logic23 Posted December 18, 2009 Share Posted December 18, 2009 Does any one know where to get a scanner that will read the subaru abs trouble code? Is it through he obd II plug? Thanks Link to comment Share on other sites More sharing options...
Fairtax4me Posted December 18, 2009 Share Posted December 18, 2009 There are scanners out there but not all will read every car. I had my eye on one made by Innova. But you can expect to pay upwards of $200 for them. And I still can't find if they will read Subaru codes. I think there is a way to get the light to flash the codes. Try searching the boards here, I'm sure it has been posted. It may even be in the USRM. Link to comment Share on other sites More sharing options...
idosubaru Posted December 18, 2009 Share Posted December 18, 2009 you don't need anything but a brain and usmb. all the info to get the codes to flash on your dashboard is on this forum. spend some time searching and you'll get it. first time i needed to i got all i needed from here and it was easy. bad sensor code, replaced, cleared code, done. Link to comment Share on other sites More sharing options...
nipper Posted December 19, 2009 Share Posted December 19, 2009 you don't need anything but a brain and usmb. all the info to get the codes to flash on your dashboard is on this forum. spend some time searching and you'll get it. first time i needed to i got all i needed from here and it was easy. bad sensor code, replaced, cleared code, done. mmmmmmmmmmm brains. Link to comment Share on other sites More sharing options...
