13mm square rear differential options
Has anyone found a less expensive off-the-shelf option for the 13mm square male socket used for the rear diff, besides the one at http://ultimatetoolco.com/drainplugs.aspx? I'm sure it's a great tool, but it's a tad pricey.
I considered getting a 9/16" pipe plug driver, and grinding it down a bit, but I'd prefer a ready-made piece, both for convenience, and to avoid adversely effecting the metallurgy during the grinding process.
I just use a 1/2" drive breaker bar, with no socket. Close enough fit for me, but I have more than a couple back-up diff covers if I strip one out.....
-Bill
1/2" drive for me too, but I thought I saw harborfreight selling a drain plug socket set last time I was in the local one
yep, standard 1/2" drive is all you need. remove the top fill plug first since you don't want to drain the fluid and find out the top one won't come out.
  • 3 years later...
I would advise using a 13mm square socket as the best best for avoiding stripped bolts. 1/2 inch = 12.7mm. A close fit, maybe, but not nearly exact.
+1 on the 1/2" business end of a ratchet, breaker bar, or impact wrench.
13mm and 1/2" are so close that I use them interchangeable except on tough situations.
BTW, the 13mm square socket can be bought at Harbor Freight Tools. One is contained in a kit that provides a selection of other sockets for $15.
Just wondering, Mr. Texan, how did you use a floor jack to loosen the differential plugs?
If hes like me i use the handel of my floor jack  as a cheater bar.
Edited by coolskaterkid
I put the breaker bar end on the pad of the floor jack and pushed up with it.
(car was on jacks)
cheater should work too.
I believe there's some type of sealant on the threads, dunno what the FSM recommends putting on there. Probably plenty of people have no problem reinstalling as-is.
I used teflon pipe tape. Looking back, probably should have only used it on the drain plugs but, I'm not too concerned about it. Not ideal I know but...
Edited by 1 Lucky Texan
