December 18, 200916 yr Does any one know where to get a scanner that will read the subaru abs trouble code? Is it through he obd II plug? Thanks
December 18, 200916 yr There are scanners out there but not all will read every car. I had my eye on one made by Innova. But you can expect to pay upwards of $200 for them. And I still can't find if they will read Subaru codes. I think there is a way to get the light to flash the codes. Try searching the boards here, I'm sure it has been posted. It may even be in the USRM.
December 18, 200916 yr you don't need anything but a brain and usmb. all the info to get the codes to flash on your dashboard is on this forum. spend some time searching and you'll get it. first time i needed to i got all i needed from here and it was easy. bad sensor code, replaced, cleared code, done.
December 19, 200916 yr you don't need anything but a brain and usmb. all the info to get the codes to flash on your dashboard is on this forum. spend some time searching and you'll get it. first time i needed to i got all i needed from here and it was easy. bad sensor code, replaced, cleared code, done. mmmmmmmmmmm brains.
