Walker Valley Time
Another month or so, I'll start having the time to do these trail runs. Almost there.
Dang, i'm busy this weekend.
I found a bottle of "water wetter" in the garage, maybe keep the water in your radiator happier.
How did those intake gaskets work out?
car seems to run ok, no oil leaks and hasnt needed water thanks guys
Bump
Come on, guys...Scott's been itching to go out again, after half or more of NWOG decided to rebuild their rigs at the same time!!!
I only need exhaust work, rear axles, and ECU containment to wheel again. :banana:
Me Rick and Woody are still all building or rebuilding our rigs, so we are out. Yohn has 15 broken axles on his rig and needs new ones................
I'm out, till mid June or late June for work anyways, unless it is raining hard...................... Sundays are the only day for me right now and even those are questionable.....................
Jeff
maybe up for an easy trail ride, new to area and would like to meet up with some of you around here. I know im going to need a cup for my rear axle, the one i started rebuilding is cracked... anyone have an extra? and change my shock mounts. overextending. but that will porobly wait a bit... let me know-
am going to install the dual range trans tomorrow, so hopefully I can get it all figured out very soon and drivable again!! :)
then we can go play! :banana:
Walker is hard the the subbies, will need lift , tires and a locked rearend
Jeff
Huummm thats to bad , glad you have work tho
Awesome are you ready for body damage?
well guess i cant play... will 6'' in. do? tires? like really knobby? only 15 min to make er posi. gona pretty her up a little instead. post a pic later today, robs isnt justice at all.
