October 10, 201015 yr I have a Ea81 out of a 83 Brat that I finished the Vanaru conversion on. It's run fine till about 3 weeks ago and now there is no spark. I have replaced the coil, the pick up coil and the cap & rotor. My vertical play in the disty shaft is less than 1/8 of an inch and I no longer have the fusable links. I am completly at a loss as to why I cant get any fire. If anybody has had this same issue or if you know somebody who has or even if your second cousin on your moms side through marriage, but once removed knew some guy back in high school who knew this other guy that might be able to figure out the problem PLEASE! PLEASE! PLEASE! Tell them to respond to the thread. Thanks Everybody Boo
October 11, 201015 yr check your high tension lead from the coil to the dizzy (if you haven't already)...i found that was the problem when i had the same problem you describe
October 11, 201015 yr Author Turbone- I've checked the ignition switch and have 11.8 volts at the coil. Brumby- I've checked both wires coming out of the pick up coil (black & white and yellow) for continuity to which they both test fine, but when I test them for an open gound the yellow has no open ground and the black & white one does. I don't know if that is how it's supposed to be or if something is jacked up there. Do you know ??
October 11, 201015 yr How do you have the wires hooked up to the coil? Black goes to + and yellow to -
October 12, 201015 yr If the tach doesn't bounce when cranking it would be the disty's pick up coil or.....whatever that thing is called....the little black thing with the wires coming out of it that tells the coil to fire. BRAIN FART Someone help me out here.
October 13, 201015 yr Pick-up coil in the disty went bad, or wire(s) to it have broke off. I had one instance of the magnet under the "C" shaped piece in the disty shatter, a multitude of little pieces where found. No idea as to why it did that. Slapped in another magnet, and it was good.
