Sensor under alternator\ps pump leaking?
oil.
I assume that you are aware that the PS pump leaking is a common problem.
Stick your finger into the liquid. Green - coolant (and I can't believe that's what it is if it's the sensor I'm thinking), brown/black oil (most likely if it's the sensor, red or redish black it's power steering fluid (ATF).
Oil pressure switch. Pretty sure that's a one wire deal.
The Crank position sensor would have no reason to "leak" because there is no passage inside the crankcase for oil to exit from.
The power steering pump commonly leaks and drips right in that area as well. But that will be more towards the passenger side head. The oil pressure switch is closer to the center of the block.
I wish I could reach the area to at least stick a finger in it but the area is unreachable til I take something off\out. It IS an oily looking residue and ATF color is not noted. Whatever it is, it's ultra slow...for now. Thanks for the input!!-Trev
