coolskaterkid Posted August 20, 2010 Share Posted August 20, 2010 So 84 gl 4x4 wagon, trying to put new pads on, went to squeeze the pison and it moved in a bit and then stopped, the piston did not go flush with the caliper, is it supposed to go flush? It makes it so i need about a quarter inch, more until it will slide over the new pads? Quote Link to comment Share on other sites More sharing options...
Flowmastered87GL Posted August 20, 2010 Share Posted August 20, 2010 Someone else can probably confirm this, but on the gen 3 GL's (sounds like you have a gen 2) you have to rotate the piston in. Dont just push it in. Some people like to stick pliers in the little holes and twist, others use a small cube with pins on it from the auto parts store that you can stick on your socket wrench and turn it. Quote Link to comment Share on other sites More sharing options...
doobieryan Posted August 20, 2010 Share Posted August 20, 2010 Someone else can probably confirm this, but on the gen 3 GL's (sounds like you have a gen 2) you have to rotate the piston in. Dont just push it in. Some people like to stick pliers in the little holes and twist, others use a small cube with pins on it from the auto parts store that you can stick on your socket wrench and turn it. +1 This will work. Just use some needle nosers Quote Link to comment Share on other sites More sharing options...
chrisgpz Posted August 20, 2010 Share Posted August 20, 2010 yes, you have to turn them to get them to go in. use pliers or whatever, i ended up buying one of these from the local auto parts store. (tool for the job) https://www.alltools.com.au/shop/images/sz/2447.jpg it was cheap. Quote Link to comment Share on other sites More sharing options...
coolskaterkid Posted August 20, 2010 Author Share Posted August 20, 2010 thank you very much guys, got one side done before dark and will get the other done today. Quote Link to comment Share on other sites More sharing options...
