July 1, 201015 yr my 94 legacy is fwd. was wondering if i need a specific engine for it since im needing a new engine or would any engine 91-94 work as i think it will?
July 1, 201015 yr Hopefully someone with more experience on this year range will chime in. Engine doesn't care which tranny. Like 90-91 have one color injectors more prone to problems. I believe 92-94 have more reliable injectors. But I think 91-94 are all linterchangable as long as you're swapping the whole engine.
July 1, 201015 yr Check out Craigslist. If you're in Saluda VA, Richmond isn't too far to look for a parts car. You may even find a whole running car in better shape.
July 1, 201015 yr im in north carolina Perhaps you would consider adding "NC" after "Saluda" in your ID.
July 1, 201015 yr Check out Craigslist. If you're in Saluda VA, Richmond isn't too far to look for a parts car. You may even find a whole running car in better shape. i don't know where saluda is but you should consider this car, i emailed him and got this, price dropped to 200$. it doesn't get any better than this, i think i deserve a free beer now. About 175,000 miles Automatic trans. AWD New brakes including rotors and 2 new tires(less than 1000 miles) no other repairs needed to put on road Seats very good, carpet good, a couple of damaged door panels Pics on ad show both sides of car, minor damage to hood/grille http://roanoke.craigslist.org/cto/1791903332.html 1992 Subaru Legacy AWD wagon - $200 (Roanoke, VA) Date: 2010-06-14, 5:02PM EDT Reply to: sale-rngta-1791903332@craigslist.org [Errors when replying to ads?] I am selling my 1992 Subaru wagon. It has been a good car but the transmission went out. I can't afford to fix it. There are a lot of good parts on it including a set of custom aluminum wheels and 2 new tires. Asking $200.00 or best offer. Location: Roanoke, VA it's NOT ok to contact this poster with services or other commercial interests Edited July 2, 201015 yr by johnceggleston
July 1, 201015 yr Author thanks john i might end up going and getting that 200 dollar subie. really good option. the one thing on my mind with it. i would have to tow it. my way is asking my buddy to hook up his car dolly and use go up there and get it. any problems on towing it?
July 1, 201015 yr It says it's AWD so I believe you could tow it if you removed the rear segment (?) of the driveshaft. Try a search--it was discussed a lot awhile back.
July 2, 201015 yr It says it's AWD so I believe you could tow it if you removed the rear segment (?) of the driveshaft. Try a search--it was discussed a lot awhile back. yes, if you use a dolly, you need to remove / disconnect the rear section of drive shaft or you will screw the trans. or just rent a car carrier trailer. the bad news is , it may cost 200$ to rent and fuel the 9 - 10 hour round trip depending on what you are towing with.
