Oil filter on 2001 forester 2.5 motor
My conclusion is that most oil filters are of excellent quality with the exception of FRAM or any re-branded FRAMS and the "expensive" filters like K&N offer no value for your dollar.
I wouldn't spend much time worrying about oil and filter choices. Seems like there's an imbalance between desire to talk oil/filters and real world value in said decision. Look up past oil threads that are painfully long...or maybe this one will go the same way. :lol:
My local auto parts store has a display with a cut open FRAM showing it's "inferior" design and parts next to a Purolator.
I use Purolator Pure One's and Mobil because they're often on sale and stock up on WIX when I'm at a place that sells them, they are well respected in the automotive community.
My recommendation is Wix, Purolator, NAPA. I avoid Fram. I heard a lot of negative talk about Fram. I was using one at the time, so at time of oil change, upon removal of the Fram, I used a hack saw and cut the filter open. I found very little filter media in the Fram, and also found the thickness of the casing wasn't much thicker then a coke can. Last Fram I bought.
It is too far for me to go to the dealer, so I buy after market filters.
I don't want to cause a debate about it; however, I just used the heavy duty Fram filter on my Forester. Putting it on myself it seemed much more substantial then their basic filter. Or, I am real trouble, should not wait for the next oil change to jettison it?
The Heavy Duty FRAM filters are actually fine. It's "XTRA" guard filters you should avoid. Oh, and +1 for the Purolator PureOne, I know those are OEM filters for Mopars.
However, as a Subaru enthusiast, I feel that it is best to purchase OEM Subaru oil filters, since the pressure valve is set specifically for Subaru engines.
Don't worry about it, it's not a big deal. I've used FRAM's before, only when I've had too, but it's not a big deal even though I think they're low grade and don't buy them. Then again it takes what 6 minutes to change one so if you feel better about it for some reason then 6 minutes and $3 isn't a big deal either!:lol: But really, you're fine, it's a filter and they work.
