My '95 Legacy: Trashwagon10
  • Replies 1.3k
  • Views 204.7k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • TheLoyale
    TheLoyale
    Trashwagon will be making a return real soon!    I built a car created by MilesFox, only to sell it to him and then to get it back.
  • TheLoyale
    TheLoyale
    Trashwagon10 makes a triumphant return to MilesFox! We rescued the car yesterday from a kid who bought it in need of a car to get him to/from school. The outer bearing cage on the passenger side axle
  • TheLoyale
    TheLoyale
    We are The Subaru Alliance!  ____________
Posted Images
Tom, I'm not surprised this happened to you, but it still really sucks. Just be glad that you have the ability to fix the car yourself for minimal cost. If it happened to some one with no mechanical ability, they would be truly screwed.
  • 2 weeks later...
Trashwagon10 is now back on its own legs and does drive, but I have some extreme bearing noise. I put the car in the air on all 4s and it seems like its coming from the Passenger side Wheel hub. Keep in mind this was the side which was pushed into the curb.
So I am still in able to drive the car.
friken finally this site is back!
and wow it looks good~!
Thanks.
Got any pictures of your with the new tires/wheels? Post them in here if you'd like.
I don't think the summer wheels will be showing off on the car this year between gas and bills and paying the IRS it's smarter to buy my winter tires now
I hear that, I've only got $14 till next friday. This Legacy is coating me to much to rebuild and it still isn't completely fix :rolleyes:
I did not get a paycheck last week because I just came back from my week off it sucked lol
I need to start buying engine related parts now like my clutch and TB covers lol the bolts all cracked the plastic on the first turn..
and I gotta replace the two cam seals and the oil separator plate this engine is leaking like mad.
I want to have the engine done by end of Nov along with all new struts.. by that time I should be getting a bit more hours :)
Well I would save your self some money and not buy the TB covers. They only make doing Timing belts take longer and of course sometimes break due to stuck bolts. I run both my Soobs coverless and am happy about it, I can check and adjust the belt whenever needed.
I just don't like my exposed timing belt and when I go off road I don't want to have to worry about an idler about to fail..
Besides I'm going to need a few other things like the side molding for the door and all for when I do paint the car.
Only thing is I can't seem to find a part number for the spolier
The Rear gate spoiler?
http://www.subarupartsforyou.com/cp_partdetail.php?partid=12391
friken got that door lock timer out..
everyone said to check the drivers side door and I said why? because everytime you slam the glove box close the doors will lock/unlock..
and sure enough as soon as I started tapping and moving the door lock timer the doors were trying to unlock and lock and it was clicking like crazy.
it's a bit of a hassle to get to it however :-/ gotta watch out for crumbly foam.
Edited by 1-3-2-4
At least your locks work, mine are all manual for now since the GT door doesn't have the Acuator in it. Plus the harness clip doesn't have all the same prongs.
Bought a used Passenger side hub assembly today from B&M Auto for $99 supposed to get it by Tuesday. Hoping this is the bearing noise I have and not a Differential bearing.
Trashwagon10 is not dead yet.
Picture updates:
Heres the CB I put in a few weeks ago (Before it got hit obviusly)
Pulled these Tweeters out of an Outback.
Waiting on the hub.
I see your car has that same wire on the tranny too i thought someone did a botched up wire job.
Do the tweeters improve the sound at all?
That wire is for the front O2 sensor, theres a bendable clip that holds the wire away on the transmission.
And yes, the tweeters add more clairity while still have the depth of the subs. I just pocketed the tweeters from the Junkyard, Why pay when you can get them for free :-p
Hmm so it's a clip.. never knew that.. mine had been rubbing on the CV inner joint and almost cut the wire it'self
Trashwagon10 is back on the scene after two months...!
____________________________________________________________________
2 Crashes, 210,000 miles and still alive.
Aww man!!! :eek: That sucks!
Progressive better not try to lowball me,
At least he has (had) insurance.
Looks like it's come back together nicely though. Guessing you got a nice fat check out of it. :grin:
I got nothing outta it. Everything I bought came out of my pocket.
This guy is just a douche. If i ever see him again he'll end up needing Flight For Life.
makes me want to get slightly more insurance coverage on my car(s) :confused:
