May 6, 201015 yr got a new used engine in the 3 door so Im ready for a Walker valley outin, a friday or a Saturday any takers?
May 6, 201015 yr Another month or so, I'll start having the time to do these trail runs. Almost there.
May 6, 201015 yr Author Another month or so, I'll start having the time to do these trail runs. Almost there. that would be nice
May 6, 201015 yr Dang, i'm busy this weekend. I found a bottle of "water wetter" in the garage, maybe keep the water in your radiator happier. How did those intake gaskets work out?
May 6, 201015 yr Author Dang, i'm busy this weekend. I found a bottle of "water wetter" in the garage, maybe keep the water in your radiator happier. How did those intake gaskets work out? car seems to run ok, no oil leaks and hasnt needed water thanks guys
May 6, 201015 yr Bump Come on, guys...Scott's been itching to go out again, after half or more of NWOG decided to rebuild their rigs at the same time!!! I only need exhaust work, rear axles, and ECU containment to wheel again.
May 7, 201015 yr Me Rick and Woody are still all building or rebuilding our rigs, so we are out. Yohn has 15 broken axles on his rig and needs new ones................ I'm out, till mid June or late June for work anyways, unless it is raining hard...................... Sundays are the only day for me right now and even those are questionable..................... Jeff
May 7, 201015 yr maybe up for an easy trail ride, new to area and would like to meet up with some of you around here. I know im going to need a cup for my rear axle, the one i started rebuilding is cracked... anyone have an extra? and change my shock mounts. overextending. but that will porobly wait a bit... let me know-
May 8, 201015 yr am going to install the dual range trans tomorrow, so hopefully I can get it all figured out very soon and drivable again!! then we can go play!
May 8, 201015 yr Author maybe up for an easy trail ride, new to area and would like to meet up with some of you around here. I know im going to need a cup for my rear axle, the one i started rebuilding is cracked... anyone have an extra? and change my shock mounts. overextending. but that will porobly wait a bit... let me know- Walker is hard the the subbies, will need lift , tires and a locked rearend Me Rick and Woody are still all building or rebuilding our rigs, so we are out. Yohn has 15 broken axles on his rig and needs new ones................ I'm out, till mid June or late June for work anyways, unless it is raining hard...................... Sundays are the only day for me right now and even those are questionable..................... Jeff Huummm thats to bad , glad you have work tho am going to install the dual range trans tomorrow, so hopefully I can get it all figured out very soon and drivable again!! then we can go play! Awesome are you ready for body damage?
May 8, 201015 yr well guess i cant play... will 6'' in. do? tires? like really knobby? only 15 min to make er posi. gona pretty her up a little instead. post a pic later today, robs isnt justice at all.
