Anarch Angel Posted May 5, 2010 Share Posted May 5, 2010 Right, I've been having a heating problem with my car for about a year. I can compensate by turning my dash heater on all the way, and while that's not a problem during winter (I live in Alaska), it's no fun during the summer. Besides, it's not fixing anything. This is getting to be a problem because sometimes the coolant's getting so hot that it's filling my overflow tank from completely empty to over the "full" line. I had a chat with a mechanic I know from the Subaru shop, and he said I was low on coolant after he had a look. He also said that I probably had a leak. That was six weeks ago, and since, I've probably managed to get a total of another 8oz of fluid into the system (it's full), and I haven't managed to find any leaks at all. I'll go over the bullet points here: -Thermostat is fine -Radiator fan works -There's nothing blocking my grill -There's no indication of any head gasket problems -No leaks in the line -The faster I'm going, the more it heats up. Driving on a street at 35MPH doesn't noticeably heat things up, but when I'm cruising down the highway, the temp starts rising. -The line is circulating (The dash heater wouldn't work otherwise) So, the only thing I can think of is that I've got blockage in my radiator, either from a clog or an air bubble. I'm still open to other possibilities before I try to flush the system and end up throwing away a ton of antifreeze, although I'd like to take care of this before I have to start worrying about the head gaskets. Quote Link to comment Share on other sites More sharing options...
wrxzzz Posted May 5, 2010 Share Posted May 5, 2010 I was thinking blocked radiator too. Sounds like what happened to an old thunderbird I drove to FL on spring break. Had to stop in some small town for a new radiator. Quote Link to comment Share on other sites More sharing options...
T'subaru Posted May 5, 2010 Share Posted May 5, 2010 I think your gl has the ea82t engine...yes? Quote Link to comment Share on other sites More sharing options...
Anarch Angel Posted May 5, 2010 Author Share Posted May 5, 2010 I think your gl has the ea82t engine...yes? It's an EA82. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 5, 2010 Share Posted May 5, 2010 The FIRST thing you need to do is a system pressure test. If it can't hold pressure then the system will not transfer heat well, and will eventually run low. Do a pressure check - if you can't see a leak anywhere then it could be an intake manifold gasket (coolant runs through them as well), or the beginning signs of a head gasket although I doubt that. My guess is that you will either find a small leak in one of the little hoses on top of the engine that run to/from the block and manifold or you will determine that the intake gaskets are shot. And don't forget when you are running the pressure test - test the cap too. If it holds 13 psi without any problems - probably time for a new radiator. But unless you have some really nasty, nasty anti-freeze (brown, chunky, etc) then my bet is on a leak. GD Quote Link to comment Share on other sites More sharing options...
Anarch Angel Posted May 5, 2010 Author Share Posted May 5, 2010 Alright, I'll get a pressure tester and see what happens. I'm hoping on a hose leak; those tend to be a cheap and easy replacement... Quote Link to comment Share on other sites More sharing options...
vagen Posted May 6, 2010 Share Posted May 6, 2010 my younger brother had the exact same problem in his ea81 hatch and after tearing his hair out we discovered his radiator was mostly plugged. there were just two or three tubes passing water so in town it was fine but on the freeway there wasn't enough flow to cool. If you have a no touch thermometer you can see if it's plugged rather easily. Quote Link to comment Share on other sites More sharing options...
Anarch Angel Posted June 1, 2010 Author Share Posted June 1, 2010 Well I finally got round to flushing this POS. I've got some CLR resting in the radiator right now; I'll flush it out in a while and see what happens. The damn petcock on this thing is so tiny that it takes forever to drain though. Quote Link to comment Share on other sites More sharing options...
heartless Posted June 1, 2010 Share Posted June 1, 2010 just a couple of thoughts for when you refill the system... 1. get the front end up in the air - preferably with the filler neck a little higher than the rest - this will help get the air bubbles up and out of the system. (and they can be a bugger to get ALL air out of!) 2. DO NOT use regular tap water in your cooling system!! either buy the premixed 50/50 antifreeze (best choice), or use distilled water to mix. Even city water from the tap will have some minerals in it that are the root of radiator clogs! (well water is even worse!) Good luck! hope your CLR treatment works. Quote Link to comment Share on other sites More sharing options...
Anarch Angel Posted June 2, 2010 Author Share Posted June 2, 2010 Didn't work; it's still overheating. I finally said "screw it" and took it back to the shop where me and two mechanic friends were treated to the smell of exhaust rising out of the overflow tank. I've got a cracked head gasket. Time to find a new car. Quote Link to comment Share on other sites More sharing options...
vagen Posted June 2, 2010 Share Posted June 2, 2010 how about just popping a set of gaskets in there and having it all better its cheaper than a new car Quote Link to comment Share on other sites More sharing options...
Anarch Angel Posted June 3, 2010 Author Share Posted June 3, 2010 Because replacing a head gasket is beyond my ability and resources (I don't even have a garage), and what it costs in labor around here exceeds the cost of getting another Subaru. I only spent $1500 on this car in the first place. Quote Link to comment Share on other sites More sharing options...
vagen Posted June 3, 2010 Share Posted June 3, 2010 well let us know where you are located and I am sure someone will offer to help thats the kind of folks I've found on here. Quote Link to comment Share on other sites More sharing options...
Anarch Angel Posted June 3, 2010 Author Share Posted June 3, 2010 A remote area in south central Alaska. :-\ Quote Link to comment Share on other sites More sharing options...
