February 16, 200422 yr I can't find it in my parts book at all. it appears to be a vac valve sort of.... mounted on the passenger side firewall near the vacuum pumps, cruise, etc... it has 2 large connectors in-line, then a smaller connector as well looks like this (the "o" is actually nothing, it'sa spacer to keep the lines lined up ) =|= O|= it's attached to the firewall with 2 screws. top left connector goes to the vapor canister top right (the one broken) went to the small connector on the bottom of the metal intake plenum lower right (small one) goes down to a round object slightly smaller than a softball. What is it?
February 16, 200422 yr lower right (small one) goes down to a round object slightly smaller than a softball. The softball thing sounds like the cruise control vacuum canister my guess is that this unknown part is part of the cruise system
February 16, 200422 yr Author I was wondering about it, but it's tied to the turbo to intake instead of the manifold with the one hose, and charcoal canister with the other hose... turns out this wasn't my fuel smell issue. my right front injector is leaking badly again...
February 16, 200422 yr it might be the sensor that hooks to the dash aqnd lits up at 2 lbs with the green "turbo" lite. give a picture and I can ID it
February 17, 200422 yr Author there's no electrical connections on it, it's just 3 vac lines. I have the analog dash too, and no turbo lights.... just a boost guage.
February 17, 200422 yr Mick, Post a picture, if I don't know, a friend of mine has work at W&L subaru for 25 years, he'll know. You got the digidash? no fair! Jay
