Author Share Posted November 25, 2009 yes it is automatic choke. is that run by vacuum? Quote Link to comment Share on other sites More sharing options...
tehweej Posted November 25, 2009 Author Share Posted November 25, 2009 sorry, forgot to say its an ea82 carb'ed Quote Link to comment Share on other sites More sharing options...
tehweej Posted November 30, 2009 Author Share Posted November 30, 2009 so the choke is closed when the engine is cold, and it opens after the engine has been run. any other ideas where to look? Quote Link to comment Share on other sites More sharing options...
tehweej Posted December 2, 2009 Author Share Posted December 2, 2009 any ideas guys? might it be ignition timing? the frustrating thing is that the problem magically disappears once i hit operating temp. this morning when i tried to warm it up, with the gas pedal slightly depressed, the engine would rev to about 3k, then fall down to about 300, and then back up to 3k and back down. after a while it stopped, and ran like a top. this is killing me! Quote Link to comment Share on other sites More sharing options...
Dirk Posted December 2, 2009 Share Posted December 2, 2009 Sounds like its still not getting enough fuel. Have you fiddled with the idle mixture screw yet? If not, then try it. Anticlockwise will give you more fuel at idle. when the engine is warm set the trottle screw so that you have about 900rpm. Then turn the idle screw anticlockwise untill the rpm starts to drop, then wind it back in a little. Do you have a workshop manual? Quote Link to comment Share on other sites More sharing options...
tehweej Posted December 2, 2009 Author Share Posted December 2, 2009 i have set the idle mixture screw. and a correction to my last post, today even after it was warm it ran like crap. seems like the carb isnt getting fuel at the rate it should to stay full. when i accel quickly in 1st, its ok, then when i shift to 2nd, it runs like crap. if i accel very gently (only revving to about 2.5k) and dont gas it too much, it is ok for longer, but then starts to hesitate and run bad, if i push the clutch in and let the engine speed drop for a bit, and then resume, it is ok for a bit, and then acts up again. i plan on replacing the fuel filter soon. that was replaced when i got the car ( about 9 months ago) but it seems like there is a blockage/lack of flow from the tank to the carb. fuel pumps are pretty much go/no go right? can they go bad in a way that they would just have reduced flow? Quote Link to comment Share on other sites More sharing options...
tehweej Posted December 2, 2009 Author Share Posted December 2, 2009 so i just replaced the fuel filter, and its all better! the gas coming out of the in side of the old filter was a rather unpleasant rusty orangish reddish color. is there any way of cleaning out my tank aside from taking it off and getting it steamed? or should i just keep replacing filters every time it does this? Quote Link to comment Share on other sites More sharing options...
Logan K Posted December 3, 2009 Share Posted December 3, 2009 i think theres some chemical you can buy at autozone that cleans your tank...i dont really know. Quote Link to comment Share on other sites More sharing options...
Deener Posted December 8, 2009 Share Posted December 8, 2009 I had the EXACT same issue. I have an 88 GL Wagon, EA82, 3AT transmission. I fixed it by (firstly listening to the guys on this site): COOLANT TEMPERATURE SENSOR!!!!! - That was the majority of the issue, once it was replaced, the cold start issue disappeared. She fires right up every time, and I don't have to give it gas to start it anymore and there's no more holding the throttle open all the way anymore either if it stalls. - I bought a multimeter and pulled my CTS out and it had ZERO reading. Pulled the wires off of where they connect to the screw/thermal piece and found that one wire was disconnected - hence no reading from it. Replacing the sensor was a HUGE differnce for me and aparently it's a common issue. IDLE AIR CONTROL VALVE!!!! - Mine was gummed up so it was idling all over the place. I just took it off, cleaned it out with carb cleaner and haven't had an issue since. AIR INTAKE!!!! - Mine had a bunch of goo in it, so cleaning that out with carb cleaner also stopped it from running rough. Before I did these things, I learned how to read the ECU codes which also confirmed the CTS issue. I would suggest pulling your codes, identifying your Coolant Temperature Sensor and testing it first...if thats your issue then you will be suprised how much of a difference it makes to have a working one. Good luck! Quote Link to comment Share on other sites More sharing options...
Frank B Posted December 8, 2009 Share Posted December 8, 2009 There really isn't a good way to clean it out while on the vehicle, but if you get it off there are a lot of options. You could try electolysis(google it), You could wash it out, maybe put some nuts and small bolts in the cleaning solution then slosh it all around to knock the rust off. Then coat with POR-15 or other tank sealer so it doesn't rust up again. It may be easier to just replace the tank too. Do you fill the tank all the way every time you get gas? Allowing some space above the gas at all times is a bad idea. Moisture builds in that space and rusts the tank. It may have just been normal build up too. to be sure, change the fuel filter again at the next oil change and see what comes out. Since it's carbed and has a low pressure fuel system, you could use a clear plastic filter between the pump and tank. Quote Link to comment Share on other sites More sharing options...
ivantruckman Posted December 8, 2009 Share Posted December 8, 2009 i thought all loyales were mpfi, not carburetor ? Quote Link to comment Share on other sites More sharing options...
Frank B Posted December 8, 2009 Share Posted December 8, 2009 MPFI, SPFI and Turbo Quote Link to comment Share on other sites More sharing options...
ivantruckman Posted December 8, 2009 Share Posted December 8, 2009 MPFI, SPFI and Turbo cool so there is no choke, maby he has an IAC , or TPS malfunction Quote Link to comment Share on other sites More sharing options...
tehweej Posted December 10, 2009 Author Share Posted December 10, 2009 i always fill up all the way. it is carb'ed, so i dont think i have a IAC, and the choke is working. i will check the contacts on the cts, where is that located? also, the starter on my soob died yesterday after it stalled on a busy street:mad: so i am going to replace that this weekend, and might just replace the cts while i am at it. it has trouble starting in the cold mornings, itll start, i have to gas it a bit to keep it going, and then it seems to be running fine, but if i go to start moving it dies, i have to crank it giving it no gas for 30-60 sec, then it turns over and is fine to go (a bit down on power, but that is expected when it's cold). any ideas there? thanks for all the help! Quote Link to comment Share on other sites More sharing options...
Frank B Posted December 10, 2009 Share Posted December 10, 2009 Sounds like it's time to clean/rebuild the carb. There are plenty of posts here on the forum to guide you, and to show you how to access the idle mixture screw and to adjust it properly. Quote Link to comment Share on other sites More sharing options...
Deener Posted December 12, 2009 Share Posted December 12, 2009 i always fill up all the way. it is carb'ed, so i dont think i have a IAC, and the choke is working. i will check the contacts on the cts, where is that located? also, the starter on my soob died yesterday after it stalled on a busy street:mad: so i am going to replace that this weekend, and might just replace the cts while i am at it. it has trouble starting in the cold mornings, itll start, i have to gas it a bit to keep it going, and then it seems to be running fine, but if i go to start moving it dies, i have to crank it giving it no gas for 30-60 sec, then it turns over and is fine to go (a bit down on power, but that is expected when it's cold). any ideas there? thanks for all the help! Seriously...that sure sounds like what was happenning when my CTS was bad. Mine is located right under/beside the thermostat housing. Mine has a light green connector that has two wires running from the connector to what appears to be a bolt. I can't upload an image otherwise I would... Quote Link to comment Share on other sites More sharing options...
